Iāve been using a nextcloud box for a while now and am now happy to transfer to it completely.
Before I do, should I take the opportunity to upgrade from an RPI 2 to an RPI3?
If this is a good idea is there any means of retaining or transferring the data already stored?
Thanks for your help.
Robin
Sorry to hear youāre facing problems
If youāre urgently looking for support to keep your business running, consider checking out our paid support options.
In order to help you as quickly as possible, before clicking Create Topic please provide as much of the following as you can (you can cut and paste this into your topic):
Nextcloud version (eg, 10.0.2):
Operating system and version (eg, Ubuntu 16.04):
PHP version (eg, 5.6):
Is this the first time youāve seen this error?:
Can you reliably replicate it? (If so, please outline steps):
Remember, this information may be requested if it isnāt supplied; for fastest response please provide as much as you can Feel free to use a pastebin service, otherwise log files can be indented with 4 spaces on each line to present them in a friendlier way on the forum.
