Dear all,
My ncp installation is not able to read the USB drive since some days ago. I am not sure what’s wrong. It was working for more than 1 year already and this started happening after last update.
The output of ncp-report is the following
ncp-report
<--! Paste this in GitHub report -->
NextCloudPi diagnostics
NextCloudPi version v1.34.1
NextCloudPi image NextCloudPi_03-09-19
distribution Raspbian GNU/Linux 10 \n \l
automount yes
USB devices sda
datadir /media/USBdrive/ncdata (doesn't exist)
rootfs usage 3.9G/15G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check error
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP ***REMOVED SENSITIVE VALUE***
gateway ***REMOVED SENSITIVE VALUE***
interface eth0
certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
uptime 26min
Nextcloud configuration
Error: Class 'OC\Server' not found in /var/www/nextcloud/lib/base.php:594
Stack trace:
#0 /var/www/nextcloud/lib/base.php(1091): OC::init()
#1 /var/www/nextcloud/console.php(49): require_once('/var/www/nextcl...')
#2 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#3 {main}
HTTPd logs
乂'M�P�'��*
8�M��RS�:���M��V �?�:���M��[Thu Jan 21 14:57:13.606611 2021] [proxy_fcgi:error] [pid 1241:tid 1715835936] [client 192.168.178.68:48940] AH01071: Got error 'PHP message: PHP Warning: filemtime(): stat failed for /media/USBdrive/ncp-backups/nextcloud-bkp_20201216_1608087624.tar in /var/www/ncp-web/backups.php on line 62PHP message: PHP Warning: filesize(): stat failed for /media/USBdrive/ncp-backups/nextcloud-bkp_20201216_1608087624.tar in /var/www/ncp-web/backups.php on line 63PHP message: PHP Warning: filemtime(): stat failed for /media/USBdrive/ncp-backups/nextcloud-bkp_20201231_1609383605.tar in /var/www/ncp-web/backups.php on line 62PHP message: PHP Warning: filesize(): stat failed for /media/USBdrive/ncp-backups/nextcloud-bkp_20201231_1609383605.tar in /var/www/ncp-web/backups.php on line 63PHP message: PHP Warning: filemtime(): stat failed for /media/USBdrive/ncp-backups/nextcloud-bkp_20210101_1609470007.tar in /var/www/ncp-web/backups.php on line 62PHP message: PHP Warning: filesize(): stat failed for /media/USBdrive/ncp-backups/nextcloud-bkp_20210101_1609470007.tar in /var/www/ncp-web/backups.php on line 63'
Database logs
Nextcloud logs
tail: cannot open '/media/USBdrive/ncdata/nextcloud.log' for reading: Not a directory
