I have two hosts with Noip
The ncp WUI wizzard opens a white area on the left side of the screen and it gives the following:
2 hosts are registered to this account.
Do you wish to have them all updated?[N] (y/N) Do you wish to have host [karma.ddns.me] updated?[N] (y/N) Do you wish to have host [sherab.ddns.net] updated?[N] (y/N) Nothing selected. Configuration file ‘/usr/local/etc/no-ip2.conf’ NOT created.
But it does not give me any way to actually update the host.
Any advice??
thank you
Running no-ip
Auto configuration for Linux client of no-ip.com.
Do you wish to have them all updated?[N] (y/N) (Do you wish to have host [karma.ddns.me] updated?[N] (y/N) yDo you wish to have host [sherab.ddns.net] updated?[N] (y/N) (
New configuration file '/usr/local/etc/no-ip2.conf' created.
Failed to enable unit: Unit /run/systemd/generator.late/noip2.service is transient or generated.
System config value trusted_domains => 3 set to string karma.ddns.net
System config value overwrite.cli.url set to string https://karma.ddns.net/
noip DDNS enabled
Done. Press any key...
