The issue you are facing: NextCloudPi is offline/gone on RaspberryPi.
Yesterday, NCPi was working fine. Today, I noticed it wasnt responding.
I navigated to nextcloud URL and the login page was different. It had a login for NC and at the bottom for a database.
Now it doesn’t respond at all or rather didnt.
I googled a little bit and saw some commands recommended.
sudo apt-get install --reinstall apache2
Did that, now when I navigate to my public domain it shows: https://i.imgur.com/BEF4uxU.png
Why I ran that command? No idea. Tired and frustrated.
I have a feeling I made it worse by running that command and that my files are gone.
I have no idea what happened. Only thing I can think of is the power flickered 3 times yesterday, but I’m fairy certain the server is on a UPS. My PC for sure didnt go out.
Doesn't exist. Only "to" folder inside.
Is stock apache.
https://i.imgur.com/AB5U90R.png
