Liebe Comunity,
ich habe eine neue nextcloud eingerichtet mit der aktuellen Version 11.0. Der Fehler tritt bei mir allerdings auch bei 10.0.2 auf.
Nach klicken auf Benutzer anlegen passiert nichts, beim (neu)laden einer nextcloud-Seite erscheint lediglich eine leere, weiße Seite. Nach ca. einer halben Minute lässt sich das System wieder erreichen.
Hier der Log des letzten Versuches mit 10.0.2:
> {“reqId”:“WF04m8CoLOkAADV5j@wAAABK”,“remoteAddr”:“217.82.60.189”,“app”:“mysql.setup”,“message”:“Specific user creation failed: An exception occurred while executing ‘SELECT user FROM mysql.user WHERE user=?’ with params [“oc__username_”]:\n\nSQLSTATE[42000]: Syntax error or access violation: 1142 SELECT command denied to user ‘U111111’@‘braggi.store.d0m.de’ for table ‘user’”,“level”:3,“time”:“2016-12-23T14:45:48+00:00”,“method”:“POST”,“url”:"/index.php",“user”:"–",“version”:“9.1.2.2”}
{"reqId":"WF04m8CoLOkAADV5j@wAAABK","remoteAddr":"_ip_","app":"mysql.setup","message":"Database creation failed: An exception occurred while executing 'GRANT ALL PRIVILEGES ON `DB_111111_` . * TO _'U111111_':\n\nSQLSTATE[42000]: Syntax error or access violation: 1044 Access denied for user '_U111111_'@'192.168.4%' to database '_DB111111_'","level":3,"time":"2016-12-23T14:45:48+00:00","method":"POST","url":"\/index.php","user":"--","version":"9.1.2.2"} {"reqId":"WF04ycCoLOkAABsMch4AAABO","remoteAddr":"_ip_","app":"PHP","message":"opendir(\/var\/tmp\/): failed to open dir: Permission denied at \/_..._\/nextcloud\/lib\/private\/TempManager.php#189","level":3,"time":"2016-12-23T14:46:33+00:00","method":"GET","url":"\/cron.php","user":"--","version":"9.1.2.2"} {"reqId":"WF05N8CoLOkAAD8unmwAAAJR","remoteAddr":"_ip_","app":"PHP","message":"opendir(\/var\/tmp\/): failed to open dir: Permission denied at \/_..._\/nextcloud\/lib\/private\/TempManager.php#189","level":3,"time":"2016-12-23T14:48:24+00:00","method":"GET","url":"\/cron.php","user":"--","version":"9.1.2.2"} {"reqId":"WF05PMCoLOkAAD8unnIAAAJR","remoteAddr":"_ip_","app":"PHP","message":"opendir(\/var\/tmp\/): failed to open dir: Permission denied at \/_..._\/nextcloud\/lib\/private\/TempManager.php#189","level":3,"time":"2016-12-23T14:48:28+00:00","method":"GET","url":"\/cron.php","user":"--","version":"9.1.2.2"} {"reqId":"WF05PsCoLOkAAG6ExgYAAABF","remoteAddr":"_ip_","app":"PHP","message":"opendir(\/var\/tmp\/): failed to open dir: Permission denied at \/_..._\/nextcloud\/lib\/private\/TempManager.php#189","level":3,"time":"2016-12-23T14:48:30+00:00","method":"GET","url":"\/cron.php","user":"--","version":"9.1.2.2"} {"reqId":"WF07dMCoLOkAAE@7HNkAAALA","remoteAddr":"_ip_","app":"PHP","message":"opendir(\/var\/tmp\/): failed to open dir: Permission denied at \/_..._\/nextcloud\/lib\/private\/TempManager.php#189","level":3,"time":"2016-12-23T14:57:57+00:00","method":"GET","url":"\/cron.php","user":"--","version":"9.1.2.2"} {"reqId":"WF07esCoLOkAAD3eAoMAAAFX","remoteAddr":"_ip_","app":"PHP","message":"opendir(\/var\/tmp\/): failed to open dir: Permission denied at \/_..._\/nextcloud\/lib\/private\/TempManager.php#189","level":3,"time":"2016-12-23T14:58:02+00:00","method":"GET","url":"\/cron.php","user":"--","version":"9.1.2.2"} {"reqId":"WF07n8CoLOkAAEpjFHgAAAGZ","remoteAddr":"_ip_","app":"PHP","message":"opendir(\/var\/tmp\/): failed to open dir: Permission denied at \/_..._\/nextcloud\/lib\/private\/TempManager.php#189","level":3,"time":"2016-12-23T14:58:39+00:00","method":"GET","url":"\/cron.php","user":"--","version":"9.1.2.2"} {"reqId":"WF07oMCoLOkAAENyD18AAAHL","remoteAddr":"_ip_","app":"PHP","message":"opendir(\/var\/tmp\/): failed to open dir: Permission denied at \/_..._\/nextcloud\/lib\/private\/TempManager.php#189","level":3,"time":"2016-12-23T14:58:40+00:00","method":"GET","url":"\/cron.php","user":"--","version":"9.1.2.2"}
Gehostet ist das ganze bei Strato.
Über Hilfe würde ich mich sehr freuen, da ich ansonsten ein anderes System suchen müsste, ohne Benutzer ist das ganze etwas witzlos.
Danke und weihnachtliche Grüße
Erik
