Hello everyone,
my NCP keeps setting itself into maintenance mode (“This Nextcloud instance is currently in maintenance mode, which may take a while.”). I can disable maintenance mode using SSH and “sudo ncp-config” and “nc-maintenance”. That works for some time, but after some hours/days my nextcloud instance stops working and goes offline/into maintenance mode again.
I ran nc-info, what resulted in the following:
pi@nextcloudpi:~ $ sudo ncp-config
Running nc-info
Gathering information...
Nextcloud is in maintenance mode - no apps have been loaded
NextCloudPi version v1.13.1
NextCloudPi image NextCloudPi_11-12-17
distribution Raspbian GNU/Linux 9 \n \l
automount no
USB devices sda
datadir /var/www/nextcloud/data
data in SD yes
data filesystem aufs
data disk usage 262G/344G
rootfs usage 262G/344G
swapfile /dev/zram3
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 15.0.5.3
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP 192.168.1.24
gateway 192.168.1.1
interface eth0
certificates *removed*
NAT loopback yes
uptime 17days
You should use nc-datadir to move your files to your plugged in USB drive
You should enable automount to use your plugged in USB drive
Done. Press any key...
Any idea what is going wrong here?
What other info do you need to help? @nachoparker
At the moment the NC is not in maintenance mode.
I tried to update to the newest NC version yesterday, that failed showing the following. Any ideas? Is that the same problem or a new one?
> Running nc-update-nextcloud
> Current Nextcloud version 15.0.5.3
> Available Nextcloud version 15.0.8
> Download Nextcloud 15.0.8...
> Back up current instance...
> check free space...
> Maintenance mode enabled
> backup database...
> backup files...
> pigz: abort: write error on <stdout> (No space left on device)
> tar: /var/www//nextcloud-bkp_20190605_1559767739.tar.gz: Wrote only 4096 of 1024 0 bytes
> tar: Child returned status 28
> tar: Error is not recoverable: exiting now
> error generating backup
> An unhandled exception has been thrown:
> RedisException: MISCONF Redis is configured to save RDB snapshots, but is curren tly not able to persist on disk. Commands that may modify the data set are disab led. Please check Redis logs for details about the error. in /var/www/nextcloud/ lib/private/Memcache/Redis.php:64
> Stack trace:
> #0 /var/www/nextcloud/lib/private/Memcache/Redis.php(64): Redis->setex('63cfcb48 d4d26c4...', 60, '["\\/var\\/www\\/n...')
> #1 /var/www/nextcloud/lib/autoloader.php(168): OC\Memcache\Redis->set('OC_User', Array, 60)
> #2 [internal function]: OC\Autoloader->load('OC_User')
> #3 /var/www/nextcloud/lib/private/User/Session.php(223): spl_autoload_call('OC_U ser')
> #4 /var/www/nextcloud/lib/private/L10N/Factory.php(168): OC\User\Session->getUse r()
> #5 /var/www/nextcloud/lib/private/L10N/Factory.php(127): OC\L10N\Factory->findLa nguage('lib')
> #6 /var/www/nextcloud/lib/private/Server.php(1499): OC\L10N\Factory->get('lib', NULL)
> #7 /var/www/nextcloud/lib/base.php(234): OC\Server->getL10N('lib')
> #8 /var/www/nextcloud/lib/base.php(659): OC::checkConfig()
> #9 /var/www/nextcloud/lib/base.php(1068): OC::init()
> #10 /var/www/nextcloud/console.php(46): require_once('/var/www/nextcl...')
> #11 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
> #12 {main}Abort...
> Maintenance mode disabled
> Error backing up
> Clean up...
Shouldnt be there plenty of room for a backup before the update?
How can I reduce the necessary backup space? @sven: The error on the image also appeared prior to the update through the web updater… Any idea how to fix it?
