NextcloudPi crashes every few weeks
hope this is the right place to post my issue and not the NextcloudPi Github.
Issue:
After installing nextcloud via NCP, everything works fine for a couple of days. After about 2 weeks nextcloud will stop working with some kind of server issue I’m not able to debug further. Last crashes were on 25th of February and 11th of March. But there were many before. Reboot does not help.
Only thing which I was able to do until now was restore a backup but that is not really a solution every 2 weeks.
I am not really sure what the problem is, as I don’t get any clue from the log files, except that it seams that Apache server is down. Unfortunately, I’m not an expert in this, so I’m quite lost at this point.
I am not sure why my issue happens. Might this be caused by hardware issue (no external power supply for hdd, SD card degradation) or is my usecase not the right one for a Nextcloud/RaspberryPi solution? Or is sth. else wrong (too much load for raspberry?)?
I would appreciate any help on further investigating this. As I would hate to stop running my Nextcloud instance because of this technical issues.
What I tried until now was play around with the nextcloudpi configuration to see if this could solve sth.
move database to usb-drive
nc-ramlogs - mount logs in RAM to prevent SD degradation (faster, consumes more RAM)
nc-swapfile Move and resize your swapfile. Recommended to move to a permanent USB drive
Hardware:
Raspberry Pi Model 3b
Original RaspberryPi Power Supply
External 2,5’’ Toshiba HDD connected (1.5TB) - connected without external power supply
Usecase:
I use nextcloudPi in a private family network. It is used for Calendar and Contact Sync via Caldav/Carddav and filesynchronization. I have 6 users.
1 Admin account (only for administration),
2 Accounts which only sync Calendar & Contacts (Phone via DavX5)
1 Accounts which uses Calendar (Thunderbird via Caldav) and Filesync via NextcloudClient (Ubuntu 18.04 LTS).
Rest of accounts is testing and dummy stuff until now.
The filesharing is done only done via the NextcloudClient with rare access via Webinterface What might be remarkable, is that the amount of data is quite high (about 680 GB - all personal data files) and contains all kind of data, which is also edited/executed (including some code files unfortunately) while NextcloudClient is active.
Any further hints required, feel free to ask.
I will post the nextcloudpi logs in the following post as we have limited amount of characters here.
BR Pedrito
Remark: I just cut the 2nd half of the details because of limited characters
<–! Paste this in GitHub report -->
NextCloudPi diagnostics
NextCloudPi version  v1.20.7
NextCloudPbage      678G/1.4T
rootfs usage         2.4G/14G
swapfile             /var/swap
dbdir                /var/lib/mysql
Nextcloud check      error
HTTPD service        up
PHP service          up
MariaDB service      up
Redis service        up
Postfix service      up
internet check       ok
port check 80        closed
port check 443       closed
IP                   ***REMOVED SENSITIVE VALUE***
gateway              ***REMOVED SENSITIVE VALUE***
interface            eth0
certificates         ***REMOVED SENSITIVE VALUE***
NAT loopback         no
uptime               14days
Nextcloud configuration
ParseError: syntax error, unexpected 'fun' (T_STRING), expecting function (T_FUNCTION) or const (T_CONST) in /var/www/nextcloud/lib/public/Files/Folder.php:75
Stack trace:
#0 /var/www/nextcloud/lib/composer/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/var/www/nextcl...')
#1 [internal function]: Composer\Autoload\ClassLoader->loadClass('OCP\\Files\\Folde...')
#2 /var/www/nextcloud/lib/public/Files/IRootFolder.php(35): spl_autoload_call('OCP\\Files\\Folde...')
#3 /var/www/nextcloud/lib/composer/composer/ClassLoader.php(444): include('/var/www/nextcl...')
#4 /var/www/nextcloud/lib/composer/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/var/www/nextcl...')
#5 [internal function]: Composer\Autoload\ClassLoader->loadClass('OCP\\Files\\IRoot...')
#6 /var/www/nextcloud/lib/private/Files/Node/LazyRoot.php(35): spl_autoload_call('OCP\\Files\\IRoot...')
#7 /var/www/nextcloud/lib/composer/composer/ClassLoader.php(444): include('/var/www/nextcl...')
#8 /var/www/nextcloud/lib/composer/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/var/www/nextcl...')
