i have Nextcloud running with the following docker-compose.yml file and i use Plesk with nginx as reverse proxy.
My problem is, that the images are accessible without a login.
I can open a image with the following url https://nc.mydomain.com/core/preview?fileId=30&x=2880&y=1800&a=true
I tried the nginx directives from the Nextcloud docker-compose example on Github.
Problem here is it does not work, because i have to use proxy_pass http://127.0.0.1:8080/;
Can someone help, to prevent accessing the images without the login?
- make the nginx settings work with proxy_pass, but how.
version: '3'
services:
db:
image: mariadb:10.5
container_name: nextcloud-mariadb
restart: always
environment:
- MARIADB_AUTO_UPGRADE=1
- MARIADB_DISABLE_UPGRADE_BACKUP=1
env_file:
- db.env
volumes:
- volumes/mariadb:/var/lib/mysql
redis:
image: redis:alpine
container_name: nextcloud-redis
restart: always
command: /bin/sh -c "redis-server --requirepass $$REDIS_HOST_PASSWORD"
env_file:
- redis.env
app:
image: nextcloud:apache
container_name: nextcloud-app
restart: always
ports:
- 127.0.0.1:8080:80
volumes:
- volumes/nextcloud:/var/www/html
depends_on:
- db
- redis
environment:
- MYSQL_HOST=db
- REDIS_HOST=redis
- NEXTCLOUD_TRUSTED_DOMAINS=nc.mydomain.com
env_file:
- db.env
- redis.env
cron:
container_name: nextcloud-cron
restart: always
volumes:
entrypoint: /cron.sh
depends_on:
- db
- redis
volumes:
db:
nextcloud:
“Additional nginx directives” in the Plesk settings for the Nextcloud Subdomain.
location / {
proxy_set_header Host $host;
proxy_read_timeout 36000s;
#Only use secure connection
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload";
#Allow big files to upload
client_max_body_size 0;
location /.well-known/carddav {
location /.well-known/caldav {
