Did your retest throw up any answers?
didnât have time yet
I retested it⌠I also have DELETE before CREATE and it works perfectly fine
letâs see your partitions
lsblk -f
Curiouser and curiouser
pi@raspberrypi:~ $ lsblk -f
NAME FSTYPE LABEL UUID MOUNTPOINT
sda ext4 b2db1d72-06d7-4d4e-a159-f87f9a199506 /media/b2db1d72-06d7-4d4e-a159-f87mmcblk0
ââmmcblk0p1 vfat boot DF02-C322 /boot
ââmmcblk0p2 ext4 28590797-4810-4851-b4ec-bf9672c2918c /
is your external usb drive mounted?
Yeah
@raspberrypi:~ $ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 2736052 1995732 596652 77% /
devtmpfs 470176 0 470176 0% /dev
tmpfs 474784 0 474784 0% /dev/shm
tmpfs 474784 47932 426852 11% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 474784 0 474784 0% /sys/fs/cgroup
/dev/mmcblk0p1 42136 21472 20664 51% /boot
tmpfs 94956 0 94956 0% /run/user/1000
/dev/sda 3845579612 69632 3650142668 1% /media/b2db1d72-06d7-4d4e-a159-f87f9a199506
why are mmcblk0p1
and mmcblk0p1
hanging from sda? are you booting from hard drive instead of SDcard?
Iâve no idea. Everything is as default as it possibly could be. Booting from SD, the only configuration done with nextcloudpi-config
maybe itâs because there is no /dev/sda1
. If you donât have data in the drive, can you start by running nc-format-USB
? Then letâs see if you have the link after reboot.
nc-format-USB seems to dislike my drive!
Launching nc-format-USB /media/b2db1d72-06d7-4d4e-a159-f87f9a199506 is still mounted Done. Press any keyâŚ
are you in v0.31.5
Yeah (as of today I think)
Try disabling nc-automount
before running nc-format-USB
Ok all done. That did format it and set it to /dev/sda1 (although with only 1.7 TB available dude to the known bug). But still only 600 ish MB available in nextcloud. I shoved a few things on there and its basically a third full after a a video and a few photos.
In v0.31.5
the limitation of 2TB from nc-format-USB
was fixed. Did you format in that version?
There was a Nextcloud bug with the free space indication in the files app. Can you check with
df -h
Are your files in /media/USBdrive/ncdata/admin/files
sudo ls /media/USBdrive/ncdata/admin/files
My apologies, youâre right. Available space is correct now.
pi@raspberrypi:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 2.7G 2.3G 238M 91% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 13M 452M 3% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 21M 21M 51% /boot
tmpfs 93M 0 93M 0% /run/user/1000
/dev/sda1 3.6T 89M 3.4T 1% /media/myCloudDrive
They are in that location, except my mp4
pi@raspberrypi:~ $ sudo ls /media/USBdrive/ncdata/admin/files
Documents IMG_20171001_220656.jpg Nextcloud Manual.pdf Photos
IMG_20171001_220648.jpg IMG_20171001_220704.jpg Nextcloud.mp4
Do you think itâs worth try to fill the 350mb (ish) of space that nextcloud shows that I have free?
well, I think it just reports it badly because PHP 32bit, you can try to see what happens out of curiosity. Maybe it will report a negative number
Unfortunately that wasnât the case. It was syncing files (using desktop client) then stop with a âconnection refusedâ error.
Iâm not sure if thereâs a connection but none of the new files are present if I sudo ls /media/USBdrive/ncdata/admin/files
did you use nc-datadir
to move your files to the external hard drive?
Have you considered trying the setup wizard, and starting from zero?
https://<yourip>:4443/wizard