#9 [internal function]: Composer\Autoload\ClassLoader->loadClass('OC\\Files\\Node\\L...')
#10 /var/www/nextcloud/lib/private/Server.php(312): spl_autoload_call('OC\\Files\\Node\\L...')
#11 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server))
#12 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet('OCP\\Files\\IRoot...')
#13 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(161): OC\ServerContainer->query('OCP\\Files\\IRoot...')
#14 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#15 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet('LazyRootFolder')
#16 /var/www/nextcloud/lib/private/Server.php(1363): OC\ServerContainer->query('LazyRootFolder')
#17 /var/www/nextcloud/lib/private/Server.php(1098): OC\Server->getRootFolder()
#18 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server))
#19 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet('OC\\Files\\AppDat...')
#20 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(69): OC\ServerContainer->query('OC\\Files\\AppDat...', true)
#21 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(99): OC\AppFramework\Utility\SimpleContainer->buildClass(Object(ReflectionClass))
#22 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(114): OC\AppFramework\Utility\SimpleContainer->resolve('OC\\App\\AppStore...')
#23 /var/www/nextcloud/lib/private/ServerContainer.php(145): OC\AppFramework\Utility\SimpleContainer->query('OC\\App\\AppStore...', true)
#24 /var/www/nextcloud/lib/private/Server.php(1515): OC\ServerContainer->query('OC\\App\\AppStore...')
#25 /var/www/nextcloud/lib/private/Server.php(1154): OC\Server->getAppFetcher()
#26 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server))
#27 /var/www/nextcloud/lib/private/ServerContainer.php(120): Pimple\Container->offsetGet('OC\\Installer')
#28 /var/www/nextcloud/core/register_command.php(68): OC\ServerContainer->query('OC\\Installer')
#29 /var/www/nextcloud/lib/private/Console/Application.php(118): require_once('/var/www/nextcl...')
#30 /var/www/nextcloud/console.php(96): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#31 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#32 {main}
HTTPd logs
[Wed Mar 11 00:00:03.807164 2020] [ssl:warn] [pid 786:tid 1996165648] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Wed Mar 11 00:00:03.807516 2020] [ssl:error] [pid 786:tid 1996165648] AH02217: ssl_stapling_init_cert: can't retrieve issuer certificate! [subject: CN=archlinux / issuer: CN=archlinux / serial: 4D0D69071A363DCC66467D909ABB2563623E84FC / notbefore: Jul 21 02:33:51 2019 GMT / notafter: Jul 18 02:33:51 2029 GMT]
[Wed Mar 11 00:00:03.807533 2020] [ssl:error] [pid 786:tid 1996165648] AH02604: Unable to configure certificate localhost:4443:0 for stapling
[Wed Mar 11 00:00:03.809235 2020] [mpm_event:notice] [pid 786:tid 1996165648] AH00489: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1c configured -- resuming normal operations
[Wed Mar 11 00:00:03.809257 2020] [core:notice] [pid 786:tid 1996165648] AH00094: Command line: '/usr/sbin/apache2'
Database logs
Nextcloud logs
{"reqId":"NW8cPL8BTWDdlv607lyU","level":3,"time":"2020-03-11T11:15:02+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":{"Exception":"ParseError","Message":"syntax error, unexpected 'fun' (T_STRING), expecting function (T_FUNCTION) or const (T_CONST)","Code":0,"Trace":[{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":322,"function":"Composer\\Autoload\\includeFile","args":["\/var\/www\/nextcloud\/lib\/composer\/composer\/..\/..\/..\/lib\/public\/Files\/Folder.php"]},{"function":"loadClass","class":"Composer\\Autoload\\ClassLoader","type":"->","args":["OCP\\Files\\Folder"]},{"file":"\/var\/www\/nextcloud\/lib\/public\/Files\/IRootFolder.php","line":35,"function":"spl_autoload_call","args":["OCP\\Files\\Folder"]},{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":444,"args":["\/var\/www\/nextcloud\/lib\/public\/Files\/IRootFolder.php"],"function":"include"},{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":322,"function":"Composer\\Autoload\\includeFile","args":["\/var\/www\/nextcloud\/lib\/composer\/composer\/..\/..\/..\/lib\/public\/Files\/IRootFolder.php"]},{"function":"loadClass","class":"Composer\\Autoload\\ClassLoader","type":"->","args":["OCP\\Files\\IRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php","line":35,"function":"spl_autoload_call","args":["OCP\\Files\\IRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":444,"args":["\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php"],"function":"include"},{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":322,"function":"Composer\\Autoload\\includeFile","args":["\/var\/www\/nextcloud\/lib\/composer\/composer\/..\/..\/..