HI, in a daring attempt to make the data high availability I setup mariadb master -to master replication.
I copied all the next cloud db to the other mariadb server running on a different node, then I did
All this seem to have worked fine but When I opened nextcloud app in browser I threw error:
I have put my log output here on pastebin as it was too big:
any help will be greatly appreciated.
Should I use nextcloud user as replication user ? or do I need to configure something else ?
Nextcloud version : 17
Operating system and version : Ubuntu : 18.04
Apache or nginx version : Apache/2.4.29 (Ubuntu)
PHP version (eg, 7.1):
on my primary server where nextcloud is installed I ran
CHANGE MASTER TO MASTER_HOST = ‘192.168.5.16’, ‘MASTER_USER’=‘replica’, ‘MASTER_PASSWORD’=‘replica’, MASTER_LOG_FILE=‘mariadb-bin.000005’, MASTER_LOG_POS= 17592443;
then on remote server where I wanted data to replicate
CHANGE MASTER TO MASTER_HOST = ‘192.168.5.15’, MASTER_USER=‘replicator’, MASTER_PASSWORD=‘replicate123’, MASTER_LOG_FILE=‘mysql-bin.000001’, MASTER_LOG_POS=946;
