I have set up the Nextcloud on the raspberry Pi 3+ according to this guide:
In itself, the whole thing is now also going on, but not as intended:
If I want to synchronize folders with Nextcloud software, it won’t happen over the home network. The data is “uploaded” for some reason, resulting in a synchronization speed of 0.2 MB/s (exactly the upload speed that my Internet connection has).
It would be great if the data would go directly from the computer via a lan cable to the router and then to the Nextcloudpi…
There’s probably just a wrong attitude somewhere but I don’t find this…
Does anyone have a suggestion?
Thank you in advance!! [Slow|690x59] (upload://zSRgBzyaib7ZZucQ6anZjz0mlSR.png) ! [proxy|690x271] - upload://8ttyPZBNqyvPLPQz6wqaHt6qgwo.png
If you want a direct communication inside your network make sure your Nextcloud Desktop Client has configured a local address.
There are multiple options:
Best Solution: Use a local DNS Resolver which manipulates your DNS Records (A-IPv4) for your local Servers. (Maybe PiHole can do this for you) - I am using Bind for such things, therefore there are also some helpful videos on youtube.
If IPv6 is available use it (only) for the dynDNS service so direct routing and NAT is no problem as each computer has its own routable address.
Temp Quick and Dirty-solutions:
Use the raspi-local IP like https://192.168.178.10 for your sync-clients.
Make sure it is the ip-access is allowed in your Nextcloud config.
It is usually located at /var/www/nextcloud/config/config.php
You can also manipulate your local.ddns.net domain in C:\Windows\System32\drivers\etc\hosts file --> disadvantage: mobile routing does not work with that setting, so you need to have an eye on it when you leave your network with your device.