\/lib\/private\/Files\/Node\/LazyRoot.php"]},{"function":"loadClass","class":"Composer\\Autoload\\ClassLoader","type":"->","args":["OC\\Files\\Node\\LazyRoot"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":312,"function":"spl_autoload_call","args":["OC\\Files\\Node\\LazyRoot"]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OCP\\Files\\IRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":161,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCP\\Files\\IRootFolder"]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":114,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["LazyRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":1363,"function":"query","class":"OC\\ServerContainer","type":"->","args":["LazyRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":1098,"function":"getRootFolder","class":"OC\\Server","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Files\\AppData\\Factory"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":69,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Files\\AppData\\Factory",true]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":99,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"name":"OC\\App\\AppStore\\Fetcher\\AppFetcher","__class__":"ReflectionClass"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":114,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\App\\AppStore\\Fetcher\\AppFetcher"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":145,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\App\\AppStore\\Fetcher\\AppFetcher",true]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":1515,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\App\\AppStore\\Fetcher\\AppFetcher"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":1154,"function":"getAppFetcher","class":"OC\\Server","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Installer"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/legacy\/util.php","line":739,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Installer"]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":653,"function":"checkServer","class":"OC_Util","type":"::","args":[{"__class__":"OC\\SystemConfig"}]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":1078,"function":"init","class":"OC","type":"::","args":[]},{"file":"\/var\/www\/nextcloud\/cron.php","line":41,"args":["\/var\/www\/nextcloud\/lib\/base.php"],"function":"require_once"}],"File":"\/var\/www\/nextcloud\/lib\/public\/Files\/Folder.php","Line":75,"CustomMessage":"--"},"userAgent":"--","version":"17.0.2.1"}
{"reqId":"NPQrVDdH2gOnLTT3025q","level":3,"time":"2020-03-11T11:30:02+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":{"Exception":"ParseError","Message":"syntax error, unexpected 'fun' (T_STRING), expecting function (T_FUNCTION) or const (T_CONST)","Code":0,"Trace":[{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":322,"function":"Composer\\Autoload\\includeFile","args":["\/var\/www\/nextcloud\/lib\/composer\/composer\/..\/..\/..\/lib\/public\/Files\/Folder.php"]},{"function":"loadClass","class":"Composer\\Autoload\\ClassLoader","type":"->","args":["OCP\\Files\\Folder"]},{"file":"\/var\/www\/nextcloud\/lib\/public\/Files\/IRootFolder.php","line":35,"function":"spl_autoload_call","args":["OCP\\Files\\Folder"]},{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":444,"args":["\/var\/www\/nextcloud\/lib\/public\/Files\/IRootFolder.php"],"function":"include"},{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":322,"function":"Composer\\Autoload\\includeFile","args":["\/var\/www\/nextcloud\/lib\/composer\/composer\/..\/..\/..\/lib\/public\/Files\/IRootFolder.php"]},{"function":"loadClass","class":"Composer\\Autoload\\ClassLoader","type":"->","args":["OCP\\Files\\IRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php","line":35,"function":"spl_autoload_call","args":["OCP\\Files\\IRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":444,"args":["\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php"],"function":"include"},{"file":"\/var\/www\/nextcloud\/lib\/composer\/composer\/ClassLoader.php","line":322,"function":"Composer\\Autoload\\includeFile","args":["\/var\/www\/nextcloud\/lib\/composer\/composer\/..\/..\/..\/lib\/private\/Files\/Node\/LazyRoot.php"]},{"function":"loadClass","class":"Composer\\Autoload\\ClassLoader","type":"->","args":["OC\\Files\\Node\\LazyRoot"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":312,"function":"spl_autoload_call","args":["OC\\Files\\Node\\LazyRoot"]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OCP\\Files\\IRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":161,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCP\\Files\\IRootFolder"]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":114,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["LazyRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":1363,"function":"query","class":"OC\\ServerContainer","type":"->","args":["LazyRootFolder"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":1098,"function":"getRootFolder","class":"OC\\Server","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Files\\AppData\\Factory"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":69,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Files\\AppData\\Factory",true]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility
