If you’re urgently looking for support to keep your business running, consider checking out our paid support options.
In order to help you as quickly as possible, before clicking Create Topic please provide as much of the following as you can (you can cut and paste this into your topic):
After updating i get the error “Internal server error”
Erro Interno do Servidor
O servidor encontrou um erro interno e não conseguiu concluir o seu pedido.
Entra em contacto com o administrador do servidor se este erro aparecer várias vezes, inclui também os detalhes técnicos abaixo no seu contacto.
Mais detalhes podem ser encontrados no log do servidor.
Detalhes técnicos
Endereço remoto: 89.109.115.82
Id. do pedido: UzxBOODrxnbfIY4dXFiO
Tipo: RuntimeException
Código: 0
Mensagem: image not found: image:OEMLOGO.bmp webroot: serverroot:/var/www/DNSCloud
Ficheiro: /var/www/DNSCloud/lib/private/URLGenerator.php
Linha: 206
Rasto
#0 /var/www/DNSCloud/apps/external/appinfo/app.php(38): OC\URLGenerator->imagePath(‘external’, ‘OEMLOGO.bmp’)
#1 /var/www/DNSCloud/lib/private/NavigationManager.php(64): OC_App::{closure}()
#2 /var/www/DNSCloud/lib/private/legacy/app.php(744): OC\NavigationManager->getAll()
#3 /var/www/DNSCloud/lib/private/TemplateLayout.php(84): OC_App::getNavigation()
#4 /var/www/DNSCloud/lib/private/legacy/template.php(232): OC\TemplateLayout->__construct(‘user’, ‘files’)
#5 /var/www/DNSCloud/lib/public/AppFramework/Http/TemplateResponse.php(157): OC_Template->fetchPage()
#6 /var/www/DNSCloud/lib/private/AppFramework/Http/Dispatcher.php(113): OCP\AppFramework\Http\TemplateResponse->render()
#7 /var/www/DNSCloud/lib/private/AppFramework/App.php(114): OC\AppFramework\Http\Dispatcher->dispatch(Object(OCA\Files\Controller\ViewController), ‘index’)
#8 /var/www/DNSCloud/lib/private/AppFramework/Routing/RouteActionHandler.php(47): OC\AppFramework\App::main(‘ViewController’, ‘index’, Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
#9 [internal function]: OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
#10 /var/www/DNSCloud/lib/private/Route/Router.php(299): call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
#11 /var/www/DNSCloud/lib/base.php(1010): OC\Route\Router->match(’/apps/files/’)
#12 /var/www/DNSCloud/index.php(40): OC::handleRequest()
#13 {main}
