Not All files are shown on Web-interface
I am working on building a resource repository for my team to store sound files. However, after uploading a large number of folders, I encountered an issue: only some files and folders are visible, typically limited to the first 30 items. All functions work fine on the client.
Does any one has the same issue?
The missing files or folders are displayed as blank area like this.
Hello @gedwen_chen and Welcome to the Nextcloud community forums!
A little more context on your issue might help. What method did you use to upload your files? Did you use the Nextcloud Desktop client application to sync the files to the server or did you upload them through Nextcloud Files using a Web browser ?
For uploading large collections of files, I would recommend using the Desktop client to sync your local folders to the server. The Desktop client will ensure that everything is perfectly in-sync and will help you a great deal in tracking specific errors.
Wild guess since you didn’t provide much context: do you have the files_readmemd app installed? If so, may be this: Version 3.0.0 on Nextcloud 28 prevents the file listing from loading completely. Lazy loading while/after scrolling broken · Issue #159 · mamatt/files_readmemd · GitHub
I need to say you are the angel. This exactly solves the issue.
