I was working on changing my PHP install to php-fpm on a working host. After configuring php-fpm and adding the following line to my enabled apache2 site Nextcloud is no longer recognizing my HSTS setting. Thoughts?
Line I added to my apache2 config:
ProxyPassMatch ^/(..php(/.)?)$ unix:/run/php/php7.3-fpm.sock|fcgi://localhost/var/www/html/
My whole apache2 config:
<IfModule mod_ssl.c>
<VirtualHost *:443>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request’s Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
ServerName nextcloud.{removed}.comServerAdmin {removed} DocumentRoot /var/www/html # Available loglevels: trace8, ..., trace1, debug, info, notice, warn, # error, crit, alert, emerg. # It is also possible to configure the loglevel for particular # modules, e.g. #LogLevel info ssl:warn ErrorLog ${APACHE_LOG_DIR}/error.log CustomLog ${APACHE_LOG_DIR}/access.log combined ProxyPassMatch ^/(.*\.php(/.*)?)$ unix:/run/php/php7.3-fpm.sock|fcgi://localhost/var/www/html/ # For most configuration files from conf-available/, which are # enabled or disabled at a global level, it is possible to # include a line for only one particular virtual host. For example the # following line enables the CGI configuration for this host only # after it has been globally disabled with "a2disconf". #Include conf-available/serve-cgi-bin.conf
<Directory /var/www/html/>
Options +FollowSymlinks
AllowOverride All
Require all granted
<IfModule mod_headers.c>
Header always set Strict-Transport-Security “max-age=15552000; includeSubDomains”
</IfModule>
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /var/www/html
SetEnv HTTP_HOME /var/www/html
</Directory>Include /etc/letsencrypt/options-ssl-apache.conf
SSLCertificateFile /etc/letsencrypt/live/nextcloud.{removed}.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/nextcloud.{removed}.com/privkey.pem
</VirtualHost>
</IfModule>
Nextcloud now says:
There are some warnings regarding your setup.
- The “Strict-Transport-Security” HTTP header is not set to at least “15552000” seconds. For enhanced security, it is recommended to enable HSTS as described in the security tips
Recommendations on how I can resolve this?
