nextcloud 20.0.4 (hosted)
linux
apache server 2.4.46
php 7.4.9
mysql 10.3.27-MariaDB
Files will not sync on nextcloud. When I try I get this error message:
Synchronized with local folder (date)
an error occurred while opening a folder. network access is disabled
Is this the first time you’ve seen this error? Y:
- try to sync files
- try again
- click account settings
- read error message
- join forum
6 hope someone can help
nextcloud log:
Error PHP Error: Cannot modify header information - headers already sent by (output started at /home/myname/public_html/3rdparty/sabre/http/lib/Sapi.php:132) at /home/myname/public_html/apps/dav/lib/Connector/Sabre/File.php#691 2021-01-07T12:30:55-0500
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 2005507 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 540641 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. 2021-01-07T12:30:55-0500
Fatal webdav Doctrine\DBAL\Exception\DeadlockException: An exception occurred while executing 'UPDATE `oc_file_locks` SET `lock` = `lock` + 1, `ttl` = ? WHERE `key` = ? AND `lock` >= 0' with params [1609867126, "files\/4eaa1948e1bcaafcceb4082f2c8cc901"]: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction 2021-01-05T10:18:46-0500
config.php:
?php
'instanceid' => 'o',
'passwordsalt' => '',
'secret' => '',
0 => 'myname.myusa.cloud',
'datadirectory' => '/home/myname/nextclouddata',
'version' => '20.0.4.0',
'overwrite.cli.url' => 'http://myname.myusa.cloud',
'dbname' => 'myname_next362',
'dbhost' => 'localhost',
'dbuser' => 'myname_next362',
'dbpassword' => 'W',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtpname' => 'myname@gmail.com',
'mail_smtppassword' => '',
'mail_smtpport' => '465',
