I am new and i took a few houers arround to check, if there is a posting simmular to mine.
And sorry für my english, I tried my best, I am from germany.
I had an owncloud for two years (and the same problem), and now I installed a new and fresh nextcloud.
It works fine and I am inpressed of the funktions, great.
But I habe this problem: When uploading many files or folders (I tryed 30 files and 2 folders with a few subfolders), uploading is crashing after 5-8 files. I got an error-message an I am logged out.
Yesterday I installed the same system on my small V-Server, and there it workes fine, I think, it must be a problem with the IONOS-Space. (My V-Server hat not enough space to serve the cloud for a long time).
I can not find the problem.
A few infos about the system:
Nextcloud-Version: - actuell 18.0.4.2
Operating system: Linux (Linux info 3.0 #1337 SMP Tue Jan 01 00:00:00 CEST 2000 all GNU/Linux)
MySQL-Version: 5.7.28-log
PHP-Version: 7.4.5
'instanceid' => 'xxxx',
'passwordsalt' => 'xxxx',
'secret' => 'xxxx//FSQ7dA/rf58S',
0 => 'cloud.mex-berlin.de',
'datadirectory' => '/homepages/38/d78627184/htdocs/nextcloud/data',
'version' => '18.0.4.2',
'overwrite.cli.url' => 'https://cloud.mex-berlin.de',
'dbname' => 'xxxx',
'dbhost' => 'xxxx',
'dbuser' => 'xxxx',
'dbpassword' => 'xxxx.9',
'mail_from_address' => 'noreply',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'mex-berlin.de',
'mail_smtphost' => 'smtp.1und1.de',
'mail_smtpport' => '465',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtpname' => 'noreply@mex-berlin.de',
'mail_smtppassword' => 'xxxx',
Thanx and greetings from berlin
Patrick
