Notify Push Container Won't Start - Possible DNS Issue, maybe ipv6?
    • 32
    • Truenas 25.04.2.4
    • Nginx Proxy Manager v2.12.6
    • yes
    • upon first deployment of AIO containers
    • AIO on custom app (yaml) in Truenas
    • no
I have a brand new fresh install on Nextcloud AIO v11.9.0 / Nextcloud Hub 25 Autumn and everything gets deployed without any issues except the Notify Push container. I’ve done a little research and this seems to happen from to time, but I was curious of a ‘well known’ solution for this and / or perhaps this is related to the recent release of Hub 25? Seems to be a DNS issues, but why would all the other containers not have an issue but this one does. Logs shown here:
2025-09-30T11:38:36.361505008Z nc: getaddrinfo for host “nextcloud-aio-nextcloud” port 9001: Name does not resolve
then a bunch of this
2025-09-30T11:50:52.310282662Z Connection to nextcloud-aio-nextcloud (172.16.2.10) 9001 port \[tcp/\*\] succeeded!
2025-09-30T11:50:52.311989997Z The notify_push binary was not found.
2025-09-30T11:50:52.312031651Z Most likely is DNS resolution not working correctly.
2025-09-30T11:50:52.312039874Z You can try to fix this by configuring a DNS server globally in dockers daemon.json.
2025-09-30T11:50:52.312046316Z See [https://dockerlabs.collabnix.com/intermediate/networking/Configuring_DNS.html](https://dockerlabs.collabnix.com/intermediate/networking/Configuring_DNS.html)
2025-09-30T11:50:52.312054111Z Afterwards a restart of docker should automatically resolve this.
2025-09-30T11:50:52.312070116Z Additionally, make sure to disable VPN software that might be running on your server
2025-09-30T11:50:52.312077189Z Also check your firewall if it blocks connections to github
2025-09-30T11:50:52.312090741Z If it should still not work afterwards, feel free to create a new thread at [https://github.com/nextcloud/all-in-one/discussions/new?category=questions](https://github.com/nextcloud/all-in-one/discussions/new?category=questions) and post the Nextcloud container logs there.
confirmed this has to be ipV6 related; i disabled ipv6 on WAN and LAN and the notify-push started right away.
