I’m trying to install NextCloudPi on my RaspberryPi 3B. Everything worked until i had to set the DDNS up. I’ve created a NOIP account and added it to my Router (Speedport Smart 3).
But when i press the Finish Button i get an error:
[ no-ip ]
Auto configuration for Linux client of no-ip.com.
Only one host [pfaff. sytes. net] is registered to this account.
It will be used.
New configuration file ‘/usr/local/etc/no-ip2.conf’ created.
Failed to enable unit: Unit /run/systemd/generator.late/noip2.service is transient or generated.
System config value trusted_domains => 3 set to string pfaff. sytes. net
System config value overwrite.cli.url set to string https ://pfaff. sytes. net/
noip DDNS enabled
[ nc-autoupdate-ncp ]
automatic NextCloudPi updates enabled
[ dnsmasq ]
System config value trusted_domains => 2 set to string pfaff. sytes. net
dnsmasq enabled
[ letsencrypt ]
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for pfaff. sytes. net
Using the webroot path /var/www/nextcloud for all unmatched domains.
Waiting for verification…
Cleaning up challenges
Failed authorization procedure. pfaff. sytes. net (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://pfaff. sytes. net/. well-known/acme-challenge/KW4bYiMkzzMdOtzc9XBJqwBplC5Q8EAs7DrMQmYa7xc: Timeout during connect (likely firewall problem)
IMPORTANT NOTES:
The following errors were reported by the server:
Domain: pfaff. sytes. net
Type: connection
Detail: Fetching
https ://pfaff. sytes. net/. well-known/acme- challenge/KW4bYiMkzzMdOtzc9XBJqwBplC5Q8EAs7DrMQmYa7xc:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you’re using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
I had to change the Domain pfaff.sytes.net because there where to much links in my post. The spaces are not the problem.
Can somebody help me?