And the log from the crash before
NextCloudPi image    NextCloudPi_07-21-19
distribution         Raspbian GNU/Linux 10 \n \l
automount            yes
USB devices          sda
datadir              /media/myCloudDrive/ncdata
data in SD           no
data filesystem      btrfs
data disk usage      678G/1.4T
rootfs usage         2.2G/14G
swapfile             /var/swap
dbdir                /media/USBdrive/ncdatabase
Nextcloud check      ok
Nextcloud version    17.0.2.1
HTTPD service        down
PHP service          up
MariaDB service      up
Redis service        up
Postfix service      up
internet check       ok
interface            eth0
NAT loopback         no
uptime               14days
        "trusted_domains": {
            "0": "localhost",
            "5": "nextcloudpi.local",
            "7": "nextcloudpi",
            "8": "nextcloudpi.lan",
            "11": "2a01:c23:8c26:7a00:ddda:3d67:be0b:c3da",
            "1": "192.168.178.9"
        "dbtype": "mysql",
        "version": "17.0.2.1",
        "overwrite.cli.url": "https:\/\/192.168.178.9\/",
        "dbport": "",
        "mysql.utf8mb4": true,
        "redis": {
            "port": 0,
            "timeout": 0,
        "tempdirectory": "\/media\/myCloudDrive\/ncdata\/tmp",
        "mail_smtpmode": "smtp",
        "preview_max_x": "2048",
        "preview_max_y": "2048",
        "jpeg_quality": "60",
        "overwriteprotocol": "https",
        "logfile": "\/media\/myCloudDrive\/ncdata\/nextcloud.log",
        "mail_sendmailmode": "smtp",
        "mail_smtpsecure": "tls",
        "mail_smtpauth": 1,
        "mail_smtpport": "587",
        "mail_smtpauthtype": "LOGIN",
        "loglevel": 2,
        "data-fingerprint": "afe9b0bd388cbddd03ef02cd61900c57"
HTTPd logs
Database logs
Nextcloud logs
{"reqId":"XkFfGRV0FFWQRDqZFI1CZgAAVQc","level":3,"time":"2020-02-10T13:48:09+00:00","remoteAddr":"192.168.178.24","user":"peter","app":"PHP","method":"PROPFIND","url":"\/remote.php\/dav\/files\/peter\/","message":"Error: Class 'OCA\\DAV\\Connector\\Sabre\\ExceptionLoggerPlugin' not found at \/var\/www\/nextcloud\/remote.php#57","userAgent":"Mozilla\/5.0 (Linux) mirall\/2.6.2git (Nextcloud)","version":"17.0.2.1"}
{"reqId":"XkFfNxV0FFWQRDqZFI1CZwAAWAc","level":3,"time":"2020-02-10T13:48:39+00:00","remoteAddr":"192.168.178.24","user":"peter","app":"PHP","method":"PROPFIND","url":"\/remote.php\/dav\/files\/peter\/","message":"Error: Class 'OCA\\DAV\\Connector\\Sabre\\ExceptionLoggerPlugin' not found at \/var\/www\/nextcloud\/remote.php#57","userAgent":"Mozilla\/5.0 (Linux) mirall\/2.6.2git (Nextcloud)","version":"17.0.2.1"}
{"reqId":"XkFfVYTGnoKmXtoFVwNPbwAAAgs","level":3,"time":"2020-02-10T13:49:09+00:00","remoteAddr":"192.168.178.24","user":"peter","app":"PHP","method":"PROPFIND","url":"\/remote.php\/dav\/files\/peter\/","message":"Error: Class 'OCA\\DAV\\Connector\\Sabre\\ExceptionLoggerPlugin' not found at \/var\/www\/nextcloud\/remote.php#57","userAgent":"Mozilla\/5.0 (Linux) mirall\/2.6.2git (Nextcloud)","version":"17.0.2.1"}
{"reqId":"XkFfcxV0FFWQRDqZFI1CaAAARgc","level":3,"time":"2020-02-10T13:49:39+00:00","remoteAddr":"192.168.178.24","user":"peter","app":"PHP","method":"PROPFIND","url":"\/remote.php\/dav\/files\/peter\/","message":"Error: Class 'OCA\\DAV\\Connector\\Sabre\\ExceptionLoggerPlugin' not found at \/var\/www\/nextcloud\/remote.php#57","userAgent":"Mozilla\/5.0 (Linux) mirall\/2.6.2git (Nextcloud)","version":"17.0.2.1"}
{"reqId":"XkFfkRV0FFWQRDqZFI1CaQAAQgc","level":3,"time":"2020-02-10T13:50:09+00:00","remoteAddr":"192.168.178.24","user":"peter","app":"PHP","method":"PROPFIND","url":"\/remote.php\/dav\/files\/peter\/","message":"Error: Class 'OCA\\DAV\\Connector\\Sabre\\ExceptionLoggerPlugin' not found at \/var\/www\/nextcloud\/remote.php#57","userAgent":"Mozilla\/5.0 (Linux) mirall\/2.6.2git (Nextcloud)","version":"17.0.2.1"}
{"reqId":"XkFgcRV0FFWQRDqZFI1CbwAAVBE","level":3,"time":"2020-02-10T13:53:55+00:00","remoteAddr":"192.168.178.24","user":"--","app":"index","method":"GET","url":"\/index.php\/csrftoken","message":{"Exception":"Doctrine\\DBAL\\Exception\\TableNotFoundException","Message":"An exception occurred while executing 'SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)' with params [\"local::\\\/media\\\/myCloudDrive\\\/ncdata\\\/\"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_storages' doesn't exist","Code":0,"Trace":[{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php","line":169,"function":"convertException","class":"Doctrine\\DBAL\\Driver\\AbstractMySQLDriver","type":"->","args":["An exception occurred while executing 'SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)' with params [\"local::\\\/media\\\/myCloudDrive\\\/ncdata\\\/\"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_storages' doesn't exist",{"errorInfo":["42S02",1146,"Table 'nextcloud.oc_storages' doesn't exist"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"}]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php","line":145,"function":"wrapException","class":"Doctrine\\DBAL\\DBALException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"},{"errorInfo":["42S02",1146,"Table 'nextcloud.oc_storages' doesn't exist"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"},"An exception occurred while executing 'SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)' with params [\"local::\\\/media\\\/myCloudDrive\\\/ncdata\\\/\"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_storages' doesn't exist"]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php","line":911,"function":"driverExceptionDuringQuery","class":"Doctrine\\DBAL\\DBALException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"},{"errorInfo":["42S02",1146,"Table 'nextcloud.oc_storages' doesn't exist"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"},"SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)",{"1":"local::\/media\/myCloudDrive\/ncdata\/"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/DB\/Connection.php","line":195,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)",["local::\/media\/myCloudDrive\/ncdata\/"],[2],null]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Query\/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (:dcValue1)",{"dcValue1":["local::\/media\/myCloudDrive\/ncdata\/"]},{"dcValue1":102}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/DB\/QueryBuilder\/QueryBuilder.php","line":214,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/StorageGlobal.php","line":60,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/StorageGlobal.php","line":72,"function":"loadForStorageIds","class":"OC\\Files\\Cache\\StorageGlobal","type":"->","args":[["local::\/media\/myCloudDrive\/ncdata\/"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Storage.php","line":95,"function":"getStorageInfo","class":"OC\\Files\\Cache\\StorageGlobal","type":"->","args":["local::\/media\/myCloudDrive\/ncdata\/"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Storage.php","line":73,"function":"getStorageById","class":"OC\\Files\\Cache\\Storage","type":"::","args":["local::\/media\/myCloudDrive\/ncdata\/"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Cache.php","line":108,"function":"__construct","class":"OC\\Files\\Cache\\Storage","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Storage\/Common.php","line":335,"function":"__construct","class":"OC\\Files\\Cache\\Cache","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/View.php","line":1326,"function":"getCache","class":"OC\\Files\\Storage\\Common","type":"->","args":["appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/View.php","line":1382,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"},"appdata_oclaqn5ofjmm\/js\/core","\/appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/Root.php","line":198,"function":"getFileInfo","class":"OC\\Files\\View","type":"->","args":["\/appdata_oclaqn5ofjmm\/js\/core"]},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["\/appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php","line":64,"function":"call_user_func_array","args":[[{"__class__":"OC\\Files\\Node\\Root"},"get"],["appdata_oclaqn5ofjmm\/js\/core"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php","line":141,"function":"__call","class":"OC\\Files\\Node\\LazyRoot","type":"->","args":["get",["appdata_oclaqn5ofjmm\/js\/core"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/AppData\/AppData.php","line":140,"function":"get","class":"OC\\Files\\Node\\LazyRoot","type":"->","args":["appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSCombiner.php","line":94,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSResourceLocator.php","line":114,"function":"process","class":"OC\\Template\\JSCombiner","type":"->","args":["\/var\/www\/nextcloud","core\/js\/merged-template-prepend.json","core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSResourceLocator.php","line":70,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\Template\\JSResourceLocator","type":"->","args":["\/var\/www\/nextcloud","core\/js\/merged-template-prepend.json"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->","args":["js\/merged-template-prepend"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/TemplateLayout.php","line":341,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->","args":[["core\/js\/dist\/main","js\/merged-template-prepend","search\/js\/search","core\/l10n\/de","search\/l10n\/de","search\/js\/searchprovider","js\/files\/fileinfo","js\/files\/client","js\/dist\/maintenance"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/TemplateLayout.php","line":169