NextCloudAIO updater fails if not run regularly. Is there a way to recover?
So I ran the updater through AIO, no warnings that this was a bad idea, but now all I get is errr messages about PHP 8.3 being wrong. I tried the recovery method listed here: all-in-one/manual-upgrade.md at main · nextcloud/all-in-one · GitHub and did get it to work for about 3 minutes, but when I restarted the containers, everything failed again.
I was hoping that AIO would simplify the process of keeping NextCloud up to date. The Host server gets updated every 2 weeks and is running Lubuntu.
  • Nextcloud Server version (e.g., 29.x.x): AIO 10.0.0 The actual nextcloud version ??? I can’t get it, that’s why I’m here
    Docker
    latest docker version
    don’t know
    8.3 => this appears to be the problem
    Yes
    Tried to use the AIO updater. Apparently this doesn’t work unless you run it daily
  • Installation method (e.g. AIO, NCP, Bare Metal/Archive, etc.)
    AIO
  • Are you using Cloudflare, mod_security, or similar? (Yes / No)
    No
Ran the AIO updater, broke everything. Nextcloud container doesn’t start gives error about PHP8.3 being the wrong version.
  1. install docker version of NextCloud
  2. Don’t update for a few months
  3. Try to update
  4. profit?
2024-12-04T02:07:44.505708927Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:07:46.553742920Z               now
2024-12-04T02:07:46.553788504Z -------------------------------
2024-12-04T02:07:46.553796990Z  2024-12-03 20:07:46.552797-06
2024-12-04T02:07:46.553803218Z (1 row)
2024-12-04T02:07:46.553808401Z
2024-12-04T02:07:46.678307813Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:07:46.678926535Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:07:46.679992789Z + '[' -n '' ']'
2024-12-04T02:07:46.680031205Z + set +x
2024-12-04T02:07:46.695101641Z Enabling Imagick...
2024-12-04T02:07:48.138428001Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/main: No such file or directory
2024-12-04T02:07:48.138462577Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/community: No such file or directory
2024-12-04T02:07:48.175520063Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:07:48.435261904Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:07:48.435306002Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:07:48.435311845Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:07:48.435318975Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:07:53.540704348Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:07:55.569108068Z               now
2024-12-04T02:07:55.569189307Z -------------------------------
2024-12-04T02:07:55.569197712Z  2024-12-03 20:07:55.568287-06
2024-12-04T02:07:55.569204638Z (1 row)
2024-12-04T02:07:55.569210995Z
2024-12-04T02:07:55.579427251Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:07:55.579820149Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:07:55.580495067Z + '[' -n '' ']'
2024-12-04T02:07:55.580513907Z + set +x
2024-12-04T02:07:55.598796137Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:07:55.873341584Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:07:55.873372195Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:07:55.873404381Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:07:55.873409117Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:07:58.451996324Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:08:00.479464651Z               now
2024-12-04T02:08:00.479521426Z -------------------------------
2024-12-04T02:08:00.479526556Z  2024-12-03 20:08:00.478733-06
2024-12-04T02:08:00.479530161Z (1 row)
2024-12-04T02:08:00.479533514Z
2024-12-04T02:08:00.488259130Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:08:00.488683969Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:08:00.489500372Z + '[' -n '' ']'
2024-12-04T02:08:00.489520361Z + set +x
2024-12-04T02:08:00.509103679Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:08:00.736906568Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:08:00.736972543Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:08:00.736990995Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:08:00.737009993Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:08:03.060084115Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:08:05.085874048Z               now
2024-12-04T02:08:05.085911439Z -------------------------------
2024-12-04T02:08:05.085919872Z  2024-12-03 20:08:05.085181-06
2024-12-04T02:08:05.085923914Z (1 row)
2024-12-04T02:08:05.085927373Z
2024-12-04T02:08:05.093524088Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:08:05.093897935Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:08:05.094607930Z + '[' -n '' ']'
2024-12-04T02:08:05.094631994Z + set +x
2024-12-04T02:08:05.114605077Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:08:05.342669173Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:08:05.342751465Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:08:05.342769451Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:08:05.342795047Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:08:07.606905812Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:08:09.632955573Z               now
2024-12-04T02:08:09.632995957Z -------------------------------
2024-12-04T02:08:09.633000397Z  2024-12-03 20:08:09.632246-06
2024-12-04T02:08:09.633004153Z (1 row)
2024-12-04T02:08:09.633007665Z
2024-12-04T02:08:09.640897645Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:08:09.641235118Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:08:09.641919310Z + '[' -n '' ']'
