No connection to selfhosted onlyoffice instance
Hey,
I’d like to integrate onlyoffice in my self hosted k3s cluster, but I’m always hitting a wall when trying to connect to it. I’ve pretty much tried everything, hopefully someone can help me to figure it out! The thing is, I have nextcloud running in docker as well (same setup with traefikv2.3), which works great. But even if I try to connect to that very instance, it fails to connect.
Err log with cluster addresses
  Error    index              InvalidArgumentException: Key may not be empty at                                            2021-01-22T12:55:32+01:00
                              custom_apps/onlyoffice/3rdparty/jwt/JWT.php line 72
                              0. custom_apps/onlyoffice/lib/crypt.php line 70
                                 Firebase\JWT\JWT::decode(
                                   "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhY3Rpb24iOiJl ... s",
                                   ["HS256"]
                              1. .../controller/callbackcontroller.php line 318
                                 OCA\Onlyoffice\Crypt->ReadHash("eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhY3Rpb2 ... s")
                              2. .../Dispatcher.php line 169
                                 OCA\Onlyoffice\Controller\CallbackController->emptyfile("eyJ0eXAiOiJKV1QiLCJhbG ... s")
                              3. .../Http/Dispatcher.php line 100
                                 OC\AppFramework\Http\Dispatcher->executeController(
                                   OCA\Onlyoffice\Controller\Ca ... {},
                                   "emptyfile"
                              4. lib/private/AppFramework/App.php line 152
                                 OC\AppFramework\Http\Dispatcher->dispatch(
                                   OCA\Onlyoffice\Controller\CallbackCon ... {},
                                   "emptyfile"
                              5. lib/private/Route/Router.php line 309
                                 OC\AppFramework\App::main(
                                   "OCA\\Onlyoffice\\Controller\\CallbackController",
                                   "emptyfile",
                                   OC\AppFramework\DependencyInjection\DIContainer {},
                                   {_route:"onlyoffice.callback.emptyfile"}
                              6. lib/base.php line 1008
                                 OC\Route\Router->match("\/apps\/onlyoffice\/empty")
                              7. index.php line 37
                                 OC::handleRequest(
  Error    index              InvalidArgumentException: Key may not be empty at                                            2021-01-22T12:55:33+01:00
                                   ["HS256"]
                                   "emptyfile"
                                   "emptyfile"
                                   "emptyfile",
                                 OC::handleRequest(
  Error    index              InvalidArgumentException: Key may not be empty at                                            2021-01-22T12:55:34+01:00
                                   ["HS256"]
                                   "emptyfile"
                                   "emptyfile"
                                   "emptyfile",
                                 OC::handleRequest(
  Error    onlyoffice         Exception: Im Dokumentenservice ist ein Fehler aufgetreten: Error while downloading the      2021-01-22T12:55:36+01:00
                              document file to be converted. at custom_apps/onlyoffice/lib/documentservice.php line 235
                              0. .../documentservice.php line 94
                                 OCA\Onlyoffice\DocumentService->ProcessConvServResponceError("-4")
                              1. .../lib/documentservice.php line 432
                                 OCA\Onlyoffice\DocumentService->GetConvertedUri(
                                   "https:\/\/nextcloud.mydomain.c ... s",
                                   "docx",
                                   "docx",
                                   "check_365051401"
                              2. .../settingscontroller.php line 168
                                 OCA\Onlyoffice\DocumentService->checkDocServiceUrl(
                                   OC\URLGenerator {},
                                   OCA\Onlyoffice\Crypt {}
                              3. .../Dispatcher.php line 169
                                 OCA\Onlyoffice\Controller\SettingsController->SaveAddress(
                                   "https:\/\/office.nex ... /",
                                   "https:\/\/office.nex ... d",
                                   "https:\/\/nextcloud. ... /",
                                   false,
                                   false
                              4. .../Http/Dispatcher.php line 100
