Originally published at: November maintenance updates: Nextcloud Hub 10 & Nextcloud Hub 25 Autumn - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 10 or Nextcloud Hub 25 Autumn, we strongly recommend you to update to version 31.0.11 and 32.0.2 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
The maintenance updates include a number of important bug fixes and improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
- Nextcloud Hub 10 (version 31.0.11)
- Nextcloud Hub 25 Autumn (version 32.0.2)
Nextcloud Hub 25 Autumn: Your digital workspace, ready in no time
It’s here! Say hello to Nextcloud Hub 25 Autumn — Your digital workspace, ready in no time. Explore all the new features of our latest release and take it for a test drive:
- Global redesign and usability lift
- New Office UI: Colors, tabs, bars
- Performance and stability boost
- New AI Agency tools unlocked
- Talk threads & live transcription
- Calendar: Date poll for participants
- Intuitive file search
- Teams 2.0 & quick Guest accounts
- Quick presets & many other admin updates
- Vue3, WebSockets and more OpenAPI for devs
- … and much more!
Get Nextcloud Hub 25 Autumn now!
Start your instant trial right away or download the latest version!
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
