example
longer
example
here
Nextcloud version (eg, 20.0.5): 23.0.0
Operating system and version (eg, Ubuntu 20.04): CentOS Stream 8
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.37
PHP version (eg, 7.4): php 8.0.14
Every Time Uploading large files through the Next Cloud web UI is 5 to 10 seconds slow in the 2.4 GB section.
Average Upload Spees : 40~50MB
2.4GB section Upload Speed: 100kb
No Error
"objectstore": {
"class": "OC\\Files\\ObjectStore\\S3",
"arguments": {
"bucket": "***REMOVED SENSITIVE VALUE***",
"autocreate": false,
"key": "***REMOVED SENSITIVE VALUE***",
"hostname": "***REMOVED SENSITIVE VALUE***",
"port": 80,
"use_ssl": false,
"region": "",
"use_path_style": true,
"legacy_auth": true
"192.168.0.170",
"dbtype": "mysql",
"version": "23.0.0.10",
"overwrite.cli.url": "http:\/\/nextcloud.***REMOVED SENSITIVE VALUE***",
"overwriteprotocol": "https",
"dbport": "",
"mysql.utf8mb4": true,
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_smtpsecure": "tls",
"mail_smtpport": "587",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"default_language": "ko",
"default_locale": "ko_KR",
"auto_logout": true,
"session_lifetime": 21600,
"session_keepalive": true,
"default_phone_region": "KR",
"auth.bruteforce.protection.enabled": false,
"filelocking.enabled": false,
"cache_chunk_gc_ttl": 86400,
"tempdirectory": "\/tmp",
"preview_libreoffice_path": "\/usr\/bin\/libreoffice"
"apps": {
"accessibility": {
"enabled": "yes",
"installed_version": "1.9.0",
"types": ""
"activity": {
"enabled": "yes",
"installed_version": "2.15.0",
"notify_email_announcementcenter": "0",
"notify_email_calendar": "0",
"notify_email_calendar_event": "0",
"notify_email_calendar_todo": "0",
"notify_email_comments": "0",
"notify_email_contacts": "0",
"notify_email_favorite": "0",
"notify_email_file_changed": "0",
"notify_email_group_settings": "1",
"notify_email_public_links": "0",
"notify_email_remote_share": "0",
"notify_email_shared": "0",
"notify_email_spreed": "0",
"notify_email_systemtags": "0",
"notify_notification_announcementcenter": "1",
"notify_notification_calendar": "0",
"notify_notification_calendar_event": "0",
"notify_notification_calendar_todo": "0",
"notify_notification_comments": "0",
"notify_notification_contacts": "0",
"notify_notification_favorite": "0",
"notify_notification_file_changed": "0",
"notify_notification_file_favorite_changed": "0",
"notify_notification_group_settings": "0",
"notify_notification_personal_settings": "0",
"notify_notification_public_links": "0",
"notify_notification_remote_share": "0",
"notify_notification_security": "1",
"notify_notification_shared": "0",
"notify_notification_spreed": "0",
"notify_notification_systemtags": "0",
"notify_setting_batchtime": "3600",
"notify_setting_self": "0",
"notify_setting_selfemail": "0",
"types": "filesystem"
"admin_audit": {
"enabled": "yes",
"installed_version": "1.13.0",
"types": "logging"
"announcementcenter": {
"enabled": "yes",
"installed_version": "6.1.1",
"types": "logging"
"backgroundjob": {
"lastjob": "5614"
"bruteforcesettings": {
"enabled": "no",
"installed_version": "2.3.0",
"types": ""
"calendar": {
"enabled": "yes",
"installed_version": "3.0.2",
"types": ""
"circles": {
"enabled": "yes",
"installed_version": "23.0.0",
"loopback_tmp_scheme": "http",
"maintenance_run": "0",
"maintenance_update": "{\"maximum\":3,\"3\":1642665002,\"2\":1642667102,\"1\":1642667102,\"4\":1642644001,\"5\":1642215602}",
"types": "filesystem,dav"
"cloud_federation_api": {
"enabled": "yes",
"installed_version": "1.6.0",
"comments": {
"enabled": "yes",
"types": "logging"
"contacts": {
"enabled": "yes",
"installed_version": "4.0.6",
"types": "dav"
"contactsinteraction": {
"enabled": "yes",
"installed_version": "1.4.0",
"types": "dav"
"core": {
"backgroundjobs_mode": "cron",
"default_encryption_module": "OC_DEFAULT_MODULE",
"installed.bundles": "[\"CoreBundle\"]",
"installedat": "1639644833.505",
"lastcron": "1642667102",
"lastupdateResult": "[]",
"lastupdatedat": "1642644438",
"oc.integritycheck.checker": "[]",
"public_files": "files_sharing\/public.php",
"public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
"shareapi_allow_share_dialog_user_enumeration": "yes",
"shareapi_restrict_user_enumeration_to_group": "yes",
"theming.variables": "08f1b540b3835fe61fd8358872a10aa8",
"vendor": "nextcloud"
"dashboard": {
"enabled": "yes",
"installed_version": "7.3.0",
"types": ""
"dav": {
"enabled": "yes",