                                   OCA\Onlyoffice\Controller\Se ... {},
                                   "saveAddress"
                              5. lib/private/AppFramework/App.php line 152
                                   OCA\Onlyoffice\Controller\SettingsCon ... {},
                                   "saveAddress"
                              6. lib/private/Route/Router.php line 309
                                   "SettingsController",
                                   "saveAddress",
                                   {_route:"onlyoffice.settings.save_address"}
                              7. lib/base.php line 1008
                                 OC\Route\Router->match("\/apps\/onlyoffice\/ajax\/settings\/address")
                              8. index.php line 37
                                 OC::handleRequest(
My traefik configuration
apiVersion: traefik.containo.us/v1alpha1
kind: IngressRoute
metadata:
  namespace: nextcloud
  labels:
    app: nextcloud
    tier: onlyoffice-backend
spec:
  entryPoints:
  - websecure
  routes:
  - kind: Rule
    match: Host(`office.nextcloud.mydomain.com`)
    middlewares:
    - name: nextcloud-office
    services:
    - kind: Service
      port: 80
  tls:
    secretName: nextcloud-onlyoffice-cert
apiVersion: v1
kind: Service
metadata:
  labels:
    app: nextcloud
spec:
  ports:
    - port: 80
  selector:
    app: nextcloud
  type: ClusterIP
kind: Middleware
metadata:
  labels:
    app: nextcloud
spec:
  headers:
    accessControlMaxAge: 100
    referrerPolicy: "no-referrer"
    stsSeconds: 31536000
    forceSTSHeader: true
    stsPreload: true
    stsIncludeSubdomains: true
    browserXssFilter: true
    customRequestHeaders:
      X-Forwarded-Proto: "https"
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: nextcloud
spec:
  selector:
    matchLabels:
      app: nextcloud
  strategy:
    type: Recreate
  template:
    metadata:
      labels:
        app: nextcloud
    spec:
      containers:
      - image: docker.io/onlyoffice/documentserver:latest
        ports:
        - containerPort: 80
Extra onlyoffice config
  'onlyoffice' =>
    'verify_peer_off' => true,
  'allow_local_remote_servers' => true,
Thank you!
If you need anything else, please ask!
Error message (with occ log:watch -vvv and settings for my docker instance of onlyoffice)
  Error    index              InvalidArgumentException: Key may not be empty at                                            2021-01-22T12:49:30+01:00
                                   ["HS256"]
                                   "emptyfile"
                                   "emptyfile"
                                   "emptyfile",
                                 OC::handleRequest(
  Error    index              InvalidArgumentException: Key may not be empty at                                            2021-01-22T12:49:31+01:00
                                   ["HS256"]
                                   "emptyfile"
                                   "emptyfile"
                                   "emptyfile",
                                 OC::handleRequest(
  Error    index              InvalidArgumentException: Key may not be empty at                                            2021-01-22T12:49:32+01:00
                                   ["HS256"]
                                   "emptyfile"
                                   "emptyfile"
                                   "emptyfile",
                                 OC::handleRequest(
  Error    onlyoffice         Exception: Im Dokumentenservice ist ein Fehler aufgetreten: Error while downloading the      2021-01-22T12:49:34+01:00
                                   "https:\/\/nextcloud.mydomain.co ... s",
                                   "docx",
                                   "docx",
                                   "check_434668502"
                                   OC\URLGenerator {},
                                   "https:\/\/office.myd ... /",
                                   false,
                                   false
                                   "saveAddress"
                                   "saveAddress"
                                   "saveAddress",
                                 OC::handleRequest(
Is it relevant that this nextcloud instance is not available publicly?
did you set the secret the same?
Do you use onlyoffice in the docker?
I had endless issues, until:
nc-config
  'onlyoffice' => array (
    'jwt_secret' => 'newsecret',
    'jwt_header' => 'newheader',
start the docker with the new secret PLUS header. using the default header never worked for me
docker run -i -t -d -p 8443:443 --restart=always -v /app/onlyoffice/DocumentServer/data:/var/www/onlyoffice/Data -e JWT_ENABLED='true' -e JWT_SECRET='newsecret' -e JWT_HEADER='newheader' onlyoffice/documentserver
Wow that did the trick, thank you! I’m still wondering why it works in my docker setup?!
