Configuration:
RPi4 4GB
Raspian Buster
Nextcloud Version: 22.2.8
PHP Version: 7.3
PostgreSQL 11.13
Nginx 1.14.2
Redis Version 4.2.0
NC directly on RPi without docker
Hi, End of 2021 I did an update from NC 20 to 21 like always. Directly after this I updated to 22.1. The first update worked fine and nextcloud came up normally. After the second update NC was not available again. Browser is showing: Internal Server Error.
Tried a lot and also the last backup did not helped.
sudo -u www-data php /var/www/nextcloud/occ maintenance:repair
gives only errors. So I startet again the updater with
sudo -u www-data php /var/www/nextcloud/updater/updater.phar
which started the update to 22.2.8, but did not finished completely. Also trying another backup and reinstalling php packages did not resolved the issue.
My logs from last update:
Nextcloud Updater - version: v20.0.0beta4-11-g68fa0d4
Current version is 23.0.0.
Update to Nextcloud 22.2.8 available. (channel: "stable")
Following file will be downloaded automatically: https://download.nextcloud.com/server/releases/nextcloud-22.2.8.zip
Open changelog ↗
Steps that will be executed:
[✔] Check for expected files
[✔] Check for write permissions
[✔] Create backup
[✔] Downloading
[✔] Verify integrity
[✔] Extracting
[✔] Enable maintenance mode
[✔] Replace entry points
[✔] Delete old files
[✔] Move new files in place
[✔] Done
Continue update? [y/N] y
Info: Pressing Ctrl-C will finish the currently running step and then stops the updater.
[✔] Create backup
[✔] Downloading
[✔] Extracting
[✔] Done
Update of code successful.
Should the "occ upgrade" command be executed? [Y/n] y
PDOException: SQLSTATE[XX000]: Internal error: 7 ERROR: unexpected chunk number 1 (expected 0) for toast value 38969 in pg_toast_2619 in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php:82
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php(82): PDO->query('SELECT * FROM "...')
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1062): Doctrine\DBAL\Driver\PDO\Connection->query('SELECT * FROM "...')
#2 /var/www/nextcloud/lib/private/DB/Connection.php(236): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM "...', Array, Array, NULL)
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\DB\Connection->executeQuery('SELECT * FROM "...', Array, Array)
#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(287): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/nextcloud/lib/private/AppConfig.php(344): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(109): OC\AppConfig->loadConfigValues()
#7 /var/www/nextcloud/lib/private/AppConfig.php(300): OC\AppConfig->getApps()
#8 /var/www/nextcloud/lib/private/legacy/OC_App.php(972): OC\AppConfig->getValues(false, 'installed_versi...')
#9 /var/www/nextcloud/lib/private/Server.php(691): OC_App::getAppVersions()
#10 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}(Object(OC\Server))
#11 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#12 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#13 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', false)
#14 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(182): OC\AppFramework\Utility\SimpleContainer->get('OC\\Memcache\\Fac...')
#16 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#17 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#18 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet('OCP\\ICacheFacto...')
#19 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OCP\\ICacheFacto...', false)
#20 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\ICacheFacto...')
#21 /var/www/nextcloud/lib/private/Server.php(1069): OC\AppFramework\Utility\SimpleContainer->get('OCP\\ICacheFacto...')
#22 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}(Object(OC\Server))
#23 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#24 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#25 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', false)
#26 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#27 /var/www/nextcloud/lib/private/Server.php(2030): OC\AppFramework\Utility\SimpleContainer->get('OCP\\Lock\\ILocki...')
#28 /var/www/nextcloud/lib/private/Files/View.php(118): OC\Server->getLockingProvider()
#29 /var/www/nextcloud/lib/private/Server.php(439): OC\Files\View->__construct()
#30 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}(Object(OC\Server))
#31 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#32 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#33 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', false)
#34 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#35 /var/www/nextcloud/lib/private/Server.php(1393): OC\AppFramework\Utility\SimpleContainer->get('OC\\Files\\Node\\H...')