,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::","args":[["core\/js\/dist\/main","js\/merged-template-prepend","search\/js\/search","core\/l10n\/de","search\/l10n\/de","search\/js\/searchprovider","js\/files\/fileinfo","js\/files\/client","js\/dist\/maintenance"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/legacy\/template.php","line":183,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["guest",""]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":945,"function":"checkMaintenanceMode","class":"OC","type":"::","args":[]},{"file":"\/var\/www\/nextcloud\/index.php","line":42,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php","Line":42,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_storages' doesn't exist","Code":"42S02","Trace":[{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php","line":903,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/DB\/Connection.php","line":195,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)",["local::\/media\/myCloudDrive\/ncdata\/"],[2],null]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Query\/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (:dcValue1)",{"dcValue1":["local::\/media\/myCloudDrive\/ncdata\/"]},{"dcValue1":102}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/DB\/QueryBuilder\/QueryBuilder.php","line":214,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/StorageGlobal.php","line":60,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/StorageGlobal.php","line":72,"function":"loadForStorageIds","class":"OC\\Files\\Cache\\StorageGlobal","type":"->","args":[["local::\/media\/myCloudDrive\/ncdata\/"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Storage.php","line":95,"function":"getStorageInfo","class":"OC\\Files\\Cache\\StorageGlobal","type":"->","args":["local::\/media\/myCloudDrive\/ncdata\/"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Storage.php","line":73,"function":"getStorageById","class":"OC\\Files\\Cache\\Storage","type":"::","args":["local::\/media\/myCloudDrive\/ncdata\/"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Cache.php","line":108,"function":"__construct","class":"OC\\Files\\Cache\\Storage","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Storage\/Common.php","line":335,"function":"__construct","class":"OC\\Files\\Cache\\Cache","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/View.php","line":1326,"function":"getCache","class":"OC\\Files\\Storage\\Common","type":"->","args":["appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/View.php","line":1382,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"},"appdata_oclaqn5ofjmm\/js\/core","\/appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/Root.php","line":198,"function":"getFileInfo","class":"OC\\Files\\View","type":"->","args":["\/appdata_oclaqn5ofjmm\/js\/core"]},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["\/appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php","line":64,"function":"call_user_func_array","args":[[{"__class__":"OC\\Files\\Node\\Root"},"get"],["appdata_oclaqn5ofjmm\/js\/core"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php","line":141,"function":"__call","class":"OC\\Files\\Node\\LazyRoot","type":"->","args":["get",["appdata_oclaqn5ofjmm\/js\/core"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/AppData\/AppData.php","line":140,"function":"get","class":"OC\\Files\\Node\\LazyRoot","type":"->","args":["appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSCombiner.php","line":94,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSResourceLocator.php","line":114,"function":"process","class":"OC\\Template\\JSCombiner","type":"->","args":["\/var\/www\/nextcloud","core\/js\/merged-template-prepend.json","core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSResourceLocator.php","line":70,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\Template\\JSResourceLocator","type":"->","args":["\/var\/www\/nextcloud","core\/js\/merged-template-prepend.json"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->","args":["js\/merged-template-prepend"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/TemplateLayout.php","line":341,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->","args":[["core\/js\/dist\/main","js\/merged-template-prepend","search\/js\/search","core\/l10n\/de","search\/l10n\/de","search\/js\/searchprovider","js\/files\/fileinfo","js\/files\/client","js\/dist\/maintenance"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/TemplateLayout.php","line":169,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::","args":[["core\/js\/dist\/main","js\/merged-template-prepend","search\/js\/search","core\/l10n\/de","search\/l10n\/de","search\/js\/searchprovider","js\/files\/fileinfo","js\/files\/client","js\/dist\/maintenance"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/legacy\/template.php","line":183,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["guest",""]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":945,"function":"checkMaintenanceMode","class":"OC","type":"::","args":[]},{"file":"\/var\/www\/nextcloud\/index.php","line":42,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php","Line":119,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_storages' doesn't