Clean installation process is a bit awkward, but simplified on Armbian. Curl script is integrated, but it takes 5 - 15 minutes, there is no easy way to uninstall the Curl installation, and Docker version only takes about 60 seconds to create via standard broadband.
- Docker Nextcloud version does not receive regular updates so it was not the latest version.
- Docker version of Nextcloud(Pi) can only be updated one full version at a time to avoid breakage.
- Version changes in ncp-web must be typed in manually, making it easy to mess up unless automatic updates are used.
- Docker version of ncp-web does not automatically define a
Trusted Domain
Also have this error in the logs after upgrade to NextcloudPi 18.0.4 stable from 18.0.3 and ncp 1.25 from 1.24
[core] Error: RedisException: NOAUTH Authentication required. at <>
- /data/nextcloud/lib/private/Memcache/Redis.php line 54
Redis->get(“9847577c3925ed1 … 4”) - /data/nextcloud/lib/private/App/InfoParser.php line 58
OC\Memcache\Redis->get("/data/nextcloud … 4") - /data/nextcloud/lib/private/App/AppManager.php line 511
OC\App\InfoParser->parse("/data/nextcloud … l") - /data/nextcloud/lib/private/legacy/app.php line 558
OC\App\AppManager->getAppInfo(“accessibility”, false, null) - /data/nextcloud/lib/private/AppFramework/App.php line 67
OC_App::getAppInfo(“accessibility”) - /data/nextcloud/lib/private/legacy/app.php line 241
OC\AppFramework\App::buildAppNamespace(“accessibility”) - /data/nextcloud/lib/private/legacy/app.php line 120
OC_App::registerAutoloading(“accessibility”, “/data/nextcloud/apps/accessibility”) - /data/nextcloud/lib/private/legacy/util.php line 197
OC_App::loadApps([“filesystem”]) - /data/nextcloud/lib/private/Files/Filesystem.php line 267
OC_Util::setupFS("") - /data/nextcloud/lib/private/Server.php line 320
OC\Files\Filesystem::getMountManager(null) - /data/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php line 118
OC\Server->OC{closure}("*** sensitive parameters replaced ***") - /data/nextcloud/lib/private/ServerContainer.php line 125
Pimple\Container->offsetGet(“RootFolder”) - /data/nextcloud/lib/private/Server.php line 342
OC\ServerContainer->query(“RootFolder”) - <>
OC\Server->OC{closure}("*** sensitive parameters replaced ***") - /data/nextcloud/lib/private/Files/Node/LazyRoot.php line 62
call_user_func(Closure {}) - /data/nextcloud/lib/private/Files/Node/LazyRoot.php line 142
OC\Files\Node\LazyRoot->__call(“get”, [“appdata_ocz3rx1zylbu/js/core”]) - /data/nextcloud/lib/private/Files/AppData/AppData.php line 143
OC\Files\Node\LazyRoot->get(“appdata_ocz3rx1zylbu/js/core”) - /data/nextcloud/lib/private/Template/JSCombiner.php line 96
OC\Files\AppData\AppData->getFolder(“core”) - /data/nextcloud/lib/private/Template/JSResourceLocator.php line 115
OC\Template\JSCombiner->process("/data/nextcloud", “core/js/merged-template-prepend.json”, “core”) - /data/nextcloud/lib/private/Template/JSResourceLocator.php line 71
OC\Template\JSResourceLocator->cacheAndAppendCombineJsonIfExist("/data/nextcloud", “core/js/merged-template-prepend.json”) - /data/nextcloud/lib/private/Template/ResourceLocator.php line 78
OC\Template\JSResourceLocator->doFind(“js/merged-template-prepend”) - /data/nextcloud/lib/private/TemplateLayout.php line 346
OC\Template\ResourceLocator->find(["core/js/dist/m … "]) - /data/nextcloud/lib/private/TemplateLayout.php line 174
OC\TemplateLayout::findJavascriptFiles(["core/js/dist/m … "]) - /data/nextcloud/lib/private/legacy/template.php line 184
OC\TemplateLayout->__construct(“error”, “”) - /data/nextcloud/lib/private/Template/Base.php line 132
OC_Template->fetchPage() - /data/nextcloud/lib/private/legacy/template.php line 333
OC\Template\Base->printPage() - /data/nextcloud/index.php line 65
OC_Template::printExceptionErrorPage(RedisException {}, 500)
GET /
from 192.168.1.149 at 2020-05-04T23:22:34+00:00
