I’m trying to get NextcloudPi install on my raspbi4 but I’m failing to login to the terminal, it says account is not available for pi nor ncp.
This is not the first time I install NextCloudPi on my raspberry using Etcher.
Any idea why this is happening?
PS: downloaded NextCloudPPi_RaspberryPi_v1.50.3.img from the official site.
Had the same issue, apparantly it doesn’t work that way. You have to access it / activate it with another computer over the LAN-IP of the Raspberry.
I was trying to login to enable SSH, not sure how to access it from another device if I don’t have SSH enabled.
Go to the browser on another device and put in the local IP-address of your RPi.
You can find out that IP address with your router, should be shown there.
I’m confused why terminal is inaccessible, hope to find some guidance.
