I install nextcloud 22 on Raspberry pi 4 (/var/www/nextcloud) with ubuntu 20.04 mate.
All works fine, but it’s very very slow. I followed the instructions about opcache, and this doc: https://docs.nextcloud.com/server/22/admin_manual/configuration_server/caching_configuration.html.
I moved the nextcloud and mysql database folders to a hdd. It’s better if I browse my files directly in the folders, but If I use the dashboard, clicking on Contacts, calendar, etc, the load takes at least 40 seconds…
The output of my config.php file in /path/to/nextcloud
GNU nano 4.8 /var/www/nextcloud/config/config.php
'instanceid' => 'kkkkkkk',
'passwordsalt' => 'ddddddF',
'secret' => 'dddddddd',
0 => 'localhost',
1 => 'xxx.xxx.0.150',
2 => 'xxx.ddns.net:90',
'version' => '22.2.0.2',
'overwrite.cli.url' => 'http://localhost/nextcloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'xxx-xxx',
'dbpassword' => 'xxxxx',
Thank you for your help.
