NextCloudPi diagnostics
ping: none: Name or service not known
NextCloudPi version v0.34.15
NextCloudPi image NextCloudPi_11-12-17
distribution Raspbian GNU/Linux 9 \n \l
automount yes
USB devices sda
datadir /var/www/nextcloud/data
data in SD yes
data filesystem ext2/ext3
data disk usage 1.9G/2.7G
rootfs usage 1.9G/2.7G
Nextcloud check ok
Nextcloud version 12.0.3.3
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP 192.168.1.9
gateway 192.168.1.1
interface eth0
certificates none
certs due none
NAT loopback no
uptime 1min
</details>
<details>
<summary>Nextcloud configuration</summary>
“system”: {
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: {
“0”: “localhost”,
“1”: “192.168.1.9”,
“5”: “nextcloudpi.local”
“datadirectory”: “/var/www/nextcloud/data”,
“overwrite.cli.url”: “https://192.168.1.9”,
“dbtype”: “mysql”,
“version”: “12.0.3.3”,
“dbname”: “nextcloud”,
“dbhost”: “localhost”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“instanceid”: “oclqkkiqcr6y”,
“memcache.local”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “/var/run/redis/redis.sock”,
“port”: 0,
“timeout”: 0
“mail_smtpmode”: “php”,
“mail_smtpauthtype”: “LOGIN”,
“mail_from_address”: “admin”,
“mail_domain”: “ownyourbits.com”,
“overwriteprotocol”: “https”
</details>
<details>
<summary>HTTPd logs</summary>
[Sat Nov 18 14:51:22.241686 2017] [authz_host:error] [pid 860:tid 1934758960] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /loading-small.gif failed, reason: unable to get the remote host name
[Sat Nov 18 14:51:22.242590 2017] [authz_host:error] [pid 860:tid 1800541232] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /img/ncp-logo.svg failed, reason: unable to get the remote host name
[Sat Nov 18 14:51:22.243017 2017] [authz_host:error] [pid 860:tid 1783764016] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /ncp.js failed, reason: unable to get the remote host name
[Sat Nov 18 14:51:22.642571 2017] [authz_host:error] [pid 860:tid 1909593136] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /img/wizard.svg failed, reason: unable to get the remote host name, referer: https://nextcloudpi.local:4443/ncp.css
[Sat Nov 18 14:51:22.643257 2017] [authz_host:error] [pid 860:tid 1876038704] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /img/poweroff.svg failed, reason: unable to get the remote host name, referer: https://nextcloudpi.local:4443/ncp.css
[Sat Nov 18 14:51:22.647161 2017] [authz_host:error] [pid 860:tid 1850872880] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /info.svg failed, reason: unable to get the remote host name, referer: https://nextcloudpi.local:4443/ncp.css
[Sat Nov 18 14:51:22.682336 2017] [authz_host:error] [pid 860:tid 1842484272] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /ncp-output.php failed, reason: unable to get the remote host name
[Sat Nov 18 14:51:32.482208 2017] [authz_host:error] [pid 860:tid 1976702000] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sat Nov 18 14:51:32.504632 2017] [authz_host:error] [pid 860:tid 1892815920] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /red-circle.svg failed, reason: unable to get the remote host name, referer: https://nextcloudpi.local:4443/ncp.css
[Sat Nov 18 14:51:34.525219 2017] [authz_host:error] [pid 860:tid 1792152624] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sat Nov 18 14:51:39.281677 2017] [proxy_fcgi:error] [pid 860:tid 1792152624] [client 192.168.1.11:23805] AH01071: Got error ‘PHP message: PHP Notice: Undefined variable: params in /var/www/ncp-web/ncp-launcher.php on line 87\nPHP message: PHP Warning: Invalid argument supplied for foreach() in /var/www/ncp-web/ncp-launcher.php on line 87\n’
[Sat Nov 18 14:51:39.295659 2017] [authz_host:error] [pid 860:tid 1959924784] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /green-circle.svg failed, reason: unable to get the remote host name, referer: https://nextcloudpi.local:4443/ncp.css
[Sat Nov 18 14:51:52.440233 2017] [authz_host:error] [pid 860:tid 1808929840] [client 192.168.1.11:23805] AH01753: access check of ‘localhost’ to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sat Nov 18 14:51:54.649886 2017] [proxy_fcgi:error] [pid 860:tid 1842484272] [client 192.168.1.11:23805] AH01067: Failed to read FastCGI header
[Sat Nov 18 14:51:54.650070 2017] [proxy_fcgi:error] [pid 860:tid 1842484272] (104)Connection reset by peer: [client 192.168.1.11:23805] AH01075: Error dispatching request to :4443:
[Sat Nov 18 14:51:56.295782 2017] [mpm_event:notice] [pid 839:tid 1991962624] AH00491: caught SIGTERM, shutting down
[Sat Nov 18 14:52:07.145674 2017] [ssl:warn] [pid 583:tid 1992183808] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Sat Nov 18 14:52:08.042131 2017] [ssl:warn] [pid 865:tid 1992183808] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Sat Nov 18 14:52:09.005071 2017] [mpm_event:notice] [pid 865:tid 1992183808] AH00489: Apache/2.4.25 (Raspbian) OpenSSL/1.0.2l configured – resuming normal operations
[Sat Nov 18 14:52:09.005283 2017] [core:notice] [pid 865:tid 1992183808] AH00094: Command line: ‘/usr/sbin/apache2’
</details>
<details>
<summary>Database logs</summary>
2017-11-18 14:51:56 1978299200 [Note] /usr/sbin/mysqld: Shutdown complete
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Using mutexes to ref count buffer pool pages
2017-11-18 14:52:18 1989099520 [Note] InnoDB: The InnoDB memory heap is disabled
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2017-11-18 14:52:18 1989099520 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Compressed tables use zlib 1.2.8
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Using Linux native AIO
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Using generic crc32 instructions
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Initializing buffer pool, size = 128.0M
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Completed initialization of buffer pool
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Highest supported file format is Barracuda.