2024-12-04T02:08:09.641944926Z + set +x
2024-12-04T02:08:09.661572891Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:08:09.890232389Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:08:09.890321638Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:08:09.890328224Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:08:09.890335426Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:08:12.482691328Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:08:14.514099557Z               now
2024-12-04T02:08:14.514137992Z -------------------------------
2024-12-04T02:08:14.514143904Z  2024-12-03 20:08:14.513382-06
2024-12-04T02:08:14.514148704Z (1 row)
2024-12-04T02:08:14.514153244Z
2024-12-04T02:08:14.522702517Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:08:14.523009914Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:08:14.523723842Z + '[' -n '' ']'
2024-12-04T02:08:14.523737904Z + set +x
2024-12-04T02:08:14.543252212Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:08:14.784050899Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:08:14.784148116Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:08:14.784168691Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:08:14.784180720Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:08:18.962571383Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:08:20.992464376Z               now
2024-12-04T02:08:20.992508001Z -------------------------------
2024-12-04T02:08:20.992513553Z  2024-12-03 20:08:20.991736-06
2024-12-04T02:08:20.992518225Z (1 row)
2024-12-04T02:08:20.992522774Z
2024-12-04T02:08:21.001358962Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:08:21.001969320Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:08:21.002982981Z + '[' -n '' ']'
2024-12-04T02:08:21.003002276Z + set +x
2024-12-04T02:08:21.023518270Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:08:21.263906061Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:08:21.263992077Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:08:21.264000646Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:08:21.264008505Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:08:28.701187692Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:08:30.730607241Z              now
2024-12-04T02:08:30.730651554Z ------------------------------
2024-12-04T02:08:30.730660166Z  2024-12-03 20:08:30.72989-06
2024-12-04T02:08:30.730667718Z (1 row)
2024-12-04T02:08:30.730672479Z
2024-12-04T02:08:30.738883111Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:08:30.739349465Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:08:30.740199297Z + '[' -n '' ']'
2024-12-04T02:08:30.740220203Z + set +x
2024-12-04T02:08:30.760564043Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:08:30.995562380Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:08:30.995624809Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:08:30.995641713Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:08:30.995649006Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:08:44.804998309Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:08:46.834813873Z               now
2024-12-04T02:08:46.834859630Z -------------------------------
2024-12-04T02:08:46.834868903Z  2024-12-03 20:08:46.834028-06
2024-12-04T02:08:46.834876550Z (1 row)
2024-12-04T02:08:46.834884235Z
2024-12-04T02:08:46.843138917Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:08:46.843754326Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:08:46.844814774Z + '[' -n '' ']'
2024-12-04T02:08:46.844840722Z + set +x
2024-12-04T02:08:46.865218624Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:08:47.104167308Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:08:47.104225005Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:08:47.104237257Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:08:47.104251345Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:09:13.728802313Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:09:15.758993580Z               now
2024-12-04T02:09:15.759042225Z -------------------------------
2024-12-04T02:09:15.759052532Z  2024-12-03 20:09:15.758247-06
2024-12-04T02:09:15.759060126Z (1 row)
2024-12-04T02:09:15.759067452Z
2024-12-04T02:09:15.767811023Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:09:15.768156879Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:09:15.769022995Z + '[' -n '' ']'
2024-12-04T02:09:15.769044253Z + set +x
2024-12-04T02:09:15.789406018Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:09:16.034325777Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:09:16.034358762Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:09:16.034383995Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:09:16.034396088Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:10:08.226364924Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:10:10.256953971Z               now
2024-12-04T02:10:10.257002027Z -------------------------------
2024-12-04T02:10:10.257007643Z  2024-12-03 20:10:10.256208-06
2024-12-04T02:10:10.257012342Z (1 row)
2024-12-04T02:10:10.257016805Z
2024-12-04T02:10:10.265370837Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:10:10.265722297Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:10:10.266498189Z + '[' -n '' ']'
2024-12-04T02:10:10.266521028Z + set +x
