Same applies here. Did you get your issue solved? If not, did you try downgrading the openssl library on your server, at least if you have access to it? While downgrading the client didn’t help, downgrading the server did.
Due to an webhosting package with no access to the library, the only solution for teh monet was downgrading the client as I mentioned before.
so something weird happened. I did not do anything on the server side, I downgraded the client tho and it didn’t work… however, the following morning everything worked again… I can’t understand what changed! seem like its now working like before since yesterday…
This episode was very weird. It’s almost as though someone was trying a SSL attack of some kind.
@blu-IT But were you able to solve your problem?
@Herbert_Bactong Strange. Is it shared hosting so the hoster might have installed updates? Or maybe some client OS updates rolled through?
@Pazu Does the issue still occur to you?
The server is a VPS so we manage it ourselves including updates… so its really strange…
