Nextcloud version: 12
Operating system and version: Ubuntu 14.04
Apache or nginx version : Apache/2.4.7
PHP version: PHP 7.0.19
I’m using Plesk 12.5
Files can only be uploaded if they’re smaller then 10kbyte (9.9kB is working)
Everything >=10kByte will be canceled with a “Internal Server Error” Message.
Can you reliably replicate it? (If so, please outline steps):
This happens with every file with desktop client and webclient.
Logging is emtpy -> No Messages (loglevel is set to 1)
private informations are replaced with …
'instanceid' => 'ocs580adsyo8',
'passwordsalt' => '...',
'secret' => '...',
0 => 'cloud.kode-it.de',
'datadirectory' => '/var/www/vhosts/kode-it.de/cloud/data',
'overwrite.cli.url' => 'https://cloud.kode-it.de',
'version' => '12.0.0.29',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:3306',
'dbuser' => '...',
'dbpassword' => '...',
'memcache.local' => '\OC\Memcache\APCu',
"log_type" => "owncloud",
"logfile" => "nextcloud.log",
"loglevel" => "1",
"logdateformat" => "F d, Y H:i:s",
The output of your Apache/nginx/system log in `/var/log/____`:
Nothing specific to Nextcloud/Nothing logged in that time span.
Last added lines where 3 hours before the error message.
My php.ini:
[Pastebin](https://pastebin.com/NqrfVbTm)
.htaccess php part
php_value upload_max_filesize 4G
php_value post_max_size 6G
php_value memory_limit 8G
php_value mbstring.func_overload 0
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
