I have installed NextcloudPi on a Raspberry Pi 4. I added a public domain with freedns. Today in the morning I installed everything and it all worked fine. Also from outside my network. But now when I plug in my raspberry now I can only access nextcloud from my local network. Any attempts to access it from outside fail. I made sure that on my router the ports 80 and 443 still point to the raspberry. The freedns-domain still points to the public domain of my router (which is a public IP, no NAT there). Also pinging my public domain resolves the IP. What could be the issue here? I’m really out of ideas on how to fix this🤔
Furhtermore: within the local network all the requests get processed now considerably slower. On the settings page on port 4443 it says in the port-check section that the ports 80 and 443 are closed. Which is weird because it still works.
This could be the reason. When I try to locally connect with ssh pi@192.168.0.xxx it doesn’t work, whereas ssh pi@nextcloupi.local works. I get the same behaviour with HTTP(S). nextcloupi.local gets resolved to a IPv6 address.
Edit: Ok now I disabled IPv6 and I can now only access the pi via 192.168.0.xxx. But when trying to access it via my public IP or domain it still doesn’t work. HTTPS fails right away, HTTP gets a timeout after a while.
Hi Atmax,
Problem could be related to hairpinning of your router. In your local network try pointing your device (Computer, Phone, etc.) to your raspberry pi as your primary dns server, and then your usual one (probably your router) as the alternative dns. Hope this helps
I don’t thinkt that’s the issue. I found a “solution”. My raspberry crashes sometimes when I restart it and the router it all works fine again. Created a thread about it here: NexcloudPi not responding after being turned on for a while
