sudo ncp-report:
<–! Paste this in GitHub report -->
NextCloudPi diagnostics
NextCloudPi version v0.62.2
NextCloudPi image NextCloudPi_10-02-18
distribution Raspbian GNU/Linux 9 \n \l
automount yes
USB devices sda
datadir /var/www/nextcloud/data
data in SD yes
data filesystem ext2/ext3
data disk usage 2.1G/29G
rootfs usage 2.1G/29G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 14.0.1.1
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP ***REMOVED SENSITIVE VALUE***
gateway ***REMOVED SENSITIVE VALUE***
interface eth0
certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
uptime 4min
Nextcloud configuration
"trusted_domains": {
"0": "localhost",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"1": "192.168.178.122"
"dbtype": "mysql",
"version": "14.0.1.1",
"overwrite.cli.url": "http:\/\/localhost\/",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"mail_smtpmode": "sendmail",
"mail_smtpauthtype": "LOGIN",
"overwriteprotocol": "https"
HTTPd logs
[Wed Oct 03 06:47:02.299579 2018] [proxy_fcgi:error] [pid 871:tid 1691411488] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: ini_s et(): A session is active. You cannot change the session module's ini settings a t this time in /var/www/ncp-web/index.php on line 41\nPHP message: PHP Warning: ini_set(): A session is active. You cannot change the session module's ini sett ings at this time in /var/www/ncp-web/index.php on line 43\nPHP message: PHP War ning: fopen(ncp-web.cfg): failed to open stream: No such file or directory in / var/www/ncp-web/L10N.php on line 145\nPHP message: PHP Warning: fopen(ncp-web.c fg): failed to open stream: No such file or directory in /var/www/ncp-web/L10N.p hp on line 145\nPHP message: NACHO auto\n - auto\nPHP message: NACHO en\n - auto \nPHP message: NACHO de\n - auto\nPHP message: NACHO es\n - auto\nPHP message: N ACHO zh\n - auto\n'
[Wed Oct 03 06:47:03.430184 2018] [proxy_fcgi:error] [pid 871:tid 1708213280] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: touch (): Utime failed: Permission denied in /var/www/ncp-web/ncp-output.php on line 8 1\n'
[Wed Oct 03 06:47:07.878573 2018] [proxy_fcgi:error] [pid 871:tid 1683010592] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:47:19.670622 2018] [proxy_fcgi:error] [pid 871:tid 1683010592] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:47:23.668819 2018] [proxy_fcgi:error] [pid 871:tid 1683010592] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:47:57.081526 2018] [proxy_fcgi:error] [pid 871:tid 1683010592] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:47:59.097577 2018] [proxy_fcgi:error] [pid 871:tid 1683010592] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:49:08.448349 2018] [proxy_fcgi:error] [pid 871:tid 1683010592] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: ini_s et(): A session is active. You cannot change the session module's ini settings a t this time in /var/www/ncp-web/index.php on line 41\nPHP message: PHP Warning: ini_set(): A session is active. You cannot change the session module's ini sett ings at this time in /var/www/ncp-web/index.php on line 43\nPHP message: PHP War ning: fopen(ncp-web.cfg): failed to open stream: No such file or directory in / var/www/ncp-web/L10N.php on line 145\nPHP message: PHP Warning: fopen(ncp-web.c fg): failed to open stream: No such file or directory in /var/www/ncp-web/L10N.p hp on line 145\nPHP message: NACHO auto\n - auto\nPHP message: NACHO en\n - auto \nPHP message: NACHO de\n - auto\nPHP message: NACHO es\n - auto\nPHP message: N ACHO zh\n - auto\n'
[Wed Oct 03 06:49:09.563338 2018] [proxy_fcgi:error] [pid 871:tid 1716614176] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: touch (): Utime failed: Permission denied in /var/www/ncp-web/ncp-output.php on line 8 1\n'
[Wed Oct 03 06:49:13.971835 2018] [proxy_fcgi:error] [pid 871:tid 1708213280] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:49:16.273467 2018] [proxy_fcgi:error] [pid 871:tid 1708213280] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:49:16.340457 2018] [proxy_fcgi:error] [pid 871:tid 1691411488] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: ini_s et(): A session is active. You cannot change the session module's ini settings a t this time in /var/www/ncp-web/index.php on line 41\nPHP message: PHP Warning: ini_set(): A session is active. You cannot change the session module's ini sett ings at this time in /var/www/ncp-web/index.php on line 43\nPHP message: PHP War ning: fopen(ncp-web.cfg): failed to open stream: No such file or directory in / var/www/ncp-web/L10N.php on line 145\nPHP message: PHP Warning: fopen(ncp-web.c fg): failed to open stream: No such file or directory in /var/www/ncp-web/L10N.p hp on line 145\nPHP message: NACHO auto\n - auto\nPHP message: NACHO en\n - auto \nPHP message: NACHO de\n - auto\nPHP message: NACHO es\n - auto\nPHP message: N ACHO zh\n - auto\n'
