Notify push not working after clean AIO install
    • 35.0.2 Summer
    • Debian GNU/Linux 13 (trixie)
    • latest AIO
    • latest AIO
    • latest AIO
    • yes
    • after a fresh install of Debian and AIO
    • AIO
I recently had to reinstall Everything on my AIO server, due to a drive failure.
Installed the latest Debian on a fresh drive. Installed AIO via the command at the top of the readme on the AIO github. Chose to update to Nextcloud Summer And everything seemed to go well.
I tried to set up Two-Factor Authentication via Nextcloud Notifications (App since removed)
But was getting no notification on the Android app.
I also use Dav Push, which is also receiving no update from the server.
I have set up push notifications for file changes and such to test, but nothing is coming through.
If anyone could point me in the right direction, I’d be hugely appreciative.
Running occ notify_push:self-test yields the following message
âś“ redis is configured
âś“ push server is receiving redis messages
âś“ push server can load mount info from database
âś“ push server can connect to the Nextcloud server
đź—´ push server is not a trusted proxy by Nextcloud or another proxy in the chain.
  Nextcloud resolved the following client address for the test request: "***STATIC IP FROM ISP***" instead of the expected "1.2.3.4" test value.
  The following trusted proxies are currently configured: "127.0.0.1", "::1", "172.18.0.0/16"
  The following x-forwarded-for header was received by Nextcloud: "***STATIC IP FROM ISP***"
    from the following remote: 127.0.0.1
âś“ All proxies in the chain appear to be trusted by Nextcloud
  One of the proxies is the chain (probably ***STATIC IP FROM ISP***) seems to have stripped the x-forwarded-for header
  Please configure the reverse proxy at ***STATIC IP FROM ISP*** to not strip the x-forwarded-for header
  If you're having issues getting the trusted proxy setup working, you can try bypassing any existing reverse proxy
  in your setup by setting the `NEXTCLOUD_URL` environment variable to point directly to the internal Nextcloud webserver url
  (You will still need the ip address of the push server added as trusted proxy)
  1. Install fresh AIO on Fresh Debian install via command on AIO page
  2. Enable app that uses Notify push
{"reqId":"Kb6lBLxCMe3kylWBbBWW","level":3,"time":"2026-11-01T12:10:54+00:00","remoteAddr":"31.22.15.95","user":"tony","app":"dav_push","method":"PUT","url":"/remote.php/dav/addressbooks/users/tony/imported-tony-nc-contacts_27-10-2026vcf/642baac0-c1d0-4e36-bcea-7ca2d1907029","scriptName":"/remote.php","message":"transport web-push failed to deliver notification to subscription 2. error message: Client error: `POST https://fcm.googleapis.com/fcm/send/dYzU7cVjcgU:APA91bHGi9uspf7Y7nbEn-_Qsf24ObjCSFVcg6WrJ1-5IQXxKYLzk9J7j0fPc131eWE0wBc_jegGVyXWeuO1up7VpFMLZRcKo_bUnNSACcmiX7Yl8joyUxaRevojlnw8uy5B1i7qDvp7` resulted in a `410 Gone` response:\npush subscription has unsubscribed or expired.\n\n thrown in /var/www/html/custom_apps/dav_push/lib/PushTransports/WebPushTransport.php:345","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:159.0) Gecko/20100101 Firefox/159.0","version":"35.0.2.2","data":{"app":"dav_push"},"id":"6ae73178359d6"}
PASTE
Not sure where to find for AIO
        "one-click-instance": true,
        "update_channel": "stable",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "timeout": 3,
            "read_timeout": 10,
            "port": 6379
        "overwritehost": "***DOMAIN NAME***",
        "overwriteprotocol": "https",
        "serverid": 445,
            "localhost",
            "***DOMAIN NAME***"
        "dbtype": "pgsql",
        "version": "35.0.2.2",
        "overwrite.cli.url": "https:\/\/***DOMAIN NAME***\/",
        "updatechecker": false,
        "loglevel": 2,
        "log_type": "file",
        "log_type_audit": "file",
        "logfile_audit": "\/var\/www\/html\/data\/audit.log",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
            "24": "OCA\\Eurooffice\\Preview"
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "eurooffice": {
            "editors_check_interval": 0,
            "jwt_secret": "***REMOVED SENSITIVE VALUE***",
            "jwt_header": "AuthorizationJwt"
        "default_phone_region": "GB",
        "mail_smtpauth": true,
        "mail_smtpport": "465",
        "mail_sendmailmode": "smtp",
        "mail_smtpstreamoptions": {
            "ssl": {
                "allow_self_signed": false,
                "verify_peer": true,
                "verify_peer_name": true
        "app_install_overwrite": [],
        "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/eperl-amd64-musl",
        "memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64",
        "DOMAIN": "***DOMAIN NAME***",
        "AIO_VERSION": "v14.4.3"
  • activity: 8.0.0
  • admin_audit: 2.0.0
  • appstore: 2.0.0
  • bruteforcesettings: 8.0.0
  • calendar: 6.6.4
  • circles: 35.0.0
  • cloud_federation_api: 2.0.0
  • comments: 2.0.0
  • contacts: 8.9.3
  • dav: 2.0.0
  • dav_push: 1.0.3
  • deck: 1.19.1
  • eurooffice: 11.0.6
  • federatedfilesharing: 2.0.0
  • federation: 2.0.0
  • files: 3.0.0
  • files_antivirus: 6.5.0
  • files_downloadlimit: 5.3.0
  • files_lock: 35.0.1
  • files_pdfviewer: 8.0.0
  • files_reminders: 2.0.0
  • files_sharing: 2.0.0
  • files_trashbin: 2.0.0
  • files_versions: 2.0.0
  • firstrunwizard: 8.0.0
  • logreader: 8.0.0
  • lookup_server_connector: 2.0.0
  • mail: 5.12.6
  • memories: 10.2.0
  • nextcloud-aio: 0.9.0
  • nextcloud_announcements: 7.0.0
  • notes: 6.1.0
  • notifications: 8.0.1
  • notify_push: 1.4.2
  • oauth2: 2.0.0
  • office: 1.1.0
  • password_policy: 7.0.0
  • photos: 8.0.0
  • previewgenerator: 5.15.0
  • privacy: 7.0.0
  • profile: 2.0.0
  • provisioning_api: 2.0.0
  • recommendations: 8.0.0
  • related_resources: 6.0.0
  • serverinfo: 7.0.0
  • settings: 2.0.0
  • sharebymail: 2.0.0
  • sharing: 1.0.4
  • spreed: 25.0.6
  • support: 7.0.0
  • survey_client: 7.0.0
  • systemtags: 2.0.0
  • tasks: 0.18.1
  • text: 9.0.1
  • theming: 3.0.0
  • twofactor_backupcodes: 2.0.0
  • twofactor_totp: 17.1.0
  • updatenotification: 2.0.0
  • user_status: 2.0.0
  • viewer: 8.0.0
  • webhook_listeners: 2.0.0
  • workflowengine: 3.0.0
  • app_api: 35.0.0 (installed 35.0.0)
  • contactsinteraction: 2.0.0 (installed 2.0.0)
  • dashboard: 8.0.0 (installed 8.0.0)
  • encryption: 3.0.1
  • files_external: 2.0.0
  • suspicious_login: 13.0.0
  • twofactor_nextcloud_notification: 9.0.0
  • user_ldap: 2.0.0
  • weather_status: 2.0.0 (installed 2.0.0)
Can you elaborate? AIO comes with notify_push pre deployed and self configures it.
Hi.
Sorry, was thinking back to when I hosted on bare metal and had to manually set it up.
