I have tried various things to get this to work, but I can’t seem to figure it out.
I have a nextcloud instance setup, everything mostly seems to work.
I have a docker instance and nginx setup.
I can visit https://office.mydomain.net/hosting/discovery and https://office.mydomain.net/hosting/capabilities and get a json response. local and remote.
In NextCloud
I can connect to collabra using localhost:9980
using https://office.mydomain.net I get “Could not establish connection to the Collabora Online server”
I also can not connect to the built-in CODE server either.
I have tried setting various loglevels, none of them output any sort of error.
Firefox Debug Console returns
XHRPOSThttps://cloud.mydomain.net/index.php/apps/richdocuments/ajax/admin.php
[HTTP/2 500 Internal Server Error 289ms]status "error" data Object { message: "Failed to connect to the remote server" } message "Failed to connect to the remote server"
Any help would be greatly appreciated.
config.php
<?php $CONFIG = array ( 'instanceid' => 'removed', 'passwordsalt' => 'removed', 'secret' => 'removed', 'trusted_domains' => array ( 0 => 'cloud.mydomain.net', 1 => 'office.mydomain.net', ), 'datadirectory' => '/nextcloud/data', 'dbtype' => 'pgsql', 'version' => '19.0.2.2', 'overwrite.cli.url' => 'https://cloud.mydomain.net', 'dbname' => 'nextcloud', 'dbhost' => 'localhost', 'dbport' => '', 'dbtableprefix' => 'oc_', 'dbuser' => 'removed', 'dbpassword' => 'removed', 'log_type' => 'file', 'logfile' => '/var/log/nextcloud.log', 'logfilemode' => 0640, 'loglevel' => '0', 'logdateformat' => 'F d, Y H:i:s', 'installed' => true, 'memcache.local' => '\OC\Memcache\APCu', 'memcache.distributed' => '\OC\Memcache\Redis', 'memcache.locking' => '\OC\Memcache\Redis', 'redis' => [ 'host' => '/run/redis/redis.sock' ] );
collabora nginx config
upstream collabora-docker {
server 127.0.0.1:9980;
}server {
listen 443 ssl;
server_name office.mydomain.net;ssl_certificate ; # managed by Certbot ssl_certificate_key ; # managed by Certbot # static files location ^~ /loleaflet { proxy_pass http://collabora-docker; proxy_set_header Host $host; } # WOPI discovery URL location ^~ /hosting/discovery { proxy_pass http://collabora-docker; proxy_set_header Host $host; } # Capabilities location ^~ /hosting/capabilities { proxy_pass http://collabora-docker; proxy_set_header Host $http_host; } # Main websocket location ~ /lool/(.*)/ws$ { proxy_pass http://collabora-docker; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "Upgrade"; proxy_set_header Host $host; proxy_read_timeout 36000s; } # Admin Console websocket location ^~ /lool/adminws { proxy_buffering off; proxy_pass http://collabora-docker; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "Upgrade"; proxy_set_header Host $host; proxy_read_timeout 36000s; } # download, presentation and image upload location ~ /lool { proxy_pass http://collabora-docker; proxy_set_header Host $host; }
nextcloud nginx config
upstream php-handler {
server unix:/run/php-fpm/php-fpm.sock;
}server {
listen 80;
listen [::]:80;
server_name cloud.mydomain.net;
# enforce https
return 301 https://$server_name:443$request_uri;
}server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name cloud.mydomain.net;# Use Mozilla's guidelines for SSL/TLS settings # https://mozilla.github.io/server-side-tls/ssl-config-generator/ # NOTE: some settings below might be redundant ssl_certificate /etc/letsencrypt/live/mydomain.net/fullchain.pem; # managed by Certbot ssl_certificate_key /etc/letsencrypt/live/mydomain.net/privkey.pem; # managed by Certbot; # Add headers to serve security related headers # Before enabling Strict-Transport-Security headers please read into this # topic first. add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always; # # WARNING: Only add the preload option once you read about # the consequences in https://hstspreload.org/. This option # will add the domain to a hardcoded list that is shipped # in all major browsers and getting removed from this list # could take several months. add_header Referrer-Policy "no-referrer" always; add_header X-Content-Type-Options "nosniff" always; add_header X-Download-Options "noopen" always; add_header X-Frame-Options "SAMEORIGIN" always; add_header X-Permitted-Cross-Domain-Policies "none" always; add_header X-Robots-Tag "none" always; add_header X-XSS-Protection "1; mode=block" always; # Remove X-Powered-By, which is an information leak fastcgi_hide_header X-Powered-By; # Path to the root of your installation root /usr/share/webapps/nextcloud; location = /robots.txt { allow all; log_not_found off; access_log off; } # The following 2 rules are only needed for the user_webfinger app. # Uncomment it if you're planning to use this app. #rewrite ^/.well-known/host-meta /public.php?service=host-meta last; #rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last; # The following rule is only needed for the Social app. # Uncomment it if you're planning to use this app. #rewrite ^/.well-known/webfinger /public.php?service=webfinger last; location = /.well-known/carddav { return 301 $scheme://$host:$server_port/remote.php/dav; } location = /.well-known/caldav { return 301 $scheme://$host:$server_port/remote.php/dav; } # set max upload size client_max_body_size 512M; fastcgi_buffers 64 4K; # Enable gzip but do not remove ETag headers gzip on; gzip_vary on; gzip_comp_level 4; gzip_min_length 256; gzip_proxied expired no-cache no-store private no_last_modified no_etag auth; gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy; # Uncomment if your server is build with the ngx_pagespeed module # This module is currently not supported. #pagespeed off; location / { rewrite ^ /index.php; } location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ { deny all; } location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) { deny all; } location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy)\.php(?:$|\/) { fastcgi_split_path_info ^(.+?\.php)(\/.*|)$; set $path_info $fastcgi_path_info; try_files $fastcgi_script_name =404; include fastcgi_params; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; fastcgi_param PATH_INFO $path_info; fastcgi_param HTTPS on; # Avoid sending the security headers twice fastcgi_param modHeadersAvailable true; # Enable pretty urls fastcgi_param front_controller_active true; fastcgi_pass php-handler; fastcgi_intercept_errors on; fastcgi_request_buffering off; } location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) { try_files $uri/ =404; index index.php; } # Adding the cache control header for js, css and map files # Make sure it is BELOW the PHP block location ~ \.(?:css|js|woff2?|svg|gif|map)$ { try_files $uri /index.php$request_uri; add_header Cache-Control "public, max-age=15778463"; # Add headers to serve security related headers (It is intended to # have those duplicated to the ones above) # Before enabling Strict-Transport-Security headers please read into # this topic first. #add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always; # # WARNING: Only add the preload option once you read about # the consequences in https://hstspreload.org/. This option # will add the domain to a hardcoded list that is shipped # in all major browsers and getting removed from this list # could take several months. add_header Referrer-Policy "no-referrer" always; add_header X-Content-Type-Options "nosniff" always; add_header X-Download-Options "noopen" always; add_header X-Frame-Options "SAMEORIGIN" always; add_header X-Permitted-Cross-Domain-Policies "none" always; add_header X-Robots-Tag "none" always; add_header X-XSS-Protection "1; mode=block" always; # Optional: Don't log access to assets access_log off; } location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap|mp4|webm)$ { try_files $uri /index.php$request_uri; # Optional: Don't log access to other assets access_log off; }
