Hey everyone,
I just started my own NextcloudPi using @nachoparker fabulous image. It works fine, but due to my routers not-supporting of NAT loopback I had to use dnsmasq to configure the Pi as DNS server. I followed the steps given on this website (link) and it works fine on Windows after configuring it accordingly.
But for some reason my android device doesn’t get a proper connection to the NextcloudPi, even after giving it at static IP and configuring the Pi as primary DNS server for it.
Opening the domain of the NextcloudPi in the android browser doesn’t load the login site properly (other websites are working fine).
In the app file changes (made in Windows) are being displayed but downloading files and uploading images results in “Connection error”.
If I’m using other peoples wifi or mobile data, syncing both ways works fine…
Anyone else having the same problem or knows how to solve this?
What I noticed is that if I use the dig command in the Pi, it doesn’t show the IP adress that the Pi is supposed to have but 127.0.0.1 instead. But if I dig my own domain it’s showing the right IP adress (192.168.1.24) for it… Is there a configuration error?
Either way - if I point the the DNS server of my android device to 127.0.0.1 it still does not upload/download files correctly (even not after reboot)…
pi@nextcloudpi:~ $ dig foursquare.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> foursquare.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 10861
;; flags: qr rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;foursquare.com. IN A
;; ANSWER SECTION:
foursquare.com. 23 IN A 151.101.64.154
foursquare.com. 23 IN A 151.101.0.154
foursquare.com. 23 IN A 151.101.128.154
foursquare.com. 23 IN A 151.101.192.154
;; Query time: 0 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Fri Dec 01 11:14:26 UTC 2017
;; MSG SIZE rcvd: 107
pi@nextcloudpi:~ $ dig <<hidden>>.ddns.net
; <<>> DiG 9.10.3-P4-Raspbian <<>> <<hidden>>.ddns.net
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 11326
;; flags: qr aa rd ra ad; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
` <<hidden>>.ddns.net IN A`
;; ANSWER SECTION:
<<hidden>>.ddns.net. 0 IN A 192.168.1.24
;; WHEN: Fri Dec 01 11:19:47 UTC 2017
;; MSG SIZE rcvd: 50
Edit: I had to set up the Pi completly new (I managed to crash it when moving data to a malfunctioning harddrive)
and am now having also trouble to connect properly to the nextcloud through windows (application and browser)… Through a VPN the connection is okay, but still kind of unstable…
For now I have a work-around:
I installed the Nextcloud dev application parallel to the normal app on my smartphone, but put in my IP adress instead of my domain. Like this it works fine, uploading and syncing without a problem.
I also logged into the windows app with a second instance using the IP adress and paused the domain-linked-sync in the program.
Like this I can use the IP-adress-based instances when I am at home and the domain-based-instances when I’m out of the house.
Still this is far from ideal. If anyone finds out, how to make sure that dnsmasq is working correctly, that would help a lot!
pi@nextcloudpi:~ $ systemctl status dnsmasq
â—Ź dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2017-12-07 10:53:05 UTC; 4 days ago
Main PID: 4441 (dnsmasq)
CGroup: /system.slice/dnsmasq.service
└─4441 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -7 /etc/dnsmasq.d,.dpkg-dist,.dpkg-old,.dpkg-new --local-service
Dec 07 10:53:05 nextcloudpi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Dec 07 10:53:05 nextcloudpi dnsmasq[4433]: dnsmasq: syntax check OK.
Dec 07 10:53:05 nextcloudpi dnsmasq[4441]: started, version 2.76 cachesize 150
Dec 07 10:53:05 nextcloudpi dnsmasq[4441]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Dec 07 10:53:05 nextcloudpi dnsmasq[4441]: DNS service limited to local subnets
Dec 07 10:53:05 nextcloudpi dnsmasq[4441]: using nameserver 8.8.4.4#53
Dec 07 10:53:05 nextcloudpi dnsmasq[4441]: read /etc/hosts - 5 addresses
Dec 07 10:53:05 nextcloudpi dnsmasq[4442]: Too few arguments.
Dec 07 10:53:05 nextcloudpi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Then see if there’s an alternative to dig for Android. There has to be. It should be a matter of pointing your DNS to the pi, it’s really no more complicated that that.
I found out how to use dig command in windows. Its included in BIND which anyone else with the same problem can find here: https://www.isc.org/downloads/.
When trying to dig a domain at first it only showed results where the secondary DNS server (8.8.8.8) was active. So I opened up the NextcloudPiPanel an re-ran dnsmasq. Now its working both in Windows and Android!
systemctl status dnsmasq shows the following:
Active: active (running) since Tue 2017-12-12 12:39:29 UTC; 1h 24min ago
Process: 5607 ExecStop=/etc/init.d/dnsmasq systemd-stop-resolvconf (code=exited, status=0/SUCCESS)
Process: 5663 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code=exited, status=0/SUCCESS)
Process: 5656 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS)
Process: 5653 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
Main PID: 5662 (dnsmasq)
└─5662 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -7 /etc/dnsmasq.d,.dpkg-dist,.dpkg-old,.dpkg-new --local-service
Dec 12 12:39:29 nextcloudpi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Dec 12 12:39:29 nextcloudpi dnsmasq[5653]: dnsmasq: syntax check OK.
Dec 12 12:39:29 nextcloudpi dnsmasq[5662]: started, version 2.76 cachesize 150
Dec 12 12:39:29 nextcloudpi dnsmasq[5662]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Dec 12 12:39:29 nextcloudpi dnsmasq[5662]: DNS service limited to local subnets
Dec 12 12:39:29 nextcloudpi dnsmasq[5662]: using nameserver 8.8.4.4#53
Dec 12 12:39:29 nextcloudpi dnsmasq[5662]: read /etc/hosts - 5 addresses
Dec 12 12:39:29 nextcloudpi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
My browser still needs longer opening the domain of the Pi than the IP-address. I don’t know why (maybe some kind of cache). But for now I’m happy! Thanks everyone!
It depends on the size of the data you need to sync as the speed of files transfer is very slow if you connect to WiFi , it will makes the connection fail or the Android transfer fail.
For me, I’d like to sync my files to my PC with transfer app, which enables me to transfer data between phone and PC via USB or wifi. All the phone contents can be transferred and without data loss.