For anyone curious, those are the deployments or changes I did to make it work:
secret.yml
apiVersion: v1
kind: Secret
type: Opaque
metadata:
  labels:
    app: nextcloud
data:
  secret: MDYwNzhmNjc5YzFlNTI1NjY3ZmUxMDliYzA1NzM1ZTg=
  header: bmV4dGNsb3Vkb25seW9mZmljZWhlYWRlcg==
configmap.yml
apiVersion: v1
kind: ConfigMap
metadata:
  labels:
    app: nextcloud
    tier: backend
data:
  onlyoffice.config.php: |-
      'onlyoffice' =>
        'jwt_secret' => '06078f679c1e525667fe109bc05735e8',
        'jwt_header' => 'nextcloudonlyofficeheader',
php-fpm.yml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: nextcloud
spec:
  selector:
    matchLabels:
      app: nextcloud
      tier: fpm-backend
  strategy:
    type: Recreate
  template:
    metadata:
      labels:
        app: nextcloud
        tier: fpm-backend
    spec:
      containers:
      - image: docker.io/library/nextcloud:stable-fpm
        env:
        - name: MYSQL_HOST
          value: nextcloud-mariadb
        - name: MYSQL_PASSWORD
          valueFrom:
            secretKeyRef:
              key: DatabasePassword
        - name: MYSQL_DATABASE
          valueFrom:
            secretKeyRef:
              key: DatabaseName
        - name: MYSQL_USER
          valueFrom:
            secretKeyRef:
              key: DatabaseUser
        - name: REDIS_HOST
          value: nextcloud-redis
        - name: REDIS_HOST_PASSWORD
          valueFrom:
            secretKeyRef:
              key: Password
        - name: NEXTCLOUD_TRUSTED_DOMAINS
          value: "nextcloud.mydomain.com"
        ports:
        - containerPort: 9000
        volumeMounts:
        - name: nextcloud-html-storage
          mountPath: /var/www/html
        - name: nextcloud-persistent-storage
          mountPath: /var/www/html/data
        - name: configs
          mountPath: /var/www/html/config/proxy.config.php
          subPath: proxy.config.php
        - name: configs
          mountPath: /var/www/html/config/smtp.config.php
          subPath: smtp.config.php
        - name: configs
          mountPath: /var/www/html/config/onlyoffice.config.php
          subPath: onlyoffice.config.php
        - name: configs
          mountPath: /var/www/html/config/extra.config.php
          subPath: extra.config.php
      volumes:
        persistentVolumeClaim:
          claimName: nextcloud-html-pv-claim
          claimName: nextcloud-pv-claim
      - name: configs
        configMap:
nginx.yml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: nextcloud
spec:
  selector:
    matchLabels:
      app: nextcloud
      tier: frontend
  strategy:
    type: Recreate
  template:
    metadata:
      labels:
        app: nextcloud
        tier: frontend
    spec:
      containers:
      - image: docker.io/modzilla/nextcloud-nginx:latest
        ports:
        - containerPort: 80
        volumeMounts:
        - name: configs
        - name: configs
        - name: configs
        - name: configs
      volumes:
      - name: configs
        configMap:
onlyoffice.yml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: nextcloud
spec:
  selector:
    matchLabels:
      app: nextcloud
  strategy:
    type: Recreate
  template:
    metadata:
      labels:
        app: nextcloud
    spec:
      containers:
        ports:
        - containerPort: 80
        env:
          - name: JWT_ENABLED
            value: "true"
          - name: JWT_SECRET
            valueFrom:
              secretKeyRef:
                key: secret
          - name: JWT_HEADER
            valueFrom:
              secretKeyRef:
                key: header
Guess I’ll just might as well post my whole config then:
mariadb.yml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: nextcloud
spec:
