A first installation of Nextcloupi went well, however, a new one had to happen, but that’s where the problem comes in. I am a novice on linux.
The image of Nextcloupi (last dated) was installed successfully on a micro-sd card with Win32Diskimager. I have a box allowing me to connect a ssd m-SATA formatted in FAT32.
Once arrived in the menu of nextcloudpi-config, via SSH, I make an nc-format-USB (for m-SATA SSD). And here is the error message:
Launching nc-format-USB / dev / sda: 8 bytes were erased at offset 0x00000200 (gpt): 45 46 49 20 50 41 52 54 / dev / sda: 8 bytes were erased at offset 0x3a38b2d600 (gpt): 45 46 49 20 50 41 52 54 / dev / sda: 2 bytes were erased at offset 0x000001fe (PMBR): 55 aa
The process is very long, before mentioning “Done, press any key”.
Thinking that everything works, I activate nc-automount, then nc-datadir.
All finished, I start the sincronization of a 2go file (size of m-SATA is 250gb).
Finally, an error occurs in the synchronization software. On the Nextcloud web interface, it says 153mb (the whole space is used), which is not possible given the size of the SSD.
I tried several times, but each time the same error message.
Hope you can help me.
Eric