exist","Code":"42S02","Trace":[{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php","line":117,"function":"execute","class":"PDOStatement","type":"->","args":[null]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php","line":903,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/DB\/Connection.php","line":195,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)",["local::\/media\/myCloudDrive\/ncdata\/"],[2],null]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Query\/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (:dcValue1)",{"dcValue1":["local::\/media\/myCloudDrive\/ncdata\/"]},{"dcValue1":102}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/DB\/QueryBuilder\/QueryBuilder.php","line":214,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/StorageGlobal.php","line":60,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/StorageGlobal.php","line":72,"function":"loadForStorageIds","class":"OC\\Files\\Cache\\StorageGlobal","type":"->","args":[["local::\/media\/myCloudDrive\/ncdata\/"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Storage.php","line":95,"function":"getStorageInfo","class":"OC\\Files\\Cache\\StorageGlobal","type":"->","args":["local::\/media\/myCloudDrive\/ncdata\/"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Storage.php","line":73,"function":"getStorageById","class":"OC\\Files\\Cache\\Storage","type":"::","args":["local::\/media\/myCloudDrive\/ncdata\/"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Cache.php","line":108,"function":"__construct","class":"OC\\Files\\Cache\\Storage","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Storage\/Common.php","line":335,"function":"__construct","class":"OC\\Files\\Cache\\Cache","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/View.php","line":1326,"function":"getCache","class":"OC\\Files\\Storage\\Common","type":"->","args":["appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/View.php","line":1382,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"},"appdata_oclaqn5ofjmm\/js\/core","\/appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/Root.php","line":198,"function":"getFileInfo","class":"OC\\Files\\View","type":"->","args":["\/appdata_oclaqn5ofjmm\/js\/core"]},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["\/appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php","line":64,"function":"call_user_func_array","args":[[{"__class__":"OC\\Files\\Node\\Root"},"get"],["appdata_oclaqn5ofjmm\/js\/core"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Node\/LazyRoot.php","line":141,"function":"__call","class":"OC\\Files\\Node\\LazyRoot","type":"->","args":["get",["appdata_oclaqn5ofjmm\/js\/core"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/AppData\/AppData.php","line":140,"function":"get","class":"OC\\Files\\Node\\LazyRoot","type":"->","args":["appdata_oclaqn5ofjmm\/js\/core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSCombiner.php","line":94,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSResourceLocator.php","line":114,"function":"process","class":"OC\\Template\\JSCombiner","type":"->","args":["\/var\/www\/nextcloud","core\/js\/merged-template-prepend.json","core"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/JSResourceLocator.php","line":70,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\Template\\JSResourceLocator","type":"->","args":["\/var\/www\/nextcloud","core\/js\/merged-template-prepend.json"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->","args":["js\/merged-template-prepend"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/TemplateLayout.php","line":341,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->","args":[["core\/js\/dist\/main","js\/merged-template-prepend","search\/js\/search","core\/l10n\/de","search\/l10n\/de","search\/js\/searchprovider","js\/files\/fileinfo","js\/files\/client","js\/dist\/maintenance"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/TemplateLayout.php","line":169,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::","args":[["core\/js\/dist\/main","js\/merged-template-prepend","search\/js\/search","core\/l10n\/de","search\/l10n\/de","search\/js\/searchprovider","js\/files\/fileinfo","js\/files\/client","js\/dist\/maintenance"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/legacy\/template.php","line":183,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["guest",""]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Template\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":945,"function":"checkMaintenanceMode","class":"OC","type":"::","args":[]},{"file":"\/var\/www\/nextcloud\/index.php","line":42,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOStatement.php","Line":117}},"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:72.0) Gecko\/20100101 Firefox\/72.0","version":"17.0.2.1"}
