example
longer
example
here
Nextcloud version (eg, 20.0.5): 23.0.2
Operating system and version (eg, Ubuntu 20.04): Arch Linux
Apache or nginx version (eg, Apache 2.4.25): nginx 1.20.2-1
PHP version (eg, 7.4): 8.1.3-1
Nextcloud stops responding for a few seconds every few seconds. So when I go to click on a menu item on the sidebar it will suddenly stop responding to any mouse movement or mouse clicks or any other events. If the mouse pointer was a hand it will remain a hand for the few seconds it’s frozen and then when nextcloud unfreezes the pointer will turn into a mouse pointer again if im no longer on a menu item.
I’ve noticed this a lot in the logs:
PHP security error: /var/lib/nextcloud/apps/richdocumentscode/proxy.php is not under the default docroot
I basically set it up according to this wiki: https://wiki.archlinux.org/title/Nextcloud
using uwsqi and postgres
- Open nextcloud on any device
[PHP] Error: foreach() argument must be of type array|object, bool given at /usr/share/webapps/nextcloud/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#152
GET /settings/admin/serverinfo
from 192.168.50.1 by admin at 2022-03-05T16:22:18+00:00
[index] Error: SplFileInfo::isDir(): open_basedir restriction in effect. File(/var/lib/nextcloud/apps/..) is not within the allowed path(s): (/var/lib/nextcloud/data:/var/lib/nextcloud/apps:/tmp:/usr/share/webapps/nextcloud:/etc/webapps/nextcloud:/dev/urandom:/usr/lib/php/modules:/var/log/nextcloud:/proc/meminfo)
GET /settings/ajax/checksetup
from 192.168.50.1 by admin at 2022-03-05T16:15:43+00:00
NOTE: Since seeing this error I commented out the open_basedir line in php.ini and /etc/uwsgi/nextcloud.ini
0 => 'localhost',
1 => 'cloud.atavismxi.com',
'overwrite.cli.url' => 'https://cloud.atavismxi.com/',
'memcache.local' => '\OC\Memcache\APCu',
'datadirectory' => '/var/lib/nextcloud/data',
'apps_paths' =>
0 =>
'path' => '/usr/share/webapps/nextcloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/lib/nextcloud/apps',
'url' => '/wapps',
'writable' => true,
'passwordsalt' => 'xP+Ibs63/TNfU11Xkc23GlxtXHc3T5',
'secret' => 'LQIuMeSZlclHxefaBWrli7jO0lhjA/WH+lO22G85DyziKkTY',
'dbtype' => 'pgsql',
'version' => '23.0.2.1',
'dbname' => 'nextcloud',
'dbhost' => '/run/postgresql',
'dbuser' => 'nextcloud',
'dbpassword' => '1234',
'instanceid' => 'ocsatj3726cy',
File is way too big