[Wed Oct 03 06:49:17.300135 2018] [proxy_fcgi:error] [pid 871:tid 1683010592] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: touch (): Utime failed: Permission denied in /var/www/ncp-web/ncp-output.php on line 8 1\n'
[Wed Oct 03 06:49:21.196162 2018] [proxy_fcgi:error] [pid 871:tid 1691411488] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:49:23.421344 2018] [proxy_fcgi:error] [pid 871:tid 1691411488] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:49:27.216484 2018] [proxy_fcgi:error] [pid 871:tid 1691411488] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: ini_s et(): A session is active. You cannot change the session module's ini settings a t this time in /var/www/ncp-web/wizard/index.php on line 21\nPHP message: PHP Wa rning: ini_set(): A session is active. You cannot change the session module's i ni settings at this time in /var/www/ncp-web/wizard/index.php on line 23\n'
[Wed Oct 03 06:49:28.392806 2018] [proxy_fcgi:error] [pid 871:tid 1683010592] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: touch (): Utime failed: Permission denied in /var/www/ncp-web/ncp-output.php on line 8 1\n'
[Wed Oct 03 06:49:37.706371 2018] [proxy_fcgi:error] [pid 871:tid 1691411488] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:49:43.132379 2018] [proxy_fcgi:error] [pid 871:tid 1691411488] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
[Wed Oct 03 06:49:47.902577 2018] [proxy_fcgi:error] [pid 871:tid 1691411488] [c lient 192.168.178.54:52160] AH01071: Got error 'PHP message: PHP Warning: fopen (ncp-web.cfg): failed to open stream: No such file or directory in /var/www/ncp- web/L10N.php on line 145\n'
Database logs
2018-10-03 4:46:38 1954333488 [Note] /usr/sbin/mysqld: Shutdown complete
2018-10-03 6:47:20 1995579376 [Note] InnoDB: Using mutexes to ref count buffer pool pages
2018-10-03 6:47:20 1995579376 [Note] InnoDB: The InnoDB memory heap is disabled
2018-10-03 6:47:20 1995579376 [Note] InnoDB: Mutexes and rw_locks use GCC atomi c builtins
2018-10-03 6:47:20 1995579376 [Note] InnoDB: GCC builtin __atomic_thread_fence( ) is used for memory barrier
2018-10-03 6:47:20 1995579376 [Note] InnoDB: Compressed tables use zlib 1.2.8
2018-10-03 6:47:20 1995579376 [Note] InnoDB: Using Linux native AIO
2018-10-03 6:47:20 1995579376 [Note] InnoDB: Using generic crc32 instructions
2018-10-03 6:47:20 1995579376 [Note] InnoDB: Initializing buffer pool, size = 1 28.0M
2018-10-03 6:47:20 1995579376 [Note] InnoDB: Completed initialization of buffer pool
2018-10-03 6:47:20 1995579376 [Note] InnoDB: Highest supported file format is B arracuda.
2018-10-03 6:47:22 1995579376 [Note] InnoDB: 128 rollback segment(s) are active .
2018-10-03 6:47:22 1995579376 [Note] InnoDB: Waiting for purge to start
2018-10-03 6:47:22 1995579376 [Note] InnoDB: Percona XtraDB (http://www.percon a.com) 5.6.35-80.0 started; log sequence number 3495113
2018-10-03 6:47:31 1417671472 [Note] InnoDB: Dumping buffer pool(s) not yet sta rted
2018-10-03 6:47:31 1995579376 [Note] Plugin 'FEEDBACK' is disabled.
2018-10-03 6:47:31 1995579376 [Note] Server socket created on IP: '127.0.0.1'.
2018-10-03 6:47:31 1995579376 [Note] /usr/sbin/mysqld: ready for connections.
Version: '10.1.23-MariaDB-9+deb9u1' socket: '/var/run/mysqld/mysqld.sock' port : 3306 Raspbian 9.0
Nextcloud logs
{"reqId":"6MBqeXepbvdKlFetHA20","level":3,"time":"2018-10-02T01:30:02+00:00","re moteAddr":"","user":"--","app":"cron","method":"","url":"--","message":{"Excepti on":"Exception","Message":"Not installed","Code":0,"Trace":[{"file":"\/var\/www\ /nextcloud\/lib\/base.php","line":660,"function":"checkInstalled","class":"OC"," type":"::","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":1068 ,"function":"init","class":"OC","type":"::","args":[]},{"file":"\/var\/www\/next cloud\/cron.php","line":41,"args":["\/var\/www\/nextcloud\/lib\/base.php"],"func tion":"require_once"}],"File":"\/var\/www\/nextcloud\/lib\/base.php","Line":277, "CustomMessage":"--"},"userAgent":"--","version":""}
lsblk -f
NAME FSTYPE LABEL UUID MOUNTPOINT
sda
-sda1 btrfs myCloudDrive 187db4fc-b42c-49d3-aca2-155c5d8e89bb mmcblk0 |-mmcblk0p1 vfat boot 3725-1C05 /boot
-mmcblk0p2 ext4 rootfs fd695ef5-f047-44bd-b159-2a78c53af20a /
thanks.
