Nextcloud version (eg, 20.0.0):
Operating system and version (Debian 10 Buster):
Apache or nginx version (nginx 1.18.0-v.debian.10+p18.0.30.0+t200826.0942):
PHP version (7.4):
This “error” appears again and again. Unfortunately, I cannot find this error in this instance.
I cannot replicate this error in any other instance.
{"reqId":"Ip8Bx87pNRMmjU50kNnU","level":4,"time":"2020-10-07T07:39:42+02:00","remoteAddr":"77.3.116.17","user":"--","app":"webdav","method":"PROPFIND","url":"/public.php/webdav/","message":{"Exception":"OCA\\DAV\\Connector\\Sabre\\Exception\\Forbidden","Message":"No read permissions","Code":0,"Trace":[{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/Tree.php","line":204,"function":"getChildren","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":905,"function":"getChildren","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":987,"function":"generatePathNodes","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":1678,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":1661,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":363,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":474,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/apps/dav/appinfo/v1/publicwebdav.php","line":113,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/vhosts/domain.tld/httpdocs/public.php","line":81,"args":["/var/www/vhosts/domain.tld/httpdocs/apps/dav/appinfo/v1/publicwebdav.php"],"function":"require_once"}],"File":"/var/www/vhosts/domain.tld/httpdocs/apps/dav/lib/Connector/Sabre/Directory.php","Line":262,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:81.0) Gecko/20100101 Firefox/81.0","version":"20.0.0.9","id":"5f7d55318a8cb"}
'instanceid' => '*',
'passwordsalt' => '*',
'secret' => '*',
0 => 'domain.tld',
'datadirectory' => '/var/www/vhosts/domain.tld/httpdocs/data',
'version' => '20.0.0.9',
'overwrite.cli.url' => 'https://domain.tld/',
'dbname' => '*',
'dbhost' => 'localhost',
'dbuser' => '*',
'dbpassword' => '*',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'share_folder' => '/Mit mir geteilt',
'mail_from_address' => '*',
'mail_smtpmode' => 'smtp',
'mail_domain' => '*',
'mail_smtpauthtype' => '*',
'mail_smtpauth' => 1,
'mail_smtphost' => '*',
'mail_smtpport' => '*',
'mail_smtpname' => '*',
'mail_smtppassword' => '*',
'log_type' => 'file',
'logfile' => '/var/www/vhosts/domain.tld/logs/*nc.log',
'loglevel' => 2,
'syslog_tag' => 'Nextcloud',
'app_install_overwrite' =>
0 => 'files_readmemd',
1 => 'occweb',
2 => 'issuetemplate',
'mail_smtpsecure' => 'ssl',
'twofactor_enforced' => 'true',
0 => '*',
1 => '*',
2 => '*',
'theme' => '',
Error 403 PROPFIND /public.php/webdav/ HTTP/2.0
Error 404 GET /ocs/v2.php/cloud/users/?format=json HTTP/1.1
Does anyone have an idea what it could be?
