can anyone tell me why my turnserver.log throws so many errors?
im back again on Port 5349 tcp/udp and the turnserver.conf has not any line to listen to 3478
: (940): INFO: log file opened: /var/tmp/turnserver_2023-03-28.log
0: (940): INFO: Listener address to use: 127.0.0.1
0: (940): INFO: Listener address to use: 127.0.1.1
0: (940): INFO: Listener address to use: ::1
0: (940): INFO: Listener address to use: x.x.x.x
0: (940): INFO: Listener address to use: 0.0.0.0
0: (940): INFO: Relay address to use: x.x.x.x
0: (940): INFO: Relay address to use: 0.0.0.0
0: (940): INFO: Black listing: 10.0.0.0-10.255.255.255
0: (940): INFO: Black listing: 172.16.0.0-172.31.255.255
0: (940): INFO: Black listing: 192.168.0.0-192.168.255.255
0: (940): INFO: Black listing: 100.64.0.0-100.127.255.255
0: (940): INFO: Black listing: 169.254.0.0-169.254.255.255
0: (940): INFO: Black listing: 192.0.0.0-192.0.0.255
0: (940): INFO: Black listing: 192.0.2.0-192.0.2.255
0: (940): INFO: Black listing: 198.18.0.0-198.19.255.255
0: (940): INFO: Black listing: 198.51.100.0-198.51.100.255
0: (940): INFO: Black listing: 203.0.113.0-203.0.113.255
0: (940): INFO: Black listing: fc00::-fdff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
0: (940): INFO: Black listing: fe80::-febf:ffff:ffff:ffff:ffff:ffff:ffff:ffff
0: (940): INFO: Black listing: ::ffff:0:0-::ffff:ffff:ffff
0: (940): INFO: Black listing: 64:ff9b::-64:ff9b::ffff:ffff
0: (940): INFO: Black listing: 64:ff9b:1::-64:ff9b:1:ffff:ffff:ffff:ffff:ffff
0: (940): INFO: Black listing: 2001::-2001:1ff:ffff:ffff:ffff:ffff:ffff:ffff
0: (940): INFO: Black listing: 2001:db8::-2001:db8:ffff:ffff:ffff:ffff:ffff:ffff
0: (940): INFO: Black listing: 2002::-2002:ffff:ffff:ffff:ffff:ffff:ffff:ffff
0: (940): INFO: Coturn Version Coturn-4.6.1 'Gorst'
0: (940): INFO: Max number of open files/sockets allowed for this process: 1048576
0: (940): INFO: Due to the open files/sockets limitation, max supported number of TURN Sessions possible is: 524000 (approximately)
0: (940): INFO:
==== Show him the instruments, Practical Frost: ====
0: (940): INFO: OpenSSL compile-time version: OpenSSL 1.1.1n 15 Mar 2022 (0x101010ef)
0: (940): INFO: TLS 1.3 supported
0: (940): INFO: DTLS 1.2 supported
0: (940): INFO: TURN/STUN ALPN supported
0: (940): INFO: Third-party authorization (oAuth) supported
0: (940): INFO: GCM (AEAD) supported
0: (940): INFO: SQLite is not supported
0: (940): INFO: Redis is not supported
0: (940): INFO: PostgreSQL is not supported
0: (940): INFO: MySQL is not supported
0: (940): INFO: MongoDB is not supported
0: (940): INFO: Default Net Engine version: 3 (UDP thread per CPU core)
0: (940): INFO: Domain name:
0: (940): INFO: Default realm: coturn.skynet-privatecloud.ch
0: (940): INFO: Certificate file found: /etc/letsencrypt/live/coturn.skynet-privatecloud.ch-rsa/fullchain.pem
0: (940): INFO: Private key file found: /etc/letsencrypt/live/coturn.skynet-privatecloud.ch-rsa/privkey.pem
0: (940): INFO: TLS cipher suite: DEFAULT:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256
0: (940): INFO: DTLS cipher suite: DEFAULT:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256
0: (940): INFO: pid file created: /var/run/turnserver.pid
0: (940): INFO: IO method: epoll (with changelist)
0: (940): INFO: Wait for relay ports initialization...
0: (940): INFO: relay 82.165.65.57 initialization...
0: (940): INFO: relay 82.165.65.57 initialization done
0: (940): INFO: relay 0.0.0.0 initialization...
