Hi everyone. In installed nextcloud 19 from source code. everything is ok and work. but my problem is nextcloud talk. I followed nextcloud manual . I installed coturn and follow all rules. but my problem is we can call others no voice and video transferred.
Did you check by default configuration of using Talk service as I want to know that before configure of Turnserver ? I am facing same problem. Its worked on same Lan but over public network its not working on my case. My configuration as same like you. Is there anybody to help us.
–listening-ip<ip> Listener IP address of relay server. Multiple listeners can be specified. If no IP (s) specified, then all IPv4 and IPv6 system IPs will be used for listening.
Hi. I installed nextcloud on the public cloud . users can have a valid IP address or sit behind NAT . Nextcloud and coturn both on the same server , and have a valid IP address .
I used lets encrypt.
There was issue on my coturn server configuration. Which is resolved now.
Choose the listening port, e.g. 3478 ( default for non-TLS ) Coturn config as below:
listening-port=3478
fingerprint
lt-cred-mech
use-auth-secret
static-auth-secret= <yourChosen/GeneratedSecret>
realm= your.domain.org
total-quota=100
bps-capacity=0
stale-nonce
no-loopback-peers # Only on coTURN below v4.5.1.0!
no-multicast-peers #The following settings can be used to adjust the logging behavior.
no-stdout-log
log-file=…
syslog
simple-log
I’m not issue the below two line because It only for specific IP
#listening-ip=office.xxxxxx.xxxx
#relay-ip=office.xxxxx.xxxxxx
Use: external-ip=your.external.ip in your turnserver.conf
listening-ip I use the internal ip in our network, for external Ip is for wan.
Works for my centos7 and coturn and nextcloud19 talk 9