#36 /var/www/nextcloud/lib/base.php(594): OC\Server->boot()
#37 /var/www/nextcloud/lib/base.php(1087): OC::init()
#38 /var/www/nextcloud/console.php(48): require_once('/var/www/nextcl...')
#39 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#40 {main}
Next Doctrine\DBAL\Driver\PDO\Exception: SQLSTATE[XX000]: Internal error: 7 ERROR: unexpected chunk number 1 (expected 0) for toast value 38969 in pg_toast_2619 in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php:26
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php(87): Doctrine\DBAL\Driver\PDO\Exception::new(Object(PDOException))
#40 {main}
Next Doctrine\DBAL\Exception\DriverException: An exception occurred while executing a query: SQLSTATE[XX000]: Internal error: 7 ERROR: unexpected chunk number 1 (expected 0) for toast value 38969 in pg_toast_2619 in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/PostgreSQL/ExceptionConverter.php:83
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1780): Doctrine\DBAL\Driver\API\PostgreSQL\ExceptionConverter->convert(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1719): Doctrine\DBAL\Connection->handleDriverException(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1067): Doctrine\DBAL\Connection->convertExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDO\Exception), 'SELECT * FROM "...', Array, Array)
#3 /var/www/nextcloud/lib/private/DB/Connection.php(236): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM "...', Array, Array, NULL)
#4 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\DB\Connection->executeQuery('SELECT * FROM "...', Array, Array)
#5 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(287): Doctrine\DBAL\Query\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(344): OC\DB\QueryBuilder\QueryBuilder->execute()
#7 /var/www/nextcloud/lib/private/AppConfig.php(109): OC\AppConfig->loadConfigValues()
#8 /var/www/nextcloud/lib/private/AppConfig.php(300): OC\AppConfig->getApps()
#9 /var/www/nextcloud/lib/private/legacy/OC_App.php(972): OC\AppConfig->getValues(false, 'installed_versi...')
#10 /var/www/nextcloud/lib/private/Server.php(691): OC_App::getAppVersions()
#11 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}(Object(OC\Server))
#12 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#13 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#14 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', false)
#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#16 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(182): OC\AppFramework\Utility\SimpleContainer->get('OC\\Memcache\\Fac...')
#17 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#18 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#19 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet('OCP\\ICacheFacto...')
#20 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OCP\\ICacheFacto...', false)
#21 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\ICacheFacto...')
#22 /var/www/nextcloud/lib/private/Server.php(1069): OC\AppFramework\Utility\SimpleContainer->get('OCP\\ICacheFacto...')
#23 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}(Object(OC\Server))
#24 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#25 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#26 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', false)
#27 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#28 /var/www/nextcloud/lib/private/Server.php(2030): OC\AppFramework\Utility\SimpleContainer->get('OCP\\Lock\\ILocki...')
#29 /var/www/nextcloud/lib/private/Files/View.php(118): OC\Server->getLockingProvider()
#30 /var/www/nextcloud/lib/private/Server.php(439): OC\Files\View->__construct()
#31 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}(Object(OC\Server))
#32 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#33 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#34 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', false)
#35 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#36 /var/www/nextcloud/lib/private/Server.php(1393): OC\AppFramework\Utility\SimpleContainer->get('OC\\Files\\Node\\H...')
#37 /var/www/nextcloud/lib/base.php(594): OC\Server->boot()
#38 /var/www/nextcloud/lib/base.php(1087): OC::init()
#39 /var/www/nextcloud/console.php(48): require_once('/var/www/nextcl...')
