I’m having some issues with NextcloudPI running on an Odroid HC-2. There was a powerfailure a couple of days ago and my NextcloudPI instance crashed.
I’m trying to restore from a backup I have (no data).
Step 1 - Flash latest NextcloudPI img using Etcher
Step 2 - Run through initial NextcloudPi wizard
- Enable USB
- Move Data folder
- Enable Fail2Ban
- Forward Ports
Step 3 - Select NC-Restore from the web menu, copy the path to the backup (/media/myCloudDrive/Backups/nextcloud-bkp_20211115_1636945202.tar.gz) and run through the process.
At this point it starts to run through but I constantly get the following error:
[ nc-restore ] (Thu Nov 25 14:39:59 AST 2021)
check free space…
extracting backup file /media/myCloudDrive/Backups/nextcloud-bkp_20211115_1636945202.tar.gz…
restore files…
restore database…
No datadir found in backup
{“reqId”:“CoqB9E8MfNDifTwM94NJ”,“level”:2,“time”:“2021-11-25T18:48:42+00:00”,“remoteAddr”:"",“user”:"–",“app”:“no app in context”,“method”:"",“url”:"–",“message”:“Temporary directory /media/USBdrive/ncdata/tmp is not present or writable”,“userAgent”:"–",“version”:“21.0.4.1”}
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
{“reqId”:“CoqB9E8MfNDifTwM94NJ”,“level”:3,“time”:“2021-11-25T18:48:43+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:{“Exception”:“Error”,“Message”:“fopen(/media/USBdrive/ncdata/data_dir_writability_test_619fda8ba91f9.tmp): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/legacy/OC_Util.php#809”,“Code”:0,“Trace”:[{“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:"::",“args”:[2,“fopen(/media/USBdrive/ncdata/data_dir_writability_test_619fda8ba91f9.tmp): failed to open stream: Permission denied”,"/var/www/nextcloud/lib/private/legacy/OC_Util.php",809,{“config”:{“class”:“OC\SystemConfig”},“l”:{“class”:“OC\L10N\LazyL10N”},“errors”:[],“CONFIG_DATADIRECTORY”:"/media/USBdrive/ncdata",“webServerRestart”:false,“0”:“And 4 more entries, set log level to debug to see all entries”}]},{“file”:"/var/www/nextcloud/lib/private/legacy/OC_Util.php",“line”:809,“function”:“fopen”,“args”:["/media/USBdrive/ncdata/data_dir_writability_test_619fda8ba91f9.tmp",“w”]},{“file”:"/var/www/nextcloud/lib/private/Console/Application.php",“line”:161,“function”:“checkServer”,“class”:“OC_Util”,“type”:"::",“args”:[{“class”:“OC\SystemConfig”}]},{“file”:"/var/www/nextcloud/console.php",“line”:99,“function”:“loadCommands”,“class”:“OC\Console\Application”,“type”:"->",“args”:[{“class”:“Symfony\Component\Console\Input\ArgvInput”},{“class”:“Symfony\Component\Console\Output\ConsoleOutput”}]},{“file”:"/var/www/nextcloud/occ",“line”:11,“args”:["/var/www/nextcloud/console.php"],“function”:“require_once”}],“File”:"/var/www/nextcloud/lib/private/Log/ErrorHandler.php",“Line”:92,“CustomMessage”:"–"},“userAgent”:"–",“version”:“21.0.4.1”}
Your data directory is not writable
Permissions can usually be fixed by giving the webserver write access to the root directory. See https://docs.nextcloud.com/server/21/go.php?to=admin-dir_permissions.
Exception: Environment not properly prepared. in /var/www/nextcloud/lib/private/Console/Application.php:168
Stack trace:
#0 /var/www/nextcloud/console.php(99): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#1 /var/www/nextcloud/occ(11): require_once(’/var/www/nextcl…’)
#2 {main}{“reqId”:“CoqB9E8MfNDifTwM94NJ”,“level”:3,“time”:“2021-11-25T18:48:43+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“fopen(/media/USBdrive/ncdata/nextcloud.log): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/Log/File.php#85”,“userAgent”:"–",“version”:“21.0.4.1”}
Cleanup…
I have a hard time understanding the output, so I’m hoping some here can help me out.
Thanks
Robert
