Dear all,
This is the error i receive from the log everytime I try o delete a folder
OCA\DAV\Connector\Sabre\Exception\Forbidden: Invalid path
/var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php - line 183:
OCA\DAV\Connector\Sabre\Directory->delete()
/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 295:
Sabre\DAV\Tree->delete("files/simon ... r")
/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89:
Sabre\DAV\CorePlugin->httpDelete(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 474:
Sabre\DAV\Server->emit("method:DELETE", [ Sabre\HTTP ... }])
/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 251:
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 319:
Sabre\DAV\Server->start()
/var/www/html/apps/dav/lib/Server.php - line 320:
Sabre\DAV\Server->exec()
/var/www/html/apps/dav/appinfo/v2/remote.php - line 35:
OCA\DAV\Server->exec()
/var/www/html/remote.php - line 167:
require_once("/var/www/ht ... p")
