Nextcloud version Nextcloud Hub 4 (26.0.4)
Operating system and version Ubuntu 22.04.3 LTS
Apache or nginx version seems like none is installed.
PHP version don’t know how to check, tried different things but nothing worked.
I did and apt-get update upgrade.
Stuck in maintenance mode, can access nextcloud by spamming update in browser but nothing works. CPU usage is quite high.
Yes
- apt-get update
- apt-get upgrade
- roboot
- nextcloud not working
{"reqId":"hRh4TZOsfQy45Zi8wdL4","level":3,"time":"2023-08-26T21:45:41+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"hRh4TZOsfQy45Zi8wdL4","level":3,"time":"2023-08-26T21:45:52+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"hRh4TZOsfQy45Zi8wdL4","level":3,"time":"2023-08-26T21:45:52+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"qjUxD8sWoJTW84PdroMq","level":3,"time":"2023-08-26T21:46:06+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"qjUxD8sWoJTW84PdroMq","level":3,"time":"2023-08-26T21:46:17+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"qjUxD8sWoJTW84PdroMq","level":3,"time":"2023-08-26T21:46:17+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"5CwI4bxcJ4H2ARX7kxNQ","level":3,"time":"2023-08-26T21:46:30+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"5CwI4bxcJ4H2ARX7kxNQ","level":3,"time":"2023-08-26T21:46:42+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"5CwI4bxcJ4H2ARX7kxNQ","level":3,"time":"2023-08-26T21:46:42+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"1tGBWhL3AmjkgIXsxFB0","level":3,"time":"2023-08-26T21:46:55+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"1tGBWhL3AmjkgIXsxFB0","level":3,"time":"2023-08-26T21:47:06+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"1tGBWhL3AmjkgIXsxFB0","level":3,"time":"2023-08-26T21:47:06+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"mKeMmQ4CG0wkrLboHw7u","level":3,"time":"2023-08-26T21:47:18+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"mKeMmQ4CG0wkrLboHw7u","level":3,"time":"2023-08-26T21:47:30+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"mKeMmQ4CG0wkrLboHw7u","level":3,"time":"2023-08-26T21:47:30+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"Wh3IHmtxDVETWD8OseQI","level":3,"time":"2023-08-26T21:47:43+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"Wh3IHmtxDVETWD8OseQI","level":3,"time":"2023-08-26T21:47:54+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"Wh3IHmtxDVETWD8OseQI","level":3,"time":"2023-08-26T21:47:54+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"W20hqxjfGSWQToRfz9od","level":3,"time":"2023-08-26T21:48:07+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"W20hqxjfGSWQToRfz9od","level":3,"time":"2023-08-26T21:48:19+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"W20hqxjfGSWQToRfz9od","level":3,"time":"2023-08-26T21:48:19+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"aoH8DWQHmbeVcycvRDAx","level":3,"time":"2023-08-26T21:48:32+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"aoH8DWQHmbeVcycvRDAx","level":3,"time":"2023-08-26T21:48:44+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"aoH8DWQHmbeVcycvRDAx","level":3,"time":"2023-08-26T21:48:44+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"qwfDobVLCRoEwqLEmDwo","level":3,"time":"2023-08-26T21:48:57+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"qwfDobVLCRoEwqLEmDwo","level":3,"time":"2023-08-26T21:49:08+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"qwfDobVLCRoEwqLEmDwo","level":3,"time":"2023-08-26T21:49:08+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"7K0GwRduvgNrancdlXQP","level":3,"time":"2023-08-26T21:49:22+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"7K0GwRduvgNrancdlXQP","level":3,"time":"2023-08-26T21:49:34+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"7K0GwRduvgNrancdlXQP","level":3,"time":"2023-08-26T21:49:34+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
