Nextcloud version :12.0.3 v0.31.5
Operating system and version : nextcloudpi image latest
Apache or nginx version :Apache/2.4.25
PHP version : PHP 7.0.19-1
Is this the first time you’ve seen this error?:
Yes
Can you reliably replicate it? (If so, please outline steps):
Yes, every time I login to web interface https://raspip:4443 it asks for credentials and it will stop asking when I write it 4 times
According to my testing, this was fixed in v0.31.2
Can you run sudo ncp-update
and retry?
I think I had the 0.31.1 now I have the 0.31.5 and it works normal. My mistake.
@nachoparker As I tried to log in today I had to put it 2 times , google chromium Version 61.0.3163.79 (Official Build) Built on Ubuntu , running on LinuxMint 18.2 (64-bit)
The permissions for password prompt have been rewritten. Please, update and try again, and report if it still acts up.
