example
longer
example
here
Nextcloud version: 25.0.2
Operating system and version: Linux 4.19.0-21-amd64 x86_64
Apache version: unknown
PHP version: 8.0.26
I do not see any files or folders in the nextcloud web interface. The only thing that is shown is the amount of files that are in a certain folder and the respective size. Those numbers are correct - i can x-check them with any client (android, linux), where all files correctly exist and are still synced. I can also access certain folders in the web interface if i type in the folder in the URL, but i dont see anything in the UI.
There are no errors shown in the admin section or the nextcloud.log. To troubleshoot I disabled all apps, checked the behaviour (no change). I also ran php occ upgrade
and php occ maintenance:repair
(no change).
Is this the first time you’ve seen this error? (Y/N): Yes
- Upgraded from 24.0.8 to 25.0.2
- Open files application
No error being shown
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => 'nextcloud.something.de',
'datadirectory' => '/var/www/vhosts/something/httpdocs/nextcloud/data',
'version' => '25.0.2.3',
'overwrite.cli.url' => 'https://nextcloud.something.de',
'dbname' => '',
'dbhost' => '',
'dbuser' => '',
'dbpassword' => '',
'theme' => '',
'loglevel' => 2,
'activity_use_cached_mountpoints' => true,
'activity_expire_days' => 180,
'default_language' => 'de',
'default_locale' => 'de',
'skeletondirectory' => '',
[Thu Dec 15 10:22:58.161502 2022] [core:crit] [pid 26338] (13)Permission denied: [client 2.203.168.145:0] AH00529: /var/www/vhosts/hosting112231.a2f51.netcup.net/httpdocs/nextcloud/data/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable and that '/var/www/vhosts/hosting112231.a2f51.netcup.net/httpdocs/nextcloud/data/' is executable
[Thu Dec 15 10:23:45.668436 2022] [fcgid:warn] [pid 26198] (32)Broken pipe: [client 2.203.168.145:0] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function
