example
longer
example
here
Nextcloud version (eg, 20.0.5): 21.0.0.18
Operating system and version (eg, Ubuntu 20.04): Raspberry Pi OS Buster 64bit
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.38 (Debian)
PHP version (eg, 7.4): 7.4.16
After having been off some hours no connection to nextcloud possible anymore trough browser.
When trying to connect with local IP address i get “… untrusted domain”
Server is up and running. Apache and pgsql ok.
ssh ok.
Is this the first time you’ve seen this error? (Y/N): y
- connect NC using https://
don't know where to find
'instanceid' => 'oc97vfin04v4',
'passwordsalt' => 'AJZ3Dj/iGP66MUI6SZg7EwBISTgiCa',
'secret' => 'B9VaXg8XRmQIoJZJX1Cnzi2udC1s6Qa8onGqpfkDEjqTbnD1',
0 => 'localhost',
1 => 'sld.tld',
2 => 'sub.sld.tld',
'dbtype' => 'pgsql',
'version' => '21.0.0.18',
'overwrite.cli.url' => 'https://sld.tld',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbport' => '5432',
'dbuser' => 'user',
'dbpassword' => 'password',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_smtphost' => 'provider',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => 'name',
'mail_smtppassword' => 'password',
'mail_from_address' => 'recipient',
'mail_domain' => 'sld.tld',
'default_language' => 'de_DE',
'default_phone_region' => 'CH',
'knowledgebaseenabled' => true,
[Wed Mar 10 00:00:00.873605 2021] [mpm_event:notice] [pid 684:tid 548637271408] AH00489: Apache/2.4.38 (Debian) OpenSSL/1.1.1j configured -- resuming normal operations
[Wed Mar 10 00:00:00.873669 2021] [core:notice] [pid 684:tid 548637271408] AH00094: Command line: '/usr/sbin/apache2'
[Wed Mar 10 00:31:45.368034 2021] [mpm_event:notice] [pid 684:tid 548637271408] AH00491: caught SIGTERM, shutting down
[Wed Mar 10 00:32:40.996211 2021] [mpm_event:notice] [pid 713:tid 548269262192] AH00489: Apache/2.4.38 (Debian) OpenSSL/1.1.1j configured -- resuming normal operations
[Wed Mar 10 00:32:40.996580 2021] [core:notice] [pid 713:tid 548269262192] AH00094: Command line: '/usr/sbin/apache2'
[Wed Mar 10 00:37:10.186165 2021] [core:warn] [pid 713:tid 548269262192] AH00045: child process 715 still did not exit, sending a SIGTERM
[Wed Mar 10 00:37:12.188310 2021] [core:warn] [pid 713:tid 548269262192] AH00045: child process 715 still did not exit, sending a SIGTERM
[Wed Mar 10 00:37:14.190420 2021] [core:warn] [pid 713:tid 548269262192] AH00045: child process 715 still did not exit, sending a SIGTERM
[Wed Mar 10 00:37:16.192513 2021] [core:error] [pid 713:tid 548269262192] AH00046: child process 715 still did not exit, sending a SIGKILL
[Wed Mar 10 00:37:17.194239 2021] [mpm_event:notice] [pid 713:tid 548269262192] AH00491: caught SIGTERM, shutting down
[Wed Mar 10 00:38:10.902126 2021] [mpm_event:notice] [pid 703:tid 547612730736] AH00489: Apache/2.4.38 (Debian) OpenSSL/1.1.1j configured -- resuming normal operations
[Wed Mar 10 00:38:10.902462 2021] [core:notice] [pid 703:tid 547612730736] AH00094: Command line: '/usr/sbin/apache2'