0: (940): INFO: relay 0.0.0.0 initialization done
0: (940): INFO: Relay ports initialization done
0: (940): INFO: Total General servers: 4
5: (942): DEBUG: turn server id=1 created
5: (941): DEBUG: turn server id=0 created
5: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
5: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
5: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
5: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
5: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
5: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
5: (943): DEBUG: turn server id=2 created
5: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
5: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
5: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
5: (944): DEBUG: turn server id=3 created
5: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
5: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
5: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 127.0.0.1:3478
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 127.0.0.1:3479
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 127.0.0.1:5349
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 127.0.0.1:5350
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 127.0.1.1:3478
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 127.0.1.1:3479
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 127.0.1.1:5349
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 127.0.1.1:5350
5: (940): INFO: IPv6. DTLS/UDP listener opened on: ::1:3478
5: (940): INFO: IPv6. DTLS/UDP listener opened on: ::1:3479
5: (940): INFO: IPv6. DTLS/UDP listener opened on: ::1:5349
5: (940): INFO: IPv6. DTLS/UDP listener opened on: ::1:5350
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 82.165.65.57:3478
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 82.165.65.57:3479
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 82.165.65.57:5349
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 82.165.65.57:5350
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 0.0.0.0:3478
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 0.0.0.0:3479
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 0.0.0.0:5349
5: (940): INFO: IPv4. DTLS/UDP listener opened on: 0.0.0.0:5350
5: (940): INFO: Total auth threads: 3
5: (940): INFO: turnserver compiled without prometheus support
10: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
10: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
10: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
10: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
10: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
10: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
10: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
10: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
10: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
11: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
11: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
10: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
11: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
11: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
11: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
11: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
11: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
11: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
11: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
12: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
12: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
12: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
12: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
12: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
12: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
12: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
13: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
13: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
13: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
13: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
13: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
13: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
13: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
13: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
13: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
13: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
13: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
13: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
14: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
14: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
14: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
14: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
14: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
14: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
14: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
14: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
14: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
14: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
14: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
14: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
15: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
15: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
15: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
15: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
15: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
15: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
15: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
15: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
15: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
15: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
15: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
16: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
15: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
16: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
16: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
16: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
16: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
16: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
16: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
16: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
17: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
17: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
17: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
17: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
17: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
17: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
17: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
17: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
17: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
17: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
17: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
18: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
18: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
18: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
18: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
18: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
18: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
18: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
18: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
18: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
18: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
18: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
18: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
19: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
19: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
19: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
19: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
19: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
19: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
19: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
19: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
19: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
19: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
19: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
19: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
20: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
20: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
20: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
20: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
20: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
20: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
20: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
20: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
20: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
20: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
20: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
20: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
21: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
21: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
21: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
21: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
21: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
21: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
21: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
21: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
21: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
21: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
21: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
21: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
22: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
22: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
22: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
22: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
22: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
22: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
22: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
22: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
22: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
22: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
22: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
22: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
23: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
23: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
23: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
23: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
23: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
23: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
23: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
23: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
23: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
23: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
23: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
23: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
24: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
24: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
24: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
24: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
24: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
24: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
24: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
24: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
24: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
24: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
24: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
24: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
25: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
25: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
25: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
25: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
25: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
25: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
25: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
25: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
25: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
25: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
25: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
25: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
26: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
26: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
26: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
26: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
26: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
26: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
26: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
26: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
26: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
26: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
26: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
26: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
27: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
27: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
27: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
27: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
27: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
27: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
27: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
27: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
27: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
27: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
27: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
27: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
28: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
28: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
28: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
28: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
28: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
28: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
28: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
28: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
28: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
28: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
28: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
28: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
29: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
29: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
29: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
29: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
29: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
29: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
29: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
29: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
29: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
29: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
29: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
29: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
30: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
30: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
30: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
30: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
30: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
30: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
30: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
30: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
30: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
30: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
30: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
30: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
31: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
31: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
31: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
31: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
31: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
31: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
31: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
31: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
31: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
31: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
31: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
31: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
32: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
32: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
32: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
32: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
32: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
32: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
32: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
32: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
32: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
32: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
32: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
32: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
33: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
33: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
33: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
33: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
33: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
33: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
33: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
33: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
33: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
33: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
33: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
33: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
34: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
34: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
34: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
34: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
34: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
34: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
34: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
34: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
34: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
34: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
34: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
34: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
35: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
35: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
35: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
35: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
35: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
35: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
35: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
35: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
35: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
35: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
35: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
35: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
36: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
36: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
36: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
36: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
36: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
36: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
36: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
36: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
36: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
36: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
36: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
36: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
37: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
