Nextcloud version _: 18.0.4
Operating system and version : Debian 10
nginx: 1.17.10
PHP version _:7.4.5
Loggin in from a local ip to local ip is no problem. Everything works like a charm.
local ip 192.168.1.119 post 443
Loggin in from a local ip to url is a problem.
I see the nextcloud screen and logo. but the login boxes do not apear.
home.sieliakus.nl
Loggin in from local network or outside network i see the same.
URL is with allowed hosts.
nginx servername is home.sieliakus.nl.
I found it.
My certificates (cloudflare) are not installed right.
I have to get id off the let’s encrypt things an point is to cloudflare.
The cli url i already edited. but more reverse proxy things are going on.
when i have it working i wil post the right .conf
Thankyou.
