Please share!
Hello @nachoparker,
HDD monitoring is nice, but not working on odroid
i got only
/dev/sda: Unknown USB bridge [0x152d:0x0578 (0x105)]
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
is it possible to configure smartctl?
oh, sorry this issue is already known as issue #710 on github.
smartctl -d sat -a /dev/sda
is working fine, but I do not know how to configure /etc/smartd.conf
yes, I know man-pages.
but the config-file only consist out of examples for the command line.
I have to take a look.
big thanks to you!
I’ll try to take a look this weekend, or whenever I can get my hands on an Odroid
I have the same problem and can’t get my external hard drive (within an icybox IB-3620) running.
When I try to mount the hard drive with the Nextcloudpi wizard, everything works and is green. But in the Web panel System Info it only shows the 15 GB of the memory card and not the whole external storage.
The result of the short test is:
[ nc-hdd-test ]
/dev/sda: Unknown USB bridge [0x152d:0x0569 (0x106)]
Please specify device type with the -d option.Use smartctl -h to get a usage summary
- Starting test on sda. Check results later
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Self-test functions not supportedSending command: “Execute SMART Short self-test routine immediately in off-line >mode”.
Drive command “Execute SMART Short self-test routine immediately in off-line mode” >successful.
Testing has begun.
I also tried in the console the comand
smartctl -l selftest /dev/sda -d sat
But the message is the same.
My configuration:
Raspberry pi 3B
Nextcloudpi v.18.0
Nextcloud version 16.0.3.0
HDD: 4 TB WD Red
I appreciate any help