37: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
37: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
37: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
37: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
37: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
37: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
37: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
37: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
37: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
37: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
37: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
38: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
38: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
38: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
38: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
38: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
38: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
38: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
38: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
38: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
38: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
38: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
38: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
39: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
39: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
39: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
39: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
39: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
39: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
39: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
39: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
39: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
39: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
39: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
39: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
40: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
40: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
40: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
40: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
40: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
40: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
40: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
40: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
40: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
40: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
40: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
40: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
41: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
41: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
41: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
41: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
41: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
41: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
41: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
41: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
41: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
41: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
41: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
41: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
42: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
42: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
42: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
42: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
42: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
42: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
42: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
42: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
42: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
42: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
42: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
42: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
43: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
43: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
43: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
43: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
43: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
43: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
43: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
43: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
43: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
43: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
43: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
43: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
44: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
44: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
44: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
44: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
44: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
44: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
44: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
44: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
44: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
44: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
44: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
44: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
45: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
45: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
45: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
45: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
45: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
45: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
45: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
45: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
45: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
45: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
45: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
45: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
46: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
46: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
46: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
46: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
46: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
46: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
46: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
46: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
46: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
46: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
46: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
46: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
47: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
47: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
47: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
47: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
47: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
47: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
47: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
47: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
47: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
47: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
47: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
47: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
48: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
48: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
48: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
48: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
48: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
48: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
48: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
48: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
48: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
48: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
48: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
48: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
49: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
49: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
49: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
49: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
49: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
49: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
49: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
49: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
49: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
49: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
49: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
49: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
50: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
50: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
50: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
50: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
50: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
50: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
50: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
50: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
50: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
50: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
50: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
50: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
51: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
51: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
51: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
51: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
51: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
51: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
51: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
51: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
51: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
51: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
51: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
51: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
52: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
52: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
52: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
52: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
52: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
52: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
52: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
52: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
52: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
52: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
52: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
52: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
53: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
53: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
53: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
53: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
53: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
53: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
53: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
53: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
53: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
53: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
53: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
53: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
54: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
54: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
54: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
54: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
54: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
54: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
54: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
54: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
54: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
54: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
54: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
54: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
55: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
55: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
55: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
55: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
55: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
55: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
55: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
55: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
55: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
55: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
55: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
55: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
56: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
56: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
56: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
56: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
56: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
56: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
56: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
56: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
56: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
56: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
56: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
56: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
57: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
57: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
57: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
57: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
57: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
57: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
57: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
57: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
57: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
57: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
57: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
57: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
58: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
58: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
58: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
58: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
58: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
58: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
58: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
58: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
58: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
58: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
58: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
58: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
59: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
59: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
59: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
59: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
59: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
59: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
59: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
59: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
59: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
59: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
59: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
59: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
60: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
60: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
60: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
60: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
60: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
60: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
60: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
60: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
60: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
60: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
60: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
60: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
61: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
61: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
61: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
61: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
61: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
61: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
61: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
61: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
61: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
61: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
61: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
61: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
62: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
62: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
62: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
62: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
62: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
62: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
62: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
62: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
62: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
62: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
62: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
62: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
63: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
63: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
63: (942): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
63: (944): WARNING: Trying to bind fd 28 to <127.0.0.1:3478>: errno=98
63: (944): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
63: (944): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
63: (943): WARNING: Trying to bind fd 26 to <127.0.0.1:3478>: errno=98
63: (943): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
63: (943): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
63: (941): WARNING: Trying to bind fd 21 to <127.0.0.1:3478>: errno=98
63: (941): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
63: (941): INFO: Trying to bind TLS/TCP listener socket to addr 127.0.0.1:3478, again...
64: (942): WARNING: Trying to bind fd 20 to <127.0.0.1:3478>: errno=98
64: (942): WARNING: Cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
64: (942): ERROR: Fatal final failure: cannot bind TLS/TCP listener socket to addr 127.0.0.1:3478
my current turn.conf as it is right now:
tls-listening-port=5349
listening-ip=127.0.0.1
listening-ip=127.0.1.1
listening-ip=::1
listening-ip=x.x.x.x
listening-ip=
relay-ip=x.x.x.x
relay-ip=
min-port=49152
max-port=65535
verbose
fingerprint
use-auth-secret
static-auth-secret=xxx
realm=signaling.domain
keep-address-family
no-cli
no-tlsv1
no-tlsv1_1
denied-peer-ip=10.0.0.0-10.255.255.255
denied-peer-ip=172.16.0.0-172.31.255.255
denied-peer-ip=192.168.0.0-192.168.255.255
denied-peer-ip=100.64.0.0-100.127.255.255
denied-peer-ip=169.254.0.0-169.254.255.255
denied-peer-ip=192.0.0.0-192.0.0.255
denied-peer-ip=192.0.2.0-192.0.2.255
denied-peer-ip=198.18.0.0-198.19.255.255
denied-peer-ip=198.51.100.0-198.51.100.255
denied-peer-ip=203.0.113.0-203.0.113.255
denied-peer-ip=fc00::-fdff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
denied-peer-ip=fe80::-febf:ffff:ffff:ffff:ffff:ffff:ffff:ffff
denied-peer-ip=::ffff:0:0-::ffff:ffff:ffff
denied-peer-ip=64:ff9b::-64:ff9b::ffff:ffff
denied-peer-ip=64:ff9b:1::-64:ff9b:1:ffff:ffff:ffff:ffff:ffff
denied-peer-ip=2001::-2001:1ff:ffff:ffff:ffff:ffff:ffff:ffff
denied-peer-ip=2001:db8::-2001:db8:ffff:ffff:ffff:ffff:ffff:ffff
denied-peer-ip=2002::-2002:ffff:ffff:ffff:ffff:ffff:ffff:ffff