{"reqId":"XkFgcRV0FFWQRDqZFI1CbwAAVBE","level":3,"time":"2020-02-10T13:53:55+00:00","remoteAddr":"192.168.178.24","user":"--","app":"core","method":"GET","url":"\/index.php\/csrftoken","message":{"Exception":"Doctrine\\DBAL\\Exception\\TableNotFoundException","Message":"An exception occurred while executing 'SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)' with params [\"local::\\\/media\\\/myCloudDrive\\\/ncdata\\\/\"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_storages' doesn't exist","Code":0,"Trace":[{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php","line":169,"function":"convertException","class":"Doctrine\\DBAL\\Driver\\AbstractMySQLDriver","type":"->","args":["An exception occurred while executing 'SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)' with params [\"local::\\\/media\\\/myCloudDrive\\\/ncdata\\\/\"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_storages' doesn't exist",{"errorInfo":["42S02",1146,"Table 'nextcloud.oc_storages' doesn't exist"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"}]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php","line":145,"function":"wrapException","class":"Doctrine\\DBAL\\DBALException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"},{"errorInfo":["42S02",1146,"Table 'nextcloud.oc_storages' doesn't exist"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"},"An exception occurred while executing 'SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)' with params [\"local::\\\/media\\\/myCloudDrive\\\/ncdata\\\/\"]:\n\nSQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_storages' doesn't exist"]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php","line":911,"function":"driverExceptionDuringQuery","class":"Doctrine\\DBAL\\DBALException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"},{"errorInfo":["42S02",1146,"Table 'nextcloud.oc_storages' doesn't exist"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"},"SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)",{"1":"local::\/media\/myCloudDrive\/ncdata\/"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/DB\/Connection.php","line":195,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (?)",["local::\/media\/myCloudDrive\/ncdata\/"],[2],null]},{"file":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Query\/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` IN (:dcValue1)",{"dcValue1":["local::\/media\/myCloudDrive\/ncdata\/"]},{"dcValue1":102}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/DB\/QueryBuilder\/QueryBuilder.php","line":214,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/StorageGlobal.php","line":60,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/StorageGlobal.php","line":72,"function":"loadForStorageIds","class":"OC\\Files\\Cache\\StorageGlobal","type":"->","args":[["local::\/media\/myCloudDrive\/ncdata\/"]]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Storage.php","line":95,"function":"getStorageInfo","class":"OC\\Files\\Cache\\StorageGlobal","type":"->","args":["local::\/media\/myCloudDrive\/ncdata\/"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Storage.php","line":73,"function":"getStorageById","class":"OC\\Files\\Cache\\Storage","type":"::","args":["local::\/media\/myCloudDrive\/ncdata\/"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Cache\/Cache.php","line":108,"function":"__construct","class":"OC\\Files\\Cache\\Storage","type":"->","args":[{"__class__":"OC\\Files\\Storage\\Local"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Files\/Storage
Whatever issues I had running software of RasPI - Kodi, FreePBX, Linux, etc. - always were power supply related…
Thanks for the hint.
I’ll try to connect the HDD via an external USB hub then and report if this solves it. But I guess I can’t do anything else about it as I already have the raspi connected via the official power supply.
And if I get you right, you had the power supply related issues even without external devices, right?
Correct.
And most of the time it didn’t last for 2 weeks (like in your case) between reboots.
The best experience I had when plugging the adapter into a APC UPS.
That was the time I run FreePBX on it… It run for months… Switched to a NUC later on…
I don’t think RasPI is in the 24/7 hardware class.
Just a hint for the ones who have issues after me. Just one more hint that henry’s comment is correct.
As I hadn’t any different hardware available (yet) I tried to run my use case without Filesync which ran fine until today (~5-6 weeks) but right now crashed again. So reduced load seams just lead to less cpu/ram/storage activity, but doesn’t solve this.