"installed_version": "1.21.0",
"encryption": {
"enabled": "no",
"encryptHomeStorage": "0",
"installed_version": "2.11.0",
"masterKeyId": "master_3c5bcc4b",
"publicShareKeyId": "pubShare_3c5bcc4b",
"recoveryKeyId": "recoveryKey_3c5bcc4b",
"federatedfilesharing": {
"enabled": "yes",
"types": ""
"federation": {
"enabled": "yes",
"types": "authentication"
"files": {
"default_quota": "100 GB",
"enabled": "yes",
"installed_version": "1.18.0",
"max_chunk_size": "0",
"files_automatedtagging": {
"enabled": "yes",
"files_pdfviewer": {
"enabled": "yes",
"installed_version": "2.4.0",
"types": ""
"files_rightclick": {
"enabled": "yes",
"installed_version": "1.2.0",
"types": ""
"files_sharing": {
"enabled": "yes",
"installed_version": "1.15.0",
"files_trashbin": {
"enabled": "yes",
"files_versions": {
"enabled": "yes",
"installed_version": "1.16.0",
"files_videoplayer": {
"enabled": "yes",
"installed_version": "1.12.0",
"types": ""
"firstrunwizard": {
"enabled": "yes",
"installed_version": "2.12.0",
"types": "logging"
"groupfolders": {
"enabled": "yes",
"installed_version": "11.1.0",
"logreader": {
"enabled": "yes",
"installed_version": "2.8.0",
"types": ""
"lookup_server_connector": {
"enabled": "yes",
"installed_version": "1.11.0",
"mail": {
"enabled": "yes",
"installed_version": "1.11.4",
"types": ""
"nextcloud_announcements": {
"enabled": "yes",
"pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
"types": "logging"
"notifications": {
"enabled": "yes",
"installed_version": "2.11.1",
"types": "logging"
"oauth2": {
"enabled": "yes",
"password_policy": {
"enabled": "yes",
"enforceHaveIBeenPwned": "1",
"enforceNonCommonPassword": "1",
"minLength": "10",
"photos": {
"enabled": "yes",
"installed_version": "1.5.0",
"types": ""
"privacy": {
"enabled": "yes",
"installed_version": "1.7.0",
"types": ""
"provisioning_api": {
"enabled": "yes",
"types": "prevent_group_restriction"
"recommendations": {
"enabled": "yes",
"types": ""
"richdocuments": {
"disable_certificate_verification": "yes",
"enabled": "yes",
"external_apps": "",
"installed_version": "5.0.1",
"public_wopi_url": "***REMOVED SENSITIVE VALUE***",
"types": "prevent_group_restriction",
"wopi_url": "***REMOVED SENSITIVE VALUE***"
"sendent": {
"enabled": "yes",
"firstRunAppVersion": "1.2.3",
"installed_version": "1.2.10",
"types": ""
"serverinfo": {
"cached_count_filecache": "54680",
"cached_count_storages": "77",
"enabled": "yes",
"types": ""
"settings": {
"enabled": "yes",
"types": ""
"sharebymail": {
"enabled": "yes",
"spreed": {
"allowed_groups": "[]",
"conversations_files": "0",
"conversations_files_public_shares": "0",
"enabled": "yes",
"has_reference_id": "yes",
"installed_version": "13.0.1",
"signaling_ticket_secret": "***REMOVED SENSITIVE VALUE***",
"sip_bridge_groups": "[]",
"start_conversations": "[]",
"stun_servers": "***REMOVED SENSITIVE VALUE***",
"turn_servers": "***REMOVED SENSITIVE VALUE***",
"types": "dav,prevent_group_restriction"
"support": {
"enabled": "yes",
"types": "session"
"survey_client": {
"apps": "yes",
"database": "yes",
"enabled": "yes",
"encryption": "yes",
"files_sharing": "yes",
"php": "yes",
"server": "yes",
"stats": "yes",
"types": ""
"systemtags": {
"enabled": "yes",
"types": "logging"
"text": {
"enabled": "yes",
"installed_version": "3.4.0",
"types": "dav"
"theming": {
"cachebuster": "6",
"color": "#000000",
"enabled": "yes",
"installed_version": "1.14.0",
"logoMime": "image\/png",
"name": "\uc694\ub2e4\uc815\ubcf4\uae30\uc220",
"slogan": "***REMOVED SENSITIVE VALUE***",
"types": "logging",
"url": "***REMOVED SENSITIVE VALUE***"
"theming_customcss": {
"cachebuster": "1639650127177",
"customcss": "#filelist-header #rich-workspace {\n display:none;\n}",
"enabled": "yes",
"installed_version": "1.10.0",
"types": ""
"twofactor_backupcodes": {
"enabled": "yes",
"types": ""
"updatenotification": {
"calendar": "3.0.5",
"contacts": "4.0.7",
"enabled": "yes",
"groupfolders": "11.1.2",
"mail": "1.11.5",
"richdocuments": "5.0.1",
"sendent": "1.2.10",
"types": "",
"update_check_errors": "0"
"user_status": {
"enabled": "yes",
"installed_version": "1.3.1",
"types": ""
"viewer": {
"enabled": "yes",
"types": ""
"weather_status": {
"enabled": "yes",
"installed_version": "1.3.0",
"types": ""
"workflow_pdf_converter": {
"enabled": "yes",
"installed_version": "1.8.0",
"workflow_script": {
"enabled": "yes",
"workflowengine": {
"enabled": "yes",
"installed_version": "2.5.0",
No Error