  selector:
    matchLabels:
      app: nextcloud
      tier: mariadb-backend
  strategy:
    type: Recreate
  template:
    metadata:
      labels:
        app: nextcloud
    spec:
      containers:
      - image: docker.io/library/mariadb:10.5
        args:
        - "--transaction-isolation=READ-COMMITTED"
        - "--binlog-format=ROW"
        env:
        - name: MYSQL_ROOT_PASSWORD
          valueFrom:
            secretKeyRef:
              key: RootPassword
          valueFrom:
            secretKeyRef:
        - name: MYSQL_USER
          valueFrom:
            secretKeyRef:
              key: DatabaseUser
          valueFrom:
            secretKeyRef:
              key: DatabaseName
        ports:
        - containerPort: 3306
        volumeMounts:
        - name: mariadb-persistent-storage
          mountPath: /var/lib/mysql
      volumes:
          claimName: nextcloud-mariadb-pv-claim
services.yml
kind: List
items:
- apiVersion: v1
  kind: Service
  metadata:
    labels:
      app: nextcloud
  spec:
    ports:
      - name: http
        protocol: TCP
        port: 80
        targetPort: 80
    selector:
      app: nextcloud
      tier: frontend
    type: ClusterIP
- apiVersion: v1
  kind: Service
  metadata:
    labels:
      app: nextcloud
  spec:
    ports:
      - port: 9000
    selector:
      app: nextcloud
      tier: fpm-backend
    type: ClusterIP
- apiVersion: v1
  kind: Service
  metadata:
    labels:
      app: nextcloud
  spec:
    ports:
      - port: 3306
    selector:
      app: nextcloud
    type: ClusterIP
    clusterIP: None
- apiVersion: v1
  kind: Service
  metadata:
    labels:
      app: nextcloud
  spec:
    ports:
      - port: 6379
    selector:
      app: nextcloud
      tier: redis-backend
    type: ClusterIP
    clusterIP: None
- apiVersion: v1
  kind: Service
  metadata:
    labels:
      app: nextcloud
  spec:
    ports:
      - port: 80
    selector:
      app: nextcloud
    type: ClusterIP
Ingresses-traefik.yml
kind: IngressRoute
metadata:
  labels:
    app: nextcloud
    tier: frontend
spec:
  entryPoints:
  - websecure
  routes:
  - kind: Rule
    match: Host(`nextcloud.mydomain.com`)
    middlewares:
    - name: nextcloud-dav
    - name: nextcloud-headers
    services:
    - kind: Service
      port: 80
  tls:
    secretName: nextcloud-cert
kind: IngressRoute
metadata:
  labels:
    app: nextcloud
spec:
  entryPoints:
  - websecure
  routes:
  - kind: Rule
    middlewares:
    services:
    - kind: Service
      port: 80
  tls:
traefik-middleware.yml
kind: Middleware
metadata:
  labels:
    app: nextcloud
    tier: frontend
spec:
  replacePathRegex:
    regex: ^/.well-known/ca(l|rd)dav
    replacement: /remote.php/dav/
kind: Middleware
metadata:
  labels:
    app: nextcloud
    tier: frontend
spec:
  headers:
    accessControlAllowOriginList:
    stsPreload: true
kind: Middleware
metadata:
  labels:
    app: nextcloud
spec:
  headers:
    stsPreload: true
I hope this will help someone trying to get nextcloud running in kubernetes. I’ll eventually putt all files on github as well.
I don´t know what the issue around the header-value
took quite some wasted time :frowning:
wondering if this is my solution to get out of this endless Nextcloud 21 and OnlyOfficeDocumentServer pissing contest I’m currently in.
OnlyOfficeDocumentServer…
https://documentserver.mydomain.com/healthcheck = true
Nextcloud…
Error when trying to connect (Server error: `GET https://documentserver.mydomain.com/healthcheck` resulted in a `503 Service Temporarily Unavailable` response:
do i just add to NC config.php
    'jwt_secret' => 'mynewsecret',
    'jwt_header' => 'mynewheader',
also do i need to edit the template and add the variables to the docker image?
