Hi
I have an issue with nextcloud Talk that I can’t figure out how to solve.
Since Nextcloud Talk is available, I tried to use the app on iOS. However, it does not work when I use my noip.com domain (somethingsomething.ddns.net → wich is no-ip.com).
If I try to connect to it via my dns name, the error I receive is “Nextcloud not found”. However, the regular nextcloud app is fine with this and does work perfectly fine.
When I use the dynamic ip to connect with Nextcloud Talk iOS then it works (after adding the ip address to the allowed hosts list).
So far I tried:
- different (new) hostname on no-ip.com
- different ports (443 and custom ports)
- completely new install of nextcloud 21 in a new Ubuntu server VM - today.
always the same result. The ip adress works fine, the hostname in the regular app also fine - but the nextcloud talk app does just not work with the hostname.
Did I miss something in the configuration that I can try?
Any idea on this is very much appreciated