2024-12-04T02:10:10.286478865Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:10:10.521156240Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:10:10.521229070Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:10:10.521246876Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:10:10.521256693Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:11:11.466584238Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:11:13.497486625Z               now
2024-12-04T02:11:13.497531792Z -------------------------------
2024-12-04T02:11:13.497537334Z  2024-12-03 20:11:13.496738-06
2024-12-04T02:11:13.497541925Z (1 row)
2024-12-04T02:11:13.497546289Z
2024-12-04T02:11:13.505654275Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:11:13.506125704Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:11:13.507008650Z + '[' -n '' ']'
2024-12-04T02:11:13.507025844Z + set +x
2024-12-04T02:11:13.527007195Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:11:13.754947365Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:11:13.754999983Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:11:13.755004604Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:11:13.755009451Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:12:14.745484118Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:12:16.776170686Z               now
2024-12-04T02:12:16.776217361Z -------------------------------
2024-12-04T02:12:16.776226491Z  2024-12-03 20:12:16.775442-06
2024-12-04T02:12:16.776235057Z (1 row)
2024-12-04T02:12:16.776242986Z
2024-12-04T02:12:16.784887748Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:12:16.785212349Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:12:16.786124845Z + '[' -n '' ']'
2024-12-04T02:12:16.786148588Z + set +x
2024-12-04T02:12:16.807147535Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:12:17.039336774Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:12:17.039401582Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:12:17.039430584Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:12:17.039446541Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
2024-12-04T02:13:18.253264438Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-12-04T02:13:20.283976879Z               now
2024-12-04T02:13:20.284021626Z -------------------------------
2024-12-04T02:13:20.284027328Z  2024-12-03 20:13:20.283201-06
2024-12-04T02:13:20.284031326Z (1 row)
2024-12-04T02:13:20.284035119Z
2024-12-04T02:13:20.291702889Z + '[' -f /dev-dri-group-was-added ']'
2024-12-04T02:13:20.292234815Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-12-04T02:13:20.293263544Z + '[' -n '' ']'
2024-12-04T02:13:20.293292498Z + set +x
2024-12-04T02:13:20.313687253Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-12-04T02:13:20.555342617Z This version of Nextcloud is not compatible with PHP>=8.3.<br/>You are currently running 8.3.13.It seems like your installed Nextcloud is not compatible with the by the container provided PHP version.
2024-12-04T02:13:20.555405151Z This most likely happened because you tried to restore an old Nextcloud version from backup that is not compatible with the PHP version that comes with the container.
2024-12-04T02:13:20.555413645Z Please try to restore a more recent backup which contains a Nextcloud version that is compatible with the PHP version that comes with the container.
2024-12-04T02:13:20.555420576Z If you do not have a more recent backup, feel free to have a look at this documentation: https://github.com/nextcloud/all-in-one/blob/main/manual-upgrade.md
PASTE
  'one-click-instance' => true,
  'one-click-instance.user-limit' => 100,
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
   'check_data_directory_permissions' => false,
  'redis' =>
    'host' => 'nextcloud-aio-redis',
    'password' => 'password',
    'port' => 6379,
  'overwritehost' => 'domain.com',
  'passwordsalt' => 'password',
  'secret' => 'secret_password',
    0 => 'localhost',
    1 => 'domain.com',
  'datadirectory' => '/mnt/ncdata',
  'dbtype' => 'pgsql',
 'version' => '27.1.7.2',
  'overwrite.cli.url' => 'https://domain.com/',
  'dbname' => 'nextcloud_database',
  'dbhost' => 'nextcloud-aio-database',
  'dbuser' => 'oc_nextcloud',
  'dbpassword' => 'password',
  'instanceid' => 'octblzw52s74',
  'loglevel' => '2',
  'log_type' => 'file',
  'logfile' => '/var/www/html/data/nextcloud.log',
  'log_rotate_size' => '10485760',
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'preview_max_x' => '2048',
  'preview_max_y' => '2048',
  'jpeg_quality' => '60',
  'enabledPreviewProviders' =>
    1 => 'OC\\Preview\\Image',
    2 => 'OC\\Preview\\MarkDown',
    3 => 'OC\\Preview\\MP3',
    4 => 'OC\\Preview\\TXT',
    5 => 'OC\\Preview\\OpenDocument',
    6 => 'OC\\Preview\\Movie',
    7 => 'OC\\Preview\\Krita',
    0 => 'OC\\Preview\\Imaginary',
  'enable_previews' => true,
  'mail_smtpmode' => 'smtp',
  'versions_retention_obligation' => 'auto, 30',
  'activity_expire_days' => '30',
  'share_folder' => '/Shared',
  'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
  'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
  'updatedirectory' => '/nc-updater',
  'davstorage.request_timeout' => 3600,
  'dbpersistent' => false,
  'files_external_allow_create_new_local' => false,
  'trusted_proxies' =>
    0 => '127.0.0.1',
    1 => '::1',
  'allow_local_remote_servers' => true,
  'preview_imaginary_url' => 'http://nextcloud-aio-imaginary:9000',
  'appsallowlist' => false,
(END)
The output of occ app:list (if possible). no idea how to get this. Should probably have better instructions for us noobs.
Don’t really have any apps installed or running.
This is how to recover
