NextCloudPi version v1.25.0
Nextcloud version :18.0.4
Operating system and version : Debian GNU/Linux 10
Apache or nginx version : Apache/2.4.38 (Debian)
PHP version _: 7.3.14
mysql version : 10.3.22
odroid H2 with
Prozessor: Intel® Celeron® J4105 CPU @ 1.50GHz (4 cores)
Speicher: 3.7 GB
I have an 2Gbit Connection to My Computer
I got an Raid with Read/Write Performance 140/120
Either CPU or Ram goes above 40% … while copy files
But still i don’t get more Then 70 Read/write with samba or direct via Nextcloud…
Any Idea where could be the Bottleneck?
My Computer could easy download with full gbit Speed from WWW
that’s not neccessarily a problem of nextcloud (could be though). could be a problem of your hardware, as well… have you checked out for general performance problems with it? maybe aunt google knows more?
How exactly do you bundle the two 1Gbit lines? Tried only with one as for 140, 1Gbit should be almost sufficient?
Also, a lot of normal routers can’t manage full Gbit even though they claim to have Gbit ports, which would fit to the 70 mb/s you are seeing. Same for a pfsense (single core routing only) firewall.
Last but not least, ethernet cables can make a big difference. Try Cat6.