#40 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#41 {main}
Keep maintenance mode active? [y/N] y
Maintenance mode kept active
and php -i :
php -i
phpinfo()
PHP Version => 7.3.31-1~deb10u1
System => Linux openhabian 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Build Date => Oct 24 2021 15:18:08
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => /etc/php/7.3/cli
Loaded Configuration File => /etc/php/7.3/cli/php.ini
Scan this dir for additional .ini files => /etc/php/7.3/cli/conf.d
Additional .ini files parsed => /etc/php/7.3/cli/conf.d/10-opcache.ini,
/etc/php/7.3/cli/conf.d/10-pdo.ini,
/etc/php/7.3/cli/conf.d/15-xml.ini,
/etc/php/7.3/cli/conf.d/20-apcu.ini,
/etc/php/7.3/cli/conf.d/20-bcmath.ini,
/etc/php/7.3/cli/conf.d/20-bz2.ini,
/etc/php/7.3/cli/conf.d/20-calendar.ini,
/etc/php/7.3/cli/conf.d/20-ctype.ini,
/etc/php/7.3/cli/conf.d/20-curl.ini,
/etc/php/7.3/cli/conf.d/20-dom.ini,
/etc/php/7.3/cli/conf.d/20-exif.ini,
/etc/php/7.3/cli/conf.d/20-fileinfo.ini,
/etc/php/7.3/cli/conf.d/20-ftp.ini,
/etc/php/7.3/cli/conf.d/20-gd.ini,
/etc/php/7.3/cli/conf.d/20-gettext.ini,
/etc/php/7.3/cli/conf.d/20-gmp.ini,
/etc/php/7.3/cli/conf.d/20-iconv.ini,
/etc/php/7.3/cli/conf.d/20-igbinary.ini,
/etc/php/7.3/cli/conf.d/20-imagick.ini,
/etc/php/7.3/cli/conf.d/20-intl.ini,
/etc/php/7.3/cli/conf.d/20-json.ini,
/etc/php/7.3/cli/conf.d/20-ldap.ini,
/etc/php/7.3/cli/conf.d/20-mbstring.ini,
/etc/php/7.3/cli/conf.d/20-pdo_pgsql.ini,
/etc/php/7.3/cli/conf.d/20-pgsql.ini,
/etc/php/7.3/cli/conf.d/20-phar.ini,
/etc/php/7.3/cli/conf.d/20-posix.ini,
/etc/php/7.3/cli/conf.d/20-readline.ini,
/etc/php/7.3/cli/conf.d/20-redis.ini,
/etc/php/7.3/cli/conf.d/20-shmop.ini,
/etc/php/7.3/cli/conf.d/20-simplexml.ini,
/etc/php/7.3/cli/conf.d/20-smbclient.ini,
/etc/php/7.3/cli/conf.d/20-sockets.ini,
/etc/php/7.3/cli/conf.d/20-sysvmsg.ini,
/etc/php/7.3/cli/conf.d/20-sysvsem.ini,
/etc/php/7.3/cli/conf.d/20-sysvshm.ini,
/etc/php/7.3/cli/conf.d/20-tokenizer.ini,
/etc/php/7.3/cli/conf.d/20-wddx.ini,
/etc/php/7.3/cli/conf.d/20-xmlreader.ini,
/etc/php/7.3/cli/conf.d/20-xmlrpc.ini,
/etc/php/7.3/cli/conf.d/20-xmlwriter.ini,
/etc/php/7.3/cli/conf.d/20-xsl.ini,
/etc/php/7.3/cli/conf.d/20-zip.ini,
/etc/php/7.3/cli/conf.d/25-apcu_bc.ini
PHP API => 20180731
PHP Extension => 20180731
Zend Extension => 320180731
Zend Extension Build => API320180731,NTS
PHP Extension Build => API20180731,NTS
Debug Build => no
Thread Safety => disabled
Zend Signal Handling => enabled
Zend Memory Manager => enabled
Zend Multibyte Support => provided by mbstring
IPv6 Support => enabled
DTrace Support => available, disabled
Registered PHP Streams => https, ftps, compress.zlib, php, file, glob, data, http, ftp, compress.bzip2, smb, zip, phar
Registered Stream Socket Transports => tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2
Registered Stream Filters => zlib.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, bzip2.*, convert.iconv.*