2017-11-18 14:52:18 1989099520 [Note] InnoDB: 128 rollback segment(s) are active.
2017-11-18 14:52:18 1989099520 [Note] InnoDB: Waiting for purge to start
2017-11-18 14:52:19 1989099520 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.35-80.0 started; log sequence number 4439289
2017-11-18 14:52:19 1447031616 [Note] InnoDB: Dumping buffer pool(s) not yet started
2017-11-18 14:52:19 1989099520 [Note] Plugin ‘FEEDBACK’ is disabled.
2017-11-18 14:52:19 1989099520 [Note] Server socket created on IP: ‘127.0.0.1’.
2017-11-18 14:52:19 1989099520 [Note] /usr/sbin/mysqld: ready for connections.
Version: ‘10.1.23-MariaDB-9+deb9u1’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 Raspbian 9.0
</details>
<details>
<summary>Nextcloud logs</summary>
{“reqId”:“WTSgmYsaiwa6dP0UWloB”,“level”:4,“time”:“2017-11-12T09:15:17+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Not installed”,“userAgent”:"–",“version”:""}
{“reqId”:“mOepx4OvoJnvEPG4ceyq”,“level”:4,“time”:“2017-11-12T09:30:14+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Not installed”,“userAgent”:"–",“version”:""}
{“reqId”:“iT0KOL06IWMgzQ45bQER”,“level”:4,“time”:“2017-11-12T09:45:12+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Not installed”,“userAgent”:"–",“version”:""}
{“reqId”:“usdnVNQgPTuyPts4i3xC”,“level”:4,“time”:“2017-11-12T10:00:18+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Not installed”,“userAgent”:"–",“version”:""}
{“reqId”:“C8f4UMPnsqYoygWQCZzW”,“level”:4,“time”:“2017-11-12T10:15:11+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Not installed”,“userAgent”:"–",“version”:""}
{“reqId”:“kV6EJNKVTueHrwFWYM6T”,“level”:4,“time”:“2017-11-12T10:30:12+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Not installed”,“userAgent”:"–",“version”:""}
{“reqId”:“i4ZUxeGKCem0ALWEojEo”,“level”:4,“time”:“2017-11-12T10:45:12+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"–",“url”:"–",“message”:“Not installed”,“userAgent”:"–",“version”:""}
{“reqId”:“Wg@TW38AAQEAAAM6yKIAAABF”,“level”:2,“time”:“2017-11-18T01:56:44+00:00”,“remoteAddr”:“192.168.1.11”,“user”:"–",“app”:“core”,“method”:“PROPFIND”,“url”:"/remote.php/webdav/",“message”:“Login failed: ‘robert’ (Remote IP: ‘192.168.1.11’)”,“userAgent”:“Mozilla/5.0 (Windows) mirall/2.3.3 (build 8250)”,“version”:“12.0.3.3”}
{“reqId”:“Wg@gmn8AAQEAAAM6yKUAAABK”,“level”:2,“time”:“2017-11-18T02:53:14+00:00”,“remoteAddr”:“174.138.61.43”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/",“message”:“Trusted domain error. “174.138.61.43” tried to access using “96.30.141.211” as host.”,“userAgent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36”,“version”:“12.0.3.3”}
{“reqId”:“Wg-agX8AAQEAAAM6yKoAAABT”,“level”:2,“time”:“2017-11-18T07:00:17+00:00”,“remoteAddr”:“46.101.139.248”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/",“message”:“Trusted domain error. “46.101.139.248” tried to access using “96.30.141.211” as host.”,“userAgent”:“Mozilla/5.0 (compatible; MSIE 10.0; Windows NT 6.1; Trident/6.0)”,“version”:“12.0.3.3”}
{“reqId”:“Wg-brn8AAQEAAAM6yLIAAABE”,“level”:2,“time”:“2017-11-18T07:05:18+00:00”,“remoteAddr”:“45.55.224.77”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/",“message”:“Trusted domain error. “45.55.224.77” tried to access using “96.30.141.211” as host.”,“userAgent”:“Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; InfoPath.2)”,“version”:“12.0.3.3”}
{“reqId”:“Wg-oA38AAQEAAAM6yLYAAABJ”,“level”:2,“time”:“2017-11-18T07:57:55+00:00”,“remoteAddr”:“54.67.67.222”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/",“message”:“Trusted domain error. “54.67.67.222” tried to access using “www.spierenburg.ca” as host.”,“userAgent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36”,“version”:“12.0.3.3”}
{“reqId”:“WhAYi38AAQEAAAM6yLwAAABQ”,“level”:2,“time”:“2017-11-18T11:24:59+00:00”,“remoteAddr”:“216.218.206.67”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/",“message”:“Trusted domain error. “216.218.206.67” tried to access using “96.30.141.211” as host.”,“userAgent”:"–",“version”:“12.0.3.3”}
{“reqId”:“WhA@1X8AAQEAAANcqdoAAA0D”,“level”:2,“time”:“2017-11-18T14:08:21+00:00”,“remoteAddr”:“192.168.1.11”,“user”:“admin”,“app”:“core”,“method”:“POST”,“url”:"/index.php/settings/users/users",“message”:“Login failed: ‘admin’ (Remote IP: ‘192.168.1.11’)”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/62.0.3202.94 Safari/537.36”,“version”:“12.0.3.3”}
</details>
