No exception for .well-known... for certbot
longer
example
here
Some or all of the below information will be requested if it isn't supplied; for fastest response please provide as much as you can :heart:
[/details]
Nextcloud version _(eg, 12.0.2)_: 15.0.2
Operating system and version _(eg, Ubuntu 17.04)_: Debian 9
Apache or nginx version _(eg, Apache 2.4.25)_:   Apache2 2.4.25-3+deb9u6
PHP version _(eg, 7.1)_: 7.2
The issue you are facing: Nextcloud does not exclude Acme-Challenge from redirect to loginpage
Is this the first time you've seen this error? _(Y/N)_: Y
1.  Run certbot (version 0.28): sudo certbot renew --dry-run
2. Certbot creates a file in /.well-known/acme-challenge, Letsencrypt checks this file.
3. Creating cert fails with error: Domain: [mydomain)
Type: unauthorized
Detail: Invalid response from
mydomain/.well-known/acme-challenge/G1Gf7h2lhuipYcRa7T6wKpgDvrR_caZnrFeIsjbV7uU:
“\n\n403
Forbidden\n\n
The output of your Nextcloud log in **Admin > Logging**:
The output of your config.php file in `/path/to/nextcloud` (make sure you remove any identifiable information!):
<?php $CONFIG = array ( 'instanceid' => 'XXX', 'passwordsalt' => 'XXX', 'secret' => 'XXX', 'trusted_domains' => array ( 0 => 'website.de', 1 => 'websitealt.de', 2 => 'cloud', 3 => '192.168.178.71', ), 'datadirectory' => '/data', 'overwrite.cli.url' => 'https://website.de', 'dbtype' => 'mysql', 'version' => '15.0.2.0', 'dbname' => 'XXX', 'dbhost' => 'localhost', 'dbport' => '', 'dbtableprefix' => 'oc_', 'dbuser' => 'XXX', 'dbpassword' => 'XXX', 'installed' => true, 'memcache.local' => '\\OC\\Memcache\\APCu', 'memcache.locking' => '\\OC\\Memcache\\Redis', 'redis' => array ( 'host' => 'localhost', 'port' => XXX, ), 'maintenance' => false, 'theme' => '', 'loglevel' => 2, 'filesystem_check_changes' => 0, 'filelocking.enabled' => true, 'updater.release.channel' => 'stable', 'mail_smtpmode' => 'smtp', 'mail_smtpsecure' => 'ssl', 'mail_smtpauthtype' => 'LOGIN', 'mail_smtpauth' => 1, 'twofactor_enforced' => 'false', 'twofactor_enforced_groups' => array ( ), 'twofactor_enforced_excluded_groups' => array ( ), ); ``` The output of your Apache/nginx/system log in `/var/log/____`: ``` [Wed Feb 06 11:13:48.263735 2019] [access_compat:error] [pid 29196] [client 17.58.81.142:50204] AH01797: client denied by server configuration: /var/www/html/index.php [Wed Feb 06 11:13:48.720440 2019] [access_compat:error] [pid 29185] [client 17.58.81.142:50250] AH01797: client denied by server configuration: /var/www/html/.well-known [Wed Feb 06 11:13:48.720742 2019] [access_compat:error] [pid 29185] [client 17.58.81.142:50250] AH01797: client denied by server configuration: /var/www/html/index.php [Wed Feb 06 11:13:49.563727 2019] [access_compat:error] [pid 29214] [client 17.58.81.142:50342] AH01797: client denied by server configuration: /var/www/ html/index.php [Wed Feb 06 11:13:49.563895 2019] [access_compat:error] [pid 29214] [client 17.58.81.142:50342] AH01797: client denied by server configuration: /var/www/html/ [Wed Feb 06 11:22:27.128936 2019] [access_compat:error] [pid 29864] [client 17.58.85.99:44628] AH01797: client denied by server configuration: /var/www/html/.well-known [Wed Feb 06 11:22:27.130089 2019] [access_compat:error] [pid 29864] [client 17.58.85.99:44628] AH01797: client denied by server configuration: /var/www/html/index.php [Wed Feb 06 11:22:28.018894 2019] [access_compat:error] [pid 29868] [client 17.58.85.99:44682] AH01797: client denied by server configuration: /var/www/html/.well-known ```
Are you using http or https? Is the URL
http://ok.fahmed.de/.well-known/acme-challenge/G1Gf7h2lhuipYcRa7T6wKpgDvrR_caZnrFeIsjbV7uU:
Accessible in a browser or via a local curl command? Where is the
directory located?
I am using https, but Port 80 is open. When I try to access the URL I am forwarded to the Nextcloud login.
I am not sure how to find the location of .well-known/acme-challenge .
Curl gives me:
301 Moved Permanently
Moved Permanently
The document has moved here.
Apache/2.4.25 (Debian) Server at website.de Port 80
Most likely the file is in your nextcloud directory, have you checked? The 301 means the http request is redirected to https. Check the location of your .well-known directory, and make sure it can be seen via http.
Thanks eehmke, but it was absolutely my fault. I had a Geo-IP lock installed which prevented the challenge file from being accessed by the authority.