{"reqId":"kMDhXzc0h7n2pqNhAKP1","level":3,"time":"2023-08-26T21:49:47+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"chmod(): Permission denied at /var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php#169","userAgent":"--","version":"26.0.4.2","data":{"app":"PHP"}}
{"reqId":"kMDhXzc0h7n2pqNhAKP1","level":3,"time":"2023-08-26T21:49:58+00:00","remoteAddr":"","user":"--","app":"recognize","method":"","url":"--","message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","userAgent":"--","version":"26.0.4.2","data":{"app":"recognize"}}
{"reqId":"kMDhXzc0h7n2pqNhAKP1","level":3,"time":"2023-08-26T21:49:58+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Exception while executing repair step Install dependencies","userAgent":"--","version":"26.0.4.2","exception":{"Exception":"Exception","Message":"Failed to install Tensorflow.js: CPU-linux-4.6.0.tar.gz\n* Downloading libtensorflow\nhttps://storage.googleapis.com/tensorflow/libtensorflow/libtensorflow-cpu-linux-x86_64-2.9.1.tar.gz\n\n* Building TensorFlow Node.js bindings\nnode-pre-gyp install failed with error: Error: Command failed: node-pre-gyp install --fallback-to-build\n/usr/bin/env: 'node': No such file or directory","Code":0,"Trace":[{"file":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","line":93,"function":"runTfjsInstall","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Repair.php","line":126,"function":"run","class":"OCA\\Recognize\\Migration\\InstallDeps","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/core/Command/Maintenance/Repair.php","line":123,"function":"run","class":"OC\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Repair","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->"},{"file":"/snap/nextcloud/36392/htdocs/occ","line":11,"args":["/snap/nextcloud/36392/htdocs/console.php"],"function":"require_once"}],"File":"/var/snap/nextcloud/36392/nextcloud/extra-apps/recognize/lib/Migration/InstallDeps.php","Line":197,"message":"Exception while executing repair step Install dependencies","exception":{},"CustomMessage":"Exception while executing repair step Install dependencies"}}
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'log_type' => 'file',
'logfile' => '/var/snap/nextcloud/current/logs/nextcloud.log',
'logfilemode' => 416,
'instanceid' => 'oclfrj6rvad4',
'passwordsalt' => 'RLNzt8lhU+LqRDL/zgTEiTUZszzU5l',
'secret' => '66Mi9x2elYVabol5VHS3Zh0fd3E1488MHB1GEqksoxv64Kdb',
0 => '*',
'datadirectory' => '/media/storage2tb/data',
'version' => '26.0.4.2',
'overwrite.cli.url' => 'http://192.',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => 'KKM4cidrmAjTW6194363dcv0WYmeEVmM73CMch4OApchwokhLvE1WAcjj-AVGf1z',
'memories.exiftool' => '/var/snap/nextcloud/35878/nextcloud/extra-apps/memories/exiftool-bin/exiftool-amd64-glibc',
'memories.vod.path' => '/var/snap/nextcloud/35878/nextcloud/extra-apps/memories/exiftool-bin/go-vod-amd64',
'app_install_overwrite' =>
0 => 'occweb',
'preview_max_x' => 1024,
'preview_max_y' => 1024,
'loglevel' => 2,
'theme' => '',
which one?
alternatives.log apport.log.2.gz apport.log.7.gz auth.log.3.gz boot.log.3 btmp dmesg.0 dpkg.log gpu-manager.log kern.log.1 openvpn syslog.2.gz ubuntu-advantage-timer.log
alternatives.log.1 apport.log.3.gz apt auth.log.4.gz boot.log.4 btmp.1 dmesg.1.gz dpkg.log.1 hp kern.log.2.gz private syslog.3.gz ubuntu-advantage-timer.log.1
anydesk.trace apport.log.4.gz auth.log boot.log boot.log.5 cups dmesg.2.gz faillog installer kern.log.3.gz speech-dispatcher syslog.4.gz unattended-upgrades
apport.log apport.log.5.gz auth.log.1 boot.log.1 boot.log.6 dist-upgrade dmesg.3.gz fontconfig.log journal kern.log.4.gz syslog ubuntu-advantage.log wtmp
apport.log.1 apport.log.6.gz auth.log.2.gz boot.log.2 bootstrap.log dmesg dmesg.4.gz gdm3 kern.log lastlog syslog.1 ubuntu-advantage.log.1
